    Cannot find module "moment"
    98 Posts 2 Posters 51.9k Views 2 Watching
      sdetweil @uok825
      @uok825 to shorten the path
      pm2 stop all
      then do
      npm start
      in the MagicMirror folder
      alt-spacebar, n to minimize MM
      then ctrl-c to stop
      once good, then pm2 status to get the number and
      pm2 start 0 or whatever number
      U 1 Reply Last reply Reply Quote 0
      • U Offline
        uok825 @sdetweil
        @sdetweil I am connected with SSH. I always did pm2 stop 0, pm2 flush, do my work and pm2 start 0. But PI0 is so slow still doing npm :D
          sdetweil @uok825
          @uok825 but don’t need to do pm2 start until its working correctly
          why do you post screen shots if connected via ssh?/ just copy the text…
            sdetweil @uok825
            @uok825 pm2 calls npm same thing…
            • U Offline
              uok825 @sdetweil
              @sdetweil Screenshot is a habit for me to take. easier than copying
                sdetweil @uok825
                @uok825 screen shots harder to read here, very tiny… impossible on phone
                U 2 Replies Last reply Reply Quote 0
                • U Offline
                  uok825 @sdetweil
                  @sdetweil Sorry to hear it. I try not to receive the screenshot sorry.
                  • U Offline
                    uok825 @sdetweil
                    @sdetweil Bad news
                    npm install log
                    pi@raspberrypi:~/MagicMirror $ npm install uuid
                    > husky@4.2.5 preuninstall /home/pi/MagicMirror/node_modules/husky
                    > node husky uninstall
                    internal/modules/cjs/loader.js:638
                        throw err;
                    Error: Cannot find module 'please-upgrade-node'
                        at Function.Module._resolveFilename (internal/modules/cjs/loader.js:636:15)
                        at Function.Module._load (internal/modules/cjs/loader.js:562:25)
                        at Module.require (internal/modules/cjs/loader.js:692:17)
                        at require (internal/modules/cjs/helpers.js:25:18)
                        at Object.<anonymous> (/home/pi/MagicMirror/node_modules/husky/husky.js:3:27)
                        at Module._compile (internal/modules/cjs/loader.js:778:30)
                        at Object.Module._extensions..js (internal/modules/cjs/loader.js:789:10)
                        at Module.load (internal/modules/cjs/loader.js:653:32)
                        at tryModuleLoad (internal/modules/cjs/loader.js:593:12)
                        at Function.Module._load (internal/modules/cjs/loader.js:585:3)
                    npm WARN lifecycle husky@4.2.5~preuninstall: continuing anyway husky@4.2.5 preuninstall: `node husky uninstall`
                    npm WARN lifecycle Exit status 1
                    > electron-chromedriver@11.0.0 install /home/pi/MagicMirror/node_modules/electron-chromedriver
                    > node ./download-chromedriver.js
                    (node:1464) UnhandledPromiseRejectionWarning: HTTPError: Response code 404 (Not Found) for https://github.com/electron/electron/releases/download/v11.0.0/chromedriver-v11.0.0-linux-armv6l.zip
                        at EventEmitter.emitter.on.response (/home/pi/MagicMirror/node_modules/got/source/as-stream.js:35:24)
                        at EventEmitter.emit (events.js:198:13)
                        at module.exports (/home/pi/MagicMirror/node_modules/got/source/get-response.js:22:10)
                        at ClientRequest.handleResponse (/home/pi/MagicMirror/node_modules/got/source/request-as-event-emitter.js:155:5)
                        at Object.onceWrapper (events.js:286:20)
                        at ClientRequest.emit (events.js:203:15)
                        at ClientRequest.origin.emit.args [as emit] (/home/pi/MagicMirror/node_modules/@szmarczak/http-timer/source/index.js:37:11)
                        at HTTPParser.parserOnIncomingClient [as onIncoming] (_http_client.js:565:21)
                        at HTTPParser.parserOnHeadersComplete (_http_common.js:111:17)
                        at TLSSocket.socketOnData (_http_client.js:451:20)
                    (node:1464) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). (rejection id: 1)
                    (node:1464) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero exit code.
