    Cannot find module "moment"
    98 Posts 2 Posters 47.7k Views 2 Watching
      sdetweil @uok825
      @uok825 said in Cannot find module "moment":
      Now i am working on LICE module. I am changed that module code.
      ok, I was looking at the original code and couldn’t find a useful line 27
      typically $ is jquery
      but the module doesn’t say it needs it…
      no package.json for dependencies and the node_helper doesn’t require it
      U 1 Reply Last reply Reply Quote 0
      • U Offline
        uok825 @sdetweil
        /* Magic Mirror
         * Module: MMM-LICE
         * By Mykle1
        const NodeHelper = require('node_helper');
        const request = require('request');
        const $ = require('cheerio');
            start: function() {
                console.log("Starting node_helper for: " + this.name);
            getLICE: function(url) {
            request({
                url: 'https://kur.altin.in/banka',
                method: 'GET'
            }, (error, response, body) => {
                if (!error && response.statusCode == 200) {
        			var arr = []
                    var result = ($('.fiyat',body));
                    result.each((_id,el) =>  (arr.push(el.children[0]['data'])))
                    var result = ($('h2[id=gfiy]',body));
                    this.sendSocketNotification('LICE_RESULT', arr);
                if (notification === 'GET_LICE') {
                    this.getLICE(payload);
          sdetweil @uok825
          @uok825 yep, that’ll do it…
          npm install cheerio
          my updater would have fixed all this IF there was a package.json file that documented the dependencies
          npm install request cheerio --save
          • U Offline
            uok825 @sdetweil
            @sdetweil Thanks man. You are the best. https://github.com/uok825/MagicMirror/tree/master/modules/MMM-LICE
              sdetweil @uok825
              @uok825 in the module folder do
              npm init
              answer the questions as best u can, ignore them if u can’t
              then
              then update your git repo with the new package.json file
              • U Offline
                uok825 @sdetweil
                @sdetweil Now im doing the npm install request cheerio --save . Should I continue or cancel?
                  sdetweil @uok825
                  @uok825 continue
                  might not create a package.json if not one
                  redo after the npm init
                  • U Offline
                    uok825 @sdetweil
                    Still same
                    pi@raspberrypi:~/MagicMirror/modules/MMM-LICE $ pm2 logs
                    [TAILING] Tailing last 15 lines for [all] processes (change the value with --lines option)
                    /home/pi/.pm2/pm2.log last 15 lines:
                    PM2        | 2021-07-26T02:05:51: PM2 log: App [MagicMirror:0] starting in -fork mode-
                    PM2        | 2021-07-26T02:05:52: PM2 log: App [MagicMirror:0] online
                    /home/pi/.pm2/logs/MagicMirror-error.log last 15 lines:
                    0|MagicMir | [26.07.2021 02:06.21.033] [WARN]  The module 'currentweather' is deprecated in favor of the 'weather'-module, please refer to the documentation for a migration path
                    0|MagicMir | [26.07.2021 02:06.21.065] [WARN]  The module 'weatherforecast' is deprecated in favor of the 'weather'-module, please refer to the documentation for a migration path
                    /home/pi/.pm2/logs/MagicMirror-out.log last 15 lines:
                    0|MagicMir | [26.07.2021 02:06.21.048] [LOG] Connecting socket for: weatherforecast
                    0|MagicMir | [26.07.2021 02:06.21.074] [LOG] Connecting socket for: newsfeed
                    0|MagicMir | [26.07.2021 02:06.21.090] [LOG] Starting node helper for: newsfeed
                    0|MagicMir | [26.07.2021 02:06.21.102] [LOG] Connecting socket for: MMM-cryptocurrency
                    0|MagicMir | [26.07.2021 02:06.21.112] [LOG] Cryptocurrency module loaded!
