    Weather module not updating hourly
    3 Posts 2 Posters 722 Views 1 Watching
      R0211
      I have 3 calls to the default weather module (current, hourly, and forecast) using openweathermap as the provider.
      Everything had been working fine, but today I noticed that the hourly forecast was not correct. Im not sure how long it has been broken, the time updates, but the temperature does not.
      The other 2 calls are working perfectly, and I have not messed with the configs for hourly.
      I have restarted MM and the pi itself, with the same result.
      • mumblebajM Offline
        mumblebaj Module Developer @R0211
        @r0211 Hi. Not sure if this will help but I noticed this on the site for the weather module:
        The hourly type is currently only implemented for:
        Environment Canada (envcanada) provider
        OpenWeatherMap provider, and only when /onecall is used as the specified endpoint.
        See the below link
        Weather Module
          R0211 @mumblebaj
          @mumblebaj But like… It was working before? for 2 weeks or so?