                    > electron@11.4.9 postinstall /home/pi/MagicMirror/node_modules/electron
                    > node install.js
                    HTTPError: Response code 404 (Not Found) for https://github.com/electron/electron/releases/download/v11.4.9/electron-v11.4.9-linux-armv6l.zip
                    > spectron@13.0.0 postinstall /home/pi/MagicMirror/node_modules/spectron
                    > node lib/rpath-fix.js
                    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/fsevents):
                    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
                    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: electron@11.4.9 (node_modules/electron):
                    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: electron@11.4.9 postinstall: `node install.js`
                    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
                    + uuid@8.3.2
                    added 334 packages from 707 contributors, updated 144 packages and audited 924 packages in 1278.767s
                    110 packages are looking for funding
                      run `npm fund` for details
                    found 0 vulnerabilities
                    MM Log
                    /home/pi/.pm2/logs/MagicMirror-error.log last 15 lines:
                    0|MagicMir | [26.07.2021 01:29.53.118] [WARN]  The module 'currentweather' is deprecated in favor of the 'weather'-module, please refer to the documentation for a migration path
                    0|MagicMir | [26.07.2021 01:29.53.151] [WARN]  The module 'weatherforecast' is deprecated in favor of the 'weather'-module, please refer to the documentation for a migration path
                    /home/pi/.pm2/logs/MagicMirror-out.log last 15 lines:
                    0|MagicMir | [26.07.2021 01:29.53.135] [LOG] Connecting socket for: weatherforecast
                    0|MagicMir | [26.07.2021 01:29.53.160] [LOG] Connecting socket for: newsfeed
                    0|MagicMir | [26.07.2021 01:29.53.172] [LOG] Starting node helper for: newsfeed
                    0|MagicMir | [26.07.2021 01:29.53.185] [LOG] Connecting socket for: MMM-cryptocurrency
                    0|MagicMir | [26.07.2021 01:29.53.202] [LOG] Cryptocurrency module loaded!
                    0|MagicMir | [26.07.2021 01:29.53.214] [LOG] Connecting socket for: MMM-MyPrayerTimes
                    0|MagicMir | [26.07.2021 01:29.53.223] [LOG] Starting node_helper for: MMM-MyPrayerTimes
                    0|MagicMir | [26.07.2021 01:29.53.236] [LOG] Connecting socket for: MMM-LICE
                    0|MagicMir | [26.07.2021 01:29.53.251] [LOG] Starting node_helper for: MMM-LICE
                    0|MagicMir | [26.07.2021 01:29.53.263] [LOG] Connecting socket for: MMM-PIR
                    0|MagicMir | [26.07.2021 01:29.53.280] [LOG] Starting module helper: MMM-PIR
                    0|MagicMir | [26.07.2021 01:29.53.289] [LOG] Sockets connected & modules started ...
                    0|MagicMir | [26.07.2021 01:29.53.303] [LOG]
                    0|MagicMir | Ready to go! Please point your browser to: http://0.0.0.0:8080
                    0|MagicMir | Starting chromium browser now, have patience, it takes a minute
                    0|MagicMirror  | [26.07.2021 01:31.55.275] [LOG]
                    0|MagicMirror  | Create new calendarfetcher for url: https://calendar.google.com/calendar/ical/10s0ee0h3tb1ko7fqhpf71sfgs%40group.calendar.google.com/private-d3794e10c136ecfea3ad72fe63078acd/basic.ics - Interval: 300000
                    0|MagicMirror  | [26.07.2021 01:31.57.499] [LOG]
                    0|MagicMirror  | Create new newsfetcher for url: https://www.cnnturk.com/feed/rss/turkiye/news - Interval: 300000
                    0|MagicMirror  | [26.07.2021 01:31.58.207] [LOG]
                    0|MagicMirror  | Create new newsfetcher for url: https://www.birgun.net/xml/rss.xml - Interval: 300000
                    0|MagicMirror  | [26.07.2021 01:31.58.335] [LOG]
                    0|MagicMirror  | Create new newsfetcher for url: https://tr.cointelegraph.com/google.xml - Interval: 300000
                    0|MagicMirror  | [26.07.2021 01:32.08.343] [ERROR]