                    0|MagicMir | [26.07.2021 02:06.21.128] [LOG] Connecting socket for: MMM-MyPrayerTimes
                    0|MagicMir | [26.07.2021 02:06.21.144] [LOG] Starting node_helper for: MMM-MyPrayerTimes
                    0|MagicMir | [26.07.2021 02:06.21.159] [LOG] Connecting socket for: MMM-LICE
                    0|MagicMir | [26.07.2021 02:06.21.174] [LOG] Starting node_helper for: MMM-LICE
                    0|MagicMir | [26.07.2021 02:06.21.187] [LOG] Connecting socket for: MMM-PIR
                    0|MagicMir | [26.07.2021 02:06.21.202] [LOG] Starting module helper: MMM-PIR
                    0|MagicMir | [26.07.2021 02:06.21.211] [LOG] Sockets connected & modules started ...
                    0|MagicMir | [26.07.2021 02:06.21.221] [LOG]
                    0|MagicMir | Ready to go! Please point your browser to: http://0.0.0.0:8080
                    0|MagicMir | Starting chromium browser now, have patience, it takes a minute
                    0|MagicMirror  | [26.07.2021 02:08.03.737] [LOG]
                    0|MagicMirror  | Create new calendarfetcher for url: https://calendar.google.com/calendar/ical/10s0ee0h3tb1ko7fqhpf71sfgs%40group.calendar.google.com/private-d3794e10c136ecfea3ad72fe63078acd/basic.ics - Interval: 300000
                    0|MagicMirror  | [26.07.2021 02:08.05.785] [LOG]
                    0|MagicMirror  | Create new newsfetcher for url: https://www.cnnturk.com/feed/rss/turkiye/news - Interval: 300000
                    0|MagicMirror  | [26.07.2021 02:08.07.210] [LOG]
                    0|MagicMirror  | Create new newsfetcher for url: https://www.birgun.net/xml/rss.xml - Interval: 300000
                    0|MagicMirror  | [26.07.2021 02:08.15.652] [ERROR]
                    0|MagicMirror  | Whoops! There was an uncaught exception...
                    0|MagicMirror  | [26.07.2021 02:08.15.761] [ERROR]
                    0|MagicMirror  | TypeError: $ is not a function
                    0|MagicMirror  |     at Request.request [as _callback] (/home/pi/MagicMirror/modules/MMM-LICE/node_helper.js:27:27)
                    0|MagicMirror  |     at Request.self.callback (/home/pi/MagicMirror/modules/MMM-LICE/node_modules/request/request.js:185:22)
                    0|MagicMirror  |     at Request.emit (events.js:198:13)
                    0|MagicMirror  |     at Request.<anonymous> (/home/pi/MagicMirror/modules/MMM-LICE/node_modules/request/request.js:1154:10)
                    0|MagicMirror  |     at IncomingMessage.<anonymous> (/home/pi/MagicMirror/modules/MMM-LICE/node_modules/request/request.js:1076:12)
                    0|MagicMirror  |     at Object.onceWrapper (events.js:286:20)
                    0|MagicMirror  |     at IncomingMessage.emit (events.js:203:15)
                    0|MagicMirror  |     at endReadableNT (_stream_readable.js:1145:12)
                    0|MagicMirror  |     at process._tickCallback (internal/process/next_tick.js:63:19)
                    0|MagicMirror  | [26.07.2021 02:08.15.803] [ERROR] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                    0|MagicMirror  | [26.07.2021 02:08.15.842] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                      sdetweil @uok825
                      @uok825 did cheerio get installed?
                      cd ~/MagicMirror/modules/MMM-LICE
                      ls node_modules/cheerio
                      • U Offline
                        uok825 @sdetweil
                        pi@raspberrypi:~ $ cd ~/MagicMirror/modules/MMM-LICE
                        pi@raspberrypi:~/MagicMirror/modules/MMM-LICE $ ls node_modules/cheerio
                        LICENSE  lib  package.json  Readme.md
                        • 6
                        • 7
                        • 8
                        • 9
                        • 10
                        • 9 / 10
