    Cannot find module "moment"
    98 Posts 2 Posters 47.7k Views 2 Watching
      sdetweil @uok825
      @uok825 hm… I use it so it should be easy…
        sdetweil @uok825
        @uok825 do u need that set of parents in front of $
        U 1 Reply Last reply Reply Quote 0
        • U Offline
          uok825 @sdetweil
          @sdetweil Deleted parents but still same.
          0|MagicMirror  | [26.07.2021 13:25.47.639] [ERROR]
          0|MagicMirror  | Whoops! There was an uncaught exception...
          0|MagicMirror  | [26.07.2021 13:25.47.741] [ERROR]
          0|MagicMirror  | TypeError: $ is not a function
          0|MagicMirror  |     at Request.request [as _callback] (/home/pi/MagicMirror/mod        ules/MMM-LICE/node_helper.js:27:26)
          0|MagicMirror  |     at Request.self.callback (/home/pi/MagicMirror/modules/MMM-        LICE/node_modules/request/request.js:185:22)
          0|MagicMirror  |     at Request.emit (events.js:198:13)
          0|MagicMirror  |     at Request.<anonymous> (/home/pi/MagicMirror/modules/MMM-LI        CE/node_modules/request/request.js:1154:10)
          0|MagicMirror  |     at IncomingMessage.<anonymous> (/home/pi/MagicMirror/module        s/MMM-LICE/node_modules/request/request.js:1076:12)
          0|MagicMirror  |     at Object.onceWrapper (events.js:286:20)
          0|MagicMirror  |     at IncomingMessage.emit (events.js:203:15)
          0|MagicMirror  |     at endReadableNT (_stream_readable.js:1145:12)
          0|MagicMirror  |     at process._tickCallback (internal/process/next_tick.js:63:        19)
          0|MagicMirror  | [26.07.2021 13:25.47.770] [ERROR]
          0|MagicMirror  | MagicMirror will not quit, but it might be a good idea to check        why this happened. Maybe no internet connection?
          0|MagicMirror  | [26.07.2021 13:25.47.788] [ERROR] If you think this really is a        n issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror        /issues
            sdetweil @uok825
            @uok825 weird. never seen such a thing
            can u try changing the $ to zz
            in the require and where used.
            $ is usually used for jQuery
            • U Offline
              uok825 @sdetweil
              @sdetweil I just rebuild the module without using request.
                sdetweil @uok825
                @uok825 ok, but THAT also make no sense…
                • U Offline
                  uok825 @sdetweil
                  @sdetweil Hi there! Problem solved. New code:
                  /* Magic Mirror
                   * Module: MMM-LICE
                   * By Mykle1
                  const NodeHelper = require('node_helper');
                  const request = require('request');
                  const cheerio = require('cheerio');
                      start: function() {
                          console.log("Starting node_helper for: " + this.name);
                      getLICE: function(url) {
                      request({
                          url: 'https://kur.altin.in/banka',
                          method: 'GET'
                      }, (error, response, body) => {
                          if (!error && response.statusCode == 200) {
                              const $ = cheerio.load(body);
                  			var arr = []
                              var result = $('.fiyat');
                              result.each((_id,el) =>  (arr.push(el.children[0]['data'])))
                              var result = $('h2[id=gfiy]');
                              this.sendSocketNotification('LICE_RESULT', arr);
                          if (notification === 'GET_LICE') {
                              this.getLICE(payload);
                  But i have an another problem. Turkish characters in the news seem broken. I think there is a utf-8 error but it doesn’t write anything in the logs.
                  Edit: The news site is broken, it’s not a mistake about us.
                    sdetweil @uok825
                    @uok825 maybe u have to pass a header in the request for utf8 formated response, or encoded…
                    • 6
                    • 7
                    • 8
                    • 9
                    • 10
                    • 10 / 10
