    How to Remove old Module
    5 Posts 2 Posters 20.9k Views 2 Watching
    • N Offline
      nobita
      Because when I use command git pull for update module,something wrong for my config
      and can not update. so I have to remove old module and use git clone for new version
      Thanks for all your help
      • morozgrafixM Offline
        morozgrafix Moderator @nobita
        @nobita not the entire directory, but rather directory that contains your module inside of MagicMirror/modules
        For example if you have MagicMirror/modules/module_to_delete
        You would do:
        cd ~/MagicMirror
        rm -rf modules/module_to_delete
        N 1 Reply Last reply Reply Quote 1
          General suggestion on that would be:
          1. backup your config.js file
          2. Remove that module entry from config.js
          3. Remove directory for that module under MagicMirror/modules
          • N Offline
            nobita @morozgrafix
            @morozgrafix you mean delete MagicMirror/modules Folder?
            morozgrafixM 1 Reply Last reply Reply Quote 0
              You would do:
              cd ~/MagicMirror
              • N Offline
                nobita @morozgrafix
                @morozgraf I see, Thanks again for your help
