    MMM-Strava stopped updating
    19 Posts 5 Posters 4.2k Views 5 Watching
    • L Offline
      levon
      Earlier this summer it was working great, but it stopped updating in the last few weeks for some reason. Anyone else have run into this?
      I see this message during start up, but being new to this, I’m not quite sure what to make of this
      [31.07.2021 14:37.41.518] [LOG]   Initializing new module helper ...
      [31.07.2021 14:37.41.519] [LOG]   Check MagicMirror version for node helper 'MMM-Strava' - Minimum version: 2.2.0 - Current version:
       2.16.0
      [31.07.2021 14:37.41.521] [LOG]   Version is ok!
      [31.07.2021 14:37.41.522] [LOG]   Module helper loaded: MMM-Strava
      On the one hand it seems to say that the version (of MM?) isn’t high enough, but then the next message says “Version is ok!” - this is a bit confusing. Plus I thought the current version of MM is 2.16, so how can version 2.2 be a requirement?
      Can anyone give me some suggestions as to how to fix this? I checked with the remote module and everything seems up-to-date. Thanks!
      • mumblebajM Offline
        mumblebaj Module Developer @levon
        @levon That message just says that the module will not work on an older version of the mirror. It is not an error. Are there any other errors in NPM? Can you check the developer window for any errors, Do a Ctrl + i which should open the developer window. MMM-Strava seems to be working fine for me.
        L 1 Reply Last reply Reply Quote 1
        • L Offline
          levon @mumblebaj
          @mumblebaj I appreciate your message. These are the startup messages I get:
          pi@io:~/MagicMirror $ cat nohup.out
          > magicmirror@2.16.0 start /home/pi/MagicMirror
          [10.08.2021 13:51.56.316] [LOG]   Starting MagicMirror: v2.16.0
          [10.08.2021 13:51.56.326] [LOG]   Loading config ...
          [10.08.2021 13:51.56.341] [LOG]   Loading module helpers ...
          [10.08.2021 13:51.56.345] [LOG]   No helper found for module: alert.
          [10.08.2021 13:51.56.714] [LOG]   Initializing new module helper ...
          [10.08.2021 13:51.56.716] [LOG]   Module helper loaded: updatenotification
          [10.08.2021 13:51.56.718] [LOG]   No helper found for module: clock.
          [10.08.2021 13:51.56.719] [LOG]   No helper found for module: weather.
          [10.08.2021 13:51.57.409] [LOG]   Initializing new module helper ...
          [10.08.2021 13:51.57.410] [LOG]   Module helper loaded: MMM-Pollen
          [10.08.2021 13:51.57.414] [LOG]   Initializing new module helper ...
          [10.08.2021 13:51.57.415] [LOG]   Module helper loaded: MMM-MoonPhase
          [10.08.2021 13:51.57.473] [LOG]   Initializing new module helper ...
          [10.08.2021 13:51.57.474] [LOG]   Module helper loaded: newsfeed
          [10.08.2021 13:51.58.561] [LOG]   Initializing new module helper ...
          [10.08.2021 13:51.58.563] [LOG]   Check MagicMirror version for node helper 'MMM-Strava' - Minimum version: 2.2.0 - Current version: 2.16.0
          [10.08.2021 13:51.58.565] [LOG]   Version is ok!
          [10.08.2021 13:51.58.567] [LOG]   Module helper loaded: MMM-Strava
          [10.08.2021 13:51.58.971] [LOG]   Initializing new module helper ...
          [10.08.2021 13:51.58.978] [LOG]   Module helper loaded: MMM-Remote-Control
          [10.08.2021 13:51.58.979] [LOG]   All module helpers loaded.
          [10.08.2021 13:51.59.145] [LOG]   Starting server on port 8080 ...
          [10.08.2021 13:51.59.165] [LOG]   Server started ...
          [10.08.2021 13:51.59.166] [LOG]   Connecting socket for: updatenotification
          [10.08.2021 13:51.59.168] [LOG]   Connecting socket for: MMM-Pollen
          [10.08.2021 13:51.59.169] [LOG]   MMM-Pollen helper started ...
