    MMM-MirrorMirrorOnTheWall - Alexa voice control to hide/show modules and display text/images
    184 Posts 25 Posters 401.5k Views 23 Watching
    • Z
      zman3
      yes i have those folders in the zip
      • J
        joanaz
        For people struggling with setting up Lambda and Alexa Skill, here’s a good visual instructions for a different Skill. Use your judgment when dealing with differences with my skill.
        https://github.com/alexa/skill-sample-nodejs-calendar-reader
        Here’s Amazon’s instructions for setting up a AWS IoT device, it’ll also be slightly different when you setup your own device, but it’s good enough.
        http://docs.aws.amazon.com/iot/latest/developerguide/iot-console-signin.html
          savage_gr1nd
          So exactly which files need to be in the zip?
          And also, when testing on the lambda site I get an error about alexa-sdk not being detected… are there other steps for installation? I’ve hit a wall
          J 1 Reply Last reply
            savage_gr1nd
            So redid everything. Same thing. When I test with my device and try to invoke it says there was a problem with the requested skills response…
            • J
              joanaz @savage_gr1nd
              @savage_gr1nd you need to include node_modules in the src folder. run ‘npm install’ inside src folder.
                savage_gr1nd
                Yea I did that. Then made the zip. The zip was too large and my page kept crashing so I used s3. Or will that not work?
                  savage_gr1nd
                  And one more thing I’m confused on and it might be why, when putting the path to certs to keys.json is it the FULL path /home etc…?
                  • J
                    @savage_gr1nd the zip shouldn’t be too large, mine was 5.1MB. I’m not sure what you are saying about path to certs and keys.json. have a look of my folder structure
                      savage_gr1nd
                      I figured out the path problem.
                      But every module ever is in my folder. Which are required so I can delete the rest.
                        savage_gr1nd
                        I’m sorry lol
                        More specific in my node_modules folder
                          savage_gr1nd
                          Okay I’m really sorry for bugging.
                          But literally got everything figured out except why my file is too large. I deleted node_modules and redid npm installs on all 4 dependencies. The node folder alone is 69mb…
                          How is yours 5.1mb…?
                          Since mine is so big. The only error I get now in lambda is time out. I just don’t understand why mine is so large.
                            savage_gr1nd @Journeytojah
                            @Journeytojah did you ever get yours to work? That’s about the same error I was getting
                            • J
                              @savage_gr1nd my node_modules is 24.2MB. How are you testing the lambda function? try something simple, like the hello intent first
                                savage_gr1nd @joanaz
                                @joanaz that’s what I was doing.
                                Also testing after uploading the code from the console.
                                After work I want to try npm depues to see if that helps.
                                But I also see you have latest define for the dependencies. What versions do you have installed so I can’t edit my package.json to install those smaller versions?
                                • J
                                  @savage_gr1nd this is my npm list
                                  ├─┬ alexa-sdk@1.0.6
                                  │ ├─┬ aws-sdk@2.9.0
                                  │ │ ├─┬ buffer@4.9.1
                                  │ │ │ ├── base64-js@1.2.0
                                  │ │ │ ├── ieee754@1.1.8
                                  │ │ │ └── isarray@1.0.0
                                  │ │ ├── crypto-browserify@1.0.9
                                  │ │ ├── jmespath@0.15.0
                                  │ │ ├── querystring@0.2.0
                                  │ │ ├── sax@1.1.5
                                  │ │ ├─┬ url@0.10.3
                                  │ │ │ └── punycode@1.3.2
                                  │ │ ├── uuid@3.0.0
                                  │ │ ├── xml2js@0.4.15
                                  │ │ └─┬ xmlbuilder@2.6.2
                                  │ │   └── lodash@3.5.0
                                  │ ├── i18next@3.5.2
                                  │ └── i18next-sprintf-postprocessor@0.2.2
                                  ├─┬ aws-iot-device-sdk@1.0.14
                                  │ ├── crypto-js@3.1.6
                                  │ ├── minimist@1.2.0
                                  │ ├─┬ mqtt@1.11.2
                                  │ │ ├─┬ commist@1.0.0
                                  │ │ │ └── leven@1.0.2
                                  │ │ ├─┬ concat-stream@1.6.0
                                  │ │ │ ├─┬ readable-stream@2.2.2
                                  │ │ │ │ ├── buffer-shims@1.0.0
                                  │ │ │ │ ├── process-nextick-args@1.0.7
                                  │ │ │ │ └── util-deprecate@1.0.2
                                  │ │ │ └── typedarray@0.0.6
                                  │ │ ├─┬ end-of-stream@1.1.0
                                  │ │ │ └─┬ once@1.3.3
                                  │ │ │   └── wrappy@1.0.2
                                  │ │ ├── help-me@0.1.0
                                  │ │ ├── inherits@2.0.3
                                  │ │ ├─┬ mqtt-connection@2.1.1
                                  │ │ │ ├── reduplexer@1.1.0
                                  │ │ │ └── through2@0.6.5
                                  │ │ ├── mqtt-packet@3.4.7
                                  │ │ ├── pump@1.0.2
                                  │ │ ├─┬ readable-stream@1.0.34
                                  │ │ │ ├── core-util-is@1.0.2
                                  │ │ │ ├── isarray@0.0.1
                                  │ │ │ └── string_decoder@0.10.31
                                  │ │ ├── reinterval@1.1.0
                                  │ │ ├─┬ split2@2.1.1
