    MMM-Face-Reco-DNN + ProfileSwitcher
    21 Posts 3 Posters 7.4k Views 3 Watching
      Stardyze @sdetweil
      @sdetweil I have all the modules selected with the class name I want for them do I set the class name in the config.js or MMM-Face-Reco-DNN.js?
        sdetweil @Stardyze
        @stardyze in config.js, on each module set the classes per person
        module: “clock:,
        classes:” fred sue",
        same for every module
        u have to set allowed users in facreco of course
          Stardyze @sdetweil
          @sdetweil Yeah I set all the classes for each module in the config.js but for so that it knows the allowed users is that in the MMM-Face-Reco-DNN.js? Like the first declaration of the classname.
            sdetweil @Stardyze
            @stardyze there is no ‘actual’ class… Facereco just looks at the classes field to match against user names
              Stardyze @sdetweil
              @sdetweil So I can’t have specific classes or layouts for each person?
                sdetweil @Stardyze
                @stardyze https://github.com/nischi/MMM-Face-Reco-DNN
                Yes, and you can share…
                layout is a challenge… like profile u need multiple instances of the same module,
                for different users…
                MM can only show or hide modules… so, you have one instance for sam, and another for bob
                  Stardyze @sdetweil
                  @sdetweil I do have classes set in each module but it doesn’t switch the profiles when a face is recognized. In the terminal, it says that the right user is recognized and is logged in but the layout doesn’t change.
                    sdetweil @Stardyze
                    @stardyze see
                    https://github.com/nischi/MMM-Face-Reco-DNN#classes
                    case of the names matters… Sam does not equal sam
                      Stardyze @sdetweil
                      @sdetweil I did look through that page and all the case names are the same (lowercase) from my dataset folders for each person to the class names for each module and it still doesn’t switch modules in the mirror. Do I have to classify the each class first in the .js in the facereco module first?
                        sdetweil @Stardyze
                        @stardyze u now know everything I know…
                        I set the module up once, and it worked on the 1st try. haven’t used it since (as I am the only user)
                          Stardyze @sdetweil
                          @sdetweil Okay haha thank you so much for your time
                            sdetweil @Stardyze
                            @stardyze the mosdule classes are space separated… right?
                              Stardyze @sdetweil
                              @sdetweil you mean like the name of the class is not right next to the colon?
                                sdetweil @Stardyze
                                @stardyze no
                                classes: “sam bob sue fred”
                                not
                                classes: “sam, bob, sue, fred”
                                  Stardyze @sdetweil
                                  @sdetweil Oh yeah of course for each module I have a space like “sam bob sue fred”
                                  • N Offline
                                    njw
                                    A “soft-announce” for something I’m working on, but is almost ready to be released…
                                    I’ve had problems with all the versions of face-recognition, profile-switching, debugging… so I’m attempting to create a new module that takes out most of the pain. The pain of getting the profiles configured correctly is still there (that’s job#2), but the facial recognition… that was something I wanted to try and improve. So, pre-announcing a new face recognition module (because we all need another module doing the same thing).
                                    https://github.com/njwilliams/MMM-Faces
                                    I welcome thoughts/suggestions to improve this!