          [10.08.2021 13:51.59.170] [LOG]   Connecting socket for: MMM-MoonPhase
          [10.08.2021 13:51.59.171] [LOG]   Starting module helper: MMM-MoonPhase
          [10.08.2021 13:51.59.172] [LOG]   Connecting socket for: newsfeed
          [10.08.2021 13:51.59.173] [LOG]   Starting node helper for: newsfeed
          [10.08.2021 13:51.59.174] [LOG]   Connecting socket for: MMM-Strava
          [10.08.2021 13:51.59.176] [LOG]   Starting module helper: MMM-Strava
          [10.08.2021 13:51.59.177] [LOG]   Connecting socket for: MMM-Remote-Control
          [10.08.2021 13:51.59.179] [LOG]   Starting node helper for: MMM-Remote-Control
          [10.08.2021 13:51.59.192] [LOG]   Sockets connected & modules started ...
          [10.08.2021 13:51.59.651] [LOG]   Launching application.
          [10.08.2021 13:52.05.159] [LOG]   Create new newsfetcher for url: https://rss.nytimes.com/services/xml/rss/nyt/HomePage.xml - Interval: 300000
          [10.08.2021 13:52.05.176] [LOG]   Create new newsfetcher for url: http://rss.cnn.com/rss/cnn_topstories.rss - Interval: 300000
          [10.08.2021 13:52.05.185] [LOG]   Create new newsfetcher for url: http://feeds.bbci.co.uk/news/world/rss.xml - Interval: 300000
          [10.08.2021 13:52.05.189] [LOG]   Create new newsfetcher for url: https://feeds.npr.org/1001/rss.xml - Interval: 300000
          [10.08.2021 13:52.05.195] [LOG]   Create new newsfetcher for url: http://feeds.washingtonpost.com/rss/world - Interval: 300000
          [10.08.2021 13:52.05.199] [LOG]   Create new newsfetcher for url: https://www.latimes.com/local/rss2.0.xml - Interval: 300000
          [10.08.2021 13:52.05.272] [INFO]  Checking git for module: MMM-Pollen
          [10.08.2021 13:52.05.383] [INFO]  Checking git for module: MMM-MoonPhase
          [10.08.2021 13:52.05.443] [INFO]  Checking git for module: MMM-Strava
          [10.08.2021 13:52.05.805] [INFO]  Checking git for module: MMM-Remote-Control
          [10.08.2021 13:52.05.854] [INFO]  Newsfeed-Fetcher: Broadcasting 23 items.
          [10.08.2021 13:52.07.468] [INFO]  Newsfeed-Fetcher: Broadcasting 15 items.
          [10.08.2021 13:52.07.656] [INFO]  Newsfeed-Fetcher: Broadcasting 25 items.
          [10.08.2021 13:52.07.870] [INFO]  Newsfeed-Fetcher: Broadcasting 9 items.
          [10.08.2021 13:52.08.590] [INFO]  Newsfeed-Fetcher: Broadcasting 100 items.
          [10.08.2021 13:52.08.644] [INFO]  Newsfeed-Fetcher: Broadcasting 51 items.
          In the developer window I get three warning and three erorrs:
          VM74 renderer_init.js:111 Electron Security Warning (Insecure Resources) This renderer process loads resources using insecure
            protocols. This exposes users of this app to unnecessary security risks.
            Consider loading the following resources over HTTPS or FTPS.
          - http://0.0.0.0:8080/css/main.css
          - http://0.0.0.0:8080/fonts/roboto.css
          - http://0.0.0.0:8080/socket.io/socket.io.js
          - http://0.0.0.0:8080/vendor/node_modules/nunjucks/browser/nunjucks.min.js
          - http://0.0.0.0:8080/js/defaults.js
          - http://0.0.0.0:8080/config/config.js
          - http://0.0.0.0:8080/vendor/vendor.js
          - http://0.0.0.0:8080/modules/default/defaultmodules.js
          - http://0.0.0.0:8080/js/logger.js
          - http://0.0.0.0:8080/translations/translations.js
          - http://0.0.0.0:8080/js/translator.js
          - http://0.0.0.0:8080/js/class.js
          - http://0.0.0.0:8080/js/module.js
          - http://0.0.0.0:8080/js/loader.js
          - http://0.0.0.0:8080/js/socketclient.js
          - http://0.0.0.0:8080/js/main.js
          - http://0.0.0.0:8080/fonts/node_modules/roboto-fontface/fonts/roboto-condensed/Roboto-Condensed-Regular.woff2
          - http://0.0.0.0:8080/translations/en.json
          - http://0.0.0.0:8080/modules/default/alert/alert.js
          - http://0.0.0.0:8080/modules/default/alert/notificationFx.js
          - http://0.0.0.0:8080/modules/default/alert/notificationFx.css
          - http://0.0.0.0:8080/vendor/css/font-awesome.css
          - http://0.0.0.0:8080/vendor/node_modules/@fortawesome/fontawesome-free/css/all.min.css
          - http://0.0.0.0:8080/vendor/node_modules/@fortawesome/fontawesome-free/css/v4-shims.min.css
          For more information and help, consult
          https://electronjs.org/docs/tutorial/security.