                    0|MagicMirror  | Newsfeed Error. Could not fetch newsfeed:  https://tr.cointelegraph.com/google.xml Error: Feed type not recognized
                    0|MagicMirror  |     at SAXStream.openf1 (/home/pi/MagicMirror/node_modules/feedme/dist/xmlfeedparser.js:99:38)
                    0|MagicMirror  |     at SAXStream.emit (events.js:198:13)
                    0|MagicMirror  |     at SAXStream._parser.parser.emit.args [as emit] (/home/pi/MagicMirror/node_modules/feedme/dist/feedme.js:24:24)
                    0|MagicMirror  |     at SAXParser.me._parser.(anonymous function) [as onopentag] (/home/pi/MagicMirror/node_modules/sax/lib/sax.js:258:17)
                    0|MagicMirror  |     at emit (/home/pi/MagicMirror/node_modules/sax/lib/sax.js:624:35)
                    0|MagicMirror  |     at emitNode (/home/pi/MagicMirror/node_modules/sax/lib/sax.js:629:5)
                    0|MagicMirror  |     at openTag (/home/pi/MagicMirror/node_modules/sax/lib/sax.js:825:5)
                    0|MagicMirror  |     at SAXParser.write (/home/pi/MagicMirror/node_modules/sax/lib/sax.js:1391:13)
                    0|MagicMirror  |     at SAXStream.write (/home/pi/MagicMirror/node_modules/sax/lib/sax.js:239:18)
                    0|MagicMirror  |     at XMLFeedParser._write (/home/pi/MagicMirror/node_modules/feedme/dist/xmlfeedparser.js:159:21)
                    0|MagicMirror  | [26.07.2021 01:32.08.796] [ERROR]
                    0|MagicMirror  | Whoops! There was an uncaught exception...
                    0|MagicMirror  | [26.07.2021 01:32.08.851] [ERROR]
                    0|MagicMirror  | TypeError: $ is not a function
                    0|MagicMirror  |     at Request.request [as _callback] (/home/pi/MagicMirror/modules/MMM-LICE/node_helper.js:27:27)
                    0|MagicMirror  |     at Request.self.callback (/home/pi/MagicMirror/modules/MMM-LICE/node_modules/request/request.js:185:22)
                    0|MagicMirror  |     at Request.emit (events.js:198:13)
                    0|MagicMirror  |     at Request.<anonymous> (/home/pi/MagicMirror/modules/MMM-LICE/node_modules/request/request.js:1154:10)
                    0|MagicMirror  |     at IncomingMessage.<anonymous> (/home/pi/MagicMirror/modules/MMM-LICE/node_modules/request/request.js:1076:12)
                    0|MagicMirror  |     at Object.onceWrapper (events.js:286:20)
                    0|MagicMirror  |     at IncomingMessage.emit (events.js:203:15)
                    0|MagicMirror  |     at endReadableNT (_stream_readable.js:1145:12)
                    0|MagicMirror  |     at process._tickCallback (internal/process/next_tick.js:63:19)
                    0|MagicMirror  | [26.07.2021 01:32.08.884] [ERROR] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                    0|MagicMirror  | [26.07.2021 01:32.08.907] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                    0|MagicMirror  | [26.07.2021 01:32.09.574] [LOG]
                    0|MagicMirror  | 200[object Object]
                    0|MagicMirror  | [26.07.2021 01:32.45.860] [ERROR]
                    0|MagicMirror  | [26.07.2021 01:32.45.891] [ERROR] TypeError: $ is not a function
                    0|MagicMirror  | [26.07.2021 01:32.45.904] [ERROR] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                    0|MagicMirror  | [26.07.2021 01:32.45.926] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                    But the good side is now i can see screen. Waiting for loading other modules. Maybe it will working.
                      sdetweil @uok825
                      @uok825 said in Cannot find module "moment":
                      Cannot find module ‘please-upgrade-node’
                      for every cannot find module, repeat
                      npm install missing_name
                      not sure on the rss feed thing… I see the output, but it doesn’t look like a normal xml feed doc
                      • U Offline
                        uok825 @sdetweil
                        @sdetweil I’ll delete cointelegraph. Now i am working on LICE module. I am changed that module code.
                        • 6
                        • 7
                        • 8
                        • 9
                        • 10
                        • 8 / 10