                                  │ │ │ └─┬ through2@2.0.3
                                  │ │ │   └── readable-stream@2.2.2
                                  │ │ └── xtend@4.0.1
                                  │ └─┬ websocket-stream@3.3.3
                                  │   ├─┬ duplexify@3.5.0
                                  │   │ ├── end-of-stream@1.0.0
                                  │   │ ├── readable-stream@2.2.2
                                  │   │ └── stream-shift@1.0.0
                                  │   ├─┬ through2@2.0.3
                                  │   └─┬ ws@1.1.1
                                  │     ├── options@0.0.6
                                  │     └── ultron@1.0.2
                                  ├─┬ google-images@2.0.0
                                  │ └─┬ got@6.7.1
                                  │   ├─┬ create-error-class@3.0.2
                                  │   │ └── capture-stack-trace@1.0.0
                                  │   ├── duplexer3@0.1.4
                                  │   ├── get-stream@3.0.0
                                  │   ├── is-redirect@1.0.0
                                  │   ├── is-retry-allowed@1.1.0
                                  │   ├── is-stream@1.1.0
                                  │   ├── lowercase-keys@1.0.0
                                  │   ├── safe-buffer@5.0.1
                                  │   ├── timed-out@4.0.0
                                  │   ├── unzip-response@2.0.1
                                  │   └─┬ url-parse-lax@1.0.0
                                  │     └── prepend-http@1.0.4
                                  └─┬ youtube-node@1.3.0
                                    ├── colors@1.0.3
                                    ├─┬ prompt@0.2.14
                                    │ ├── pkginfo@0.4.0
                                    │ ├─┬ read@1.0.7
                                    │ │ └── mute-stream@0.0.7
                                    │ ├── revalidator@0.1.8
                                    │ ├─┬ utile@0.2.1
                                    │ │ ├── async@0.2.10
                                    │ │ ├── deep-equal@1.0.1
                                    │ │ ├── i@0.3.5
                                    │ │ ├─┬ mkdirp@0.5.1
                                    │ │ │ └── minimist@0.0.8
                                    │ │ ├── ncp@0.4.2
                                    │ │ └─┬ rimraf@2.5.4
                                    │ │   └─┬ glob@7.1.1
                                    │ │     ├── fs.realpath@1.0.0
                                    │ │     ├── inflight@1.0.6
                                    │ │     ├─┬ minimatch@3.0.3
                                    │ │     │ └─┬ brace-expansion@1.1.6
                                    │ │     │   ├── balanced-match@0.4.2
                                    │ │     │   └── concat-map@0.0.1
                                    │ │     └── path-is-absolute@1.0.1
                                    │ └─┬ winston@0.8.3
                                    │   ├── colors@0.6.2
                                    │   ├── cycle@1.0.3
                                    │   ├── eyes@0.1.8
                                    │   ├── pkginfo@0.3.1
                                    │   └── stack-trace@0.0.9
                                    └─┬ request@2.53.0
                                      ├── aws-sign2@0.5.0
                                      ├── bl@0.9.5
                                      ├── caseless@0.9.0
                                      ├─┬ combined-stream@0.0.7
                                      │ └── delayed-stream@0.0.5
                                      ├── forever-agent@0.5.2
                                      ├─┬ form-data@0.2.0
                                      │ └── async@0.9.2
                                      ├─┬ hawk@2.3.1
                                      │ ├── boom@2.10.1
                                      │ ├── cryptiles@2.0.5
                                      │ ├── hoek@2.16.3
                                      │ └── sntp@1.0.9
                                      ├─┬ http-signature@0.10.1
                                      │ ├── asn1@0.1.11
                                      │ ├── assert-plus@0.1.5
                                      │ └── ctype@0.5.3
                                      ├── isstream@0.1.2
                                      ├── json-stringify-safe@5.0.1
                                      ├─┬ mime-types@2.0.14
                                      │ └── mime-db@1.12.0
                                      ├── node-uuid@1.4.7
                                      ├── oauth-sign@0.6.0
                                      ├── qs@2.3.3
                                      ├── stringstream@0.0.5
                                      ├─┬ tough-cookie@2.3.2
                                      │ └── punycode@1.4.1
                                      └── tunnel-agent@0.4.3
                                    @joanaz awesome!
                                    I’m sure between the two methods I can shrink it down enough. At least I hope i can haha
                                    I’m way too excited to get this running and play with it. Thank you!
                                    • J
                                      @savage_gr1nd yeah, i was really excited when i got it working. :) let me know when you do!
                                      S 3 Replies Last reply
                                        @joanaz it’s seriously been 3 days after work. Of playing with code for 7 hours each day. It’s kicking my ass but I’ll get it lol
                                          @joanaz so I was thinking, the mirrormirror module, can it be configured to play “next up” in the YouTube api? Instead of loop? :/
                                            @joanaz okay. Finally. Got a response. Now. The mmm.
                                            Everytime I touch the config.js doesn’t load up. Can you give me a few more details for setting up the module?
                                            IE. Where to run npm install for aws-iot-device-sdk lol
                                            • 6
                                            • 9
                                            • 10
                                            • 4 / 10