          This warning will not show up
          once the app is packaged.
          VM74 renderer_init.js:111 Electron Security Warning (enableRemoteModule) This renderer process has "enableRemoteModule" enabled
              and attempted to load remote content from 'http://0.0.0.0:8080/'. This
          VM74 renderer_init.js:111 Electron Security Warning (Insecure Content-Security-Policy) This renderer process has either no Content Security
              Policy set or a policy with "unsafe-eval" enabled. This exposes users of
          loader.js:164
          and the errors are:
          Load stylesheet: css/custom.css
          (index):1 Refused to apply style from 'http://0.0.0.0:8080/css/custom.css' because its MIME type ('text/html') is not a supported stylesheet MIME type, and strict MIME checking is enabled.
          loader.js:214 Error on loading stylesheet: css/custom.css
          stylesheet.onerror @ loader.js:214
          None of this seems related to the Strava module as I can see, but again, my knowledge with this software is limited.
          I have a small Python program that can access and display the output from the Strava API, so I know the correct information is up there and accessible/updated, it just stopped being reflected in the module/display here for some reason.
            sdetweil @levon
            @levon css/custom.css is because the file doesn’t exist by default…
            my installer creates an empty file, because many users don’t know how to create a file on linux…
            • L Offline
              levon @sdetweil
              @sdetweil said in MMM-Strava stopped updating:
              @levon css/custom.css is because he file doesn’t exist by default…
              Ah, super helpful, I did
              touch custom.css
              in the css directory and those errors went away. Thanks! Now if I can only figure out the rest :)
                sdetweil @levon
                @levon it appears the module doesn’t log much…
                karsten13K 1 Reply Last reply Reply Quote 1
                • karsten13K Offline
                  karsten13 @sdetweil
                  debug must be set in the config to get more logs …
                  • L Offline
                    levon @karsten13
                    @karsten13 Thanks … so I added “DEBUG” to this list, that should do it right?
                    logLevel: ["INFO", "LOG", "WARN", "ERROR", "DEBUG"], // Add "DEBUG" for even more logging
                    Doesn’t seem to show much more than before though, just LOG and INFO as before … I’ll read up to see if there’s something else I need to do to trace that module in the meantime.
                      sdetweil @levon
                      @levon said in MMM-Strava stopped updating:
                      no… that is different… you will get a lot of calendar module debug
                      for normal modules
                             debug: true,
                      • L Offline
                        levon @sdetweil
                        @sdetweil Thanks for the info. I now get these additional informative messages, but it all looks right, though it doesn’t update the information.
                        10.08.2021 16:20.18.805] [LOG]   MMM-Strava: "Getting data for module_8_MMM-Strava"
                        [10.08.2021 16:20.18.819] [LOG]   MMM-Strava: "Getting athlete activities for module_8_MMM-Strava after 2021-01-01"
                        [10.08.2021 16:20.18.845] [INFO]  Checking git for module: MMM-Pollen
                        [10.08.2021 16:20.18.970] [INFO]  Checking git for module: MMM-MoonPhase
                        [10.08.2021 16:20.19.063] [INFO]  Checking git for module: MMM-Strava
                        [10.08.2021 16:20.19.644] [INFO]  Checking git for module: MMM-Remote-Control
                        [10.08.2021 16:20.20.433] [INFO]  Newsfeed-Fetcher: Broadcasting 24 items.
                        [10.08.2021 16:20.20.850] [INFO]  Newsfeed-Fetcher: Broadcasting 15 items.
                        [10.08.2021 16:20.21.204] [INFO]  Newsfeed-Fetcher: Broadcasting 27 items.
                        [10.08.2021 16:20.21.750] [INFO]  Newsfeed-Fetcher: Broadcasting 9 items.
                        [10.08.2021 16:20.22.632] [LOG]   MMM-Strava: "Summarising athlete activities for module_8_MMM-Strava"
                        [10.08.2021 16:20.22.925] [INFO]  Newsfeed-Fetcher: Broadcasting 100 items.
                        [10.08.2021 16:20.23.000] [INFO]  Newsfeed-Fetcher: Broadcasting 52 items.
                        [10.08.2021 16:25.20.708] [INFO]  Newsfeed-Fetcher: Broadcasting 24 items.
                        [10.08.2021 16:25.21.232] [INFO]  Newsfeed-Fetcher: Broadcasting 15 items.
                        [10.08.2021 16:25.22.021] [INFO]  Newsfeed-Fetcher: Broadcasting 26 items.
                        [10.08.2021 16:25.22.197] [INFO]  Newsfeed-Fetcher: Broadcasting 9 items.
                        [10.08.2021 16:25.23.983] [INFO]  Newsfeed-Fetcher: Broadcasting 100 items.
                        [10.08.2021 16:25.24.292] [INFO]  Newsfeed-Fetcher: Broadcasting 52 items.
                        [10.08.2021 16:30.18.841] [LOG]   MMM-Strava: "Getting data for module_8_MMM-Strava"
                        [10.08.2021 16:30.18.844] [LOG]   MMM-Strava: "Getting athlete activities for module_8_MMM-Strava after 2021-01-01"
                        [10.08.2021 16:30.20.841] [INFO]  Newsfeed-Fetcher: Broadcasting 24 items.
                        [10.08.2021 16:30.21.431] [INFO]  Newsfeed-Fetcher: Broadcasting 15 items.
                        [10.08.2021 16:30.21.558] [LOG]   MMM-Strava: "Summarising athlete activities for module_8_MMM-Strava"
                        For instance here’s the output of a Python program that uses the same API/credentials
                        [16:21 991] $ python strava_info.py
                        Expired token ..
                        Retriving information from year 2021 and onward.
                        .Done.
                        API requests/pages: 2   records read: 235
                        Saving to file "strava_activities_final.csv"
                        Since 2021
                        # of runs : 136    total distance:  653.18 miles
                        # of walks:  97    total distance:  232.63 miles
                        # of other:   2    total distance:    3.62 miles
                        Total #   : 235    total distance:  889.44 miles
                        [16:21 992] $
                        The MM module has been stuck for a few weeks with these values
                          @levon Hi. Apologies for the late replies. Time difference. Can you check when last the tokens.js file was touched? That file is updated every time it does a call out to get data. Else I would suggest maybe just doing a git pull and npm install in the MMM-Strava folder. From the above replies I can’t see anything else that could be going wrong though.
                          L 2 Replies Last reply Reply Quote 1
                          • L Offline
                            levon @mumblebaj
                            @mumblebaj No apologies needed at all - I appreciate all the info/suggestions.
                            Looks like the file is up-to-date, though the file was last touched about 30 minutes ago, in the config file it says to be updated every 10 minutes, so perhaps that’s a bit odd?
                            pi@io:~/MagicMirror/modules/MMM-Strava $ ls -lrts
                            total 256
                             24 -rw-r--r--  1 pi pi  23415 Jun  3 07:09 README.md
                             16 -rw-r--r--  1 pi pi  15048 Jun  3 07:09 node_helper.js
                             12 -rw-r--r--  1 pi pi  12257 Jun  3 07:09 MMM-Strava.js
                              8 -rw-r--r--  1 pi pi   6408 Jun  3 07:09 MMM-Strava.css
                              4 -rw-r--r--  1 pi pi   1099 Jun  3 07:09 LICENSE
                              4 drwxr-xr-x  2 pi pi   4096 Jun  3 07:09 tests/
                              4 drwxr-xr-x  2 pi pi   4096 Jun  3 07:09 templates/
                              4 drwxr-xr-x  4 pi pi   4096 Jun  3 07:09 public/
                              4 -rw-r--r--  1 pi pi   1604 Jun  3 07:09 package.json
                              4 drwxr-xr-x  2 pi pi   4096 Jun  3 07:09 translations/
                              4 drwxr-xr-x 57 pi pi   4096 Jun  3 07:10 node_modules/
                            164 -rw-r--r--  1 pi pi 166945 Jul 28 14:02 package-lock.json
                              4 -rw-r--r--  1 pi pi   1034 Aug 11 15:40 tokens.json
                            • L Offline
                              levon @mumblebaj
                              @mumblebaj Ok, so I did this:
                              pi@io:~/MagicMirror/modules/MMM-Strava $ git pull && npm install
                              From https://github.com/ianperrin/MMM-Strava
                               * [new branch]      dependabot/npm_and_yarn/path-parse-1.0.7 -> origin/dependabot/npm_and_yarn/path-parse-1.0.7
                              Already up to date.
                              npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/fsevents):
                              npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
                              added 380 packages from 277 contributors and audited 435 packages in 42s
                              75 packages are looking for funding
                                run `npm fund` for details
                              found 13 vulnerabilities (12 moderate, 1 high)
                                run `npm audit fix` to fix them, or `npm audit` for details
                              I didn’t run any of the fixes, I looked at audit, but didn’t see anything that seemed related to Strava.
                              Should I be concerned that the package-lock.json time stamp is different from the other June 3 files when I initially installed this? In all other modules the file stamps have the same values.
                              The log seems to show this module working ok, trying to get data every 5 minutes (I made it shorter for testing) though the timestamp on the tokens.json file hasn’t changed from 15:40 today, now it’s over 2 hours since then.
                              pi@io:~/MagicMirror $ grep Strava nohup.out
                              [11.08.2021 16:46.44.905] [LOG]   Check MagicMirror version for node helper 'MMM-Strava' - Minimum version: 2.2.0 - Current version: 2.16.0
                              [11.08.2021 16:46.44.910] [LOG]   Module helper loaded: MMM-Strava
                              [11.08.2021 16:46.45.936] [LOG]   Connecting socket for: MMM-Strava
                              [11.08.2021 16:46.45.937] [LOG]   Starting module helper: MMM-Strava
                              [11.08.2021 16:46.54.215] [LOG]   MMM-Strava: "Getting data for module_8_MMM-Strava"
                              [11.08.2021 16:46.54.227] [LOG]   MMM-Strava: "Getting athlete activities for module_8_MMM-Strava after 2021-01-01"
                              [11.08.2021 16:46.54.961] [INFO]  Checking git for module: MMM-Strava
                              [11.08.2021 16:46.58.455] [LOG]   MMM-Strava: "Summarising athlete activities for module_8_MMM-Strava"
                              [11.08.2021 16:51.54.275] [LOG]   MMM-Strava: "Getting data for module_8_MMM-Strava"
                              [11.08.2021 16:51.54.279] [LOG]   MMM-Strava: "Getting athlete activities for module_8_MMM-Strava after 2021-01-01"
                              [11.08.2021 16:51.55.648] [LOG]   MMM-Strava: "Summarising athlete activities for module_8_MMM-Strava"
                              I think I’m going to try updating the Strava module again based on the instruction on their github page. If that doesn’t work, perhaps I’ll just try nuking that directory and reinstalling it from scratch.
                              I’m just puzzled it stopped working.
                              S mumblebajM 2 Replies Last reply Reply Quote 0
                                sdetweil @levon
                                @levon npm install updates the package-lock.json file. ( its the record of what is installed under MM)
                                  @levon I think check if it is successfully hitting the API on Strava. Check https://www.strava.com/settings/api.
                                  Also check if the Authorization Callback Domain matches your MM IP.
                                  • L Offline
                                    levon @mumblebaj
                                    @mumblebaj Yes, it is doing that for sure, I had kept an eye on that.
                                    I think I finally tracked down the problem, however I don’t understand why it broke. The problem is with one of the options in the config.js file. I had used mode “chart” successfully since early June (ie for almost 2 months) as it also gave me stats on walks too, but for some reason the updates stopped happening with this mode (rather than the default “table” mode)
                                    If I comment out the mode, or explicitly specify the default mode of “table”, I get the correct stats for runs, but it ignores the walk (as documented, it will only do run, swim, ride in “table” mode)
                                    I think I will open an issue with this.
                                    I appreciate all of your help/suggestions. Perhaps the code author can shed some light on this.
                                      @levon Awesome. Glad you found the issue. The code uses the npm module strava-v3. It looks like the method used does not return walking.
                                      • L Offline
                                        levon @mumblebaj
                                        @mumblebaj Thank again for your help and everyone else. I definitely learned more about the software and how everything is connected. I’m sure that will come in handy down the line.
                                        • I Offline
                                          ianperrin
                                          Hi all, sorry for the delayed response
                                          @levon looking at the screen shot of your stats from the python module, the total number of activities you have logged this year exceeds 200. Whilst the module will continue to work (making api calls and updating the tokens file) only the first 200 activities are summarised in the chart.
                                          There is an issue relating to this bug ion GitHub, but I’ve not had the time to delve deeper.
                                          To confirm, can you set the period to “recent” and confirm the latest activities are included in the chart?
                                          “Live as if you were to die tomorrow. Learn as if you were to live forever.” - Mahatma Gandhi
