    MagicMirror dual monitor configuration
    10 Posts 2 Posters 2.5k Views 2 Watching
    • P
      pastormingle
      I have my mm configured and working great on one monitor. I’ve used pm2 module to auto start for display=:0 but we i’ve tried to get display=:2 to start i get nothing on the second display… I have 2 instances of mm one named mm and the other mm2. i’ve added the following in mm.sh file
      cd ~/MagicMirror
      DISPLAY=:0 npm start
      cd ~/MagicMirror1
      DISPLAY=:4 npm start
      But still only the Display 1 will start… Help please…
      • P
        pastormingle @sdetweil
        @sdetweil freaking genius!.. That worked like a charm… I’ve been beating my head against the wall for 2 days now trying to figure this thing out… Wonderful…
          sdetweil @pastormingle
          @pastormingle the second display is not :2
          it’s all still display :0
          u can adjust the pixel offset for the web page
          by adding
          electronOptions:{ x:1920 },
          to config.js before the modules: entry
          where the 1920 is the pixel width of the 1st display
          • P
            @sdetweil you are saying in my second mm directory in the config file add the electronOptions?
              @pastormingle correct… one displays a x:0 (default)
              and the other displays at x:1920)
              • P
                • P
                  pastormingle @pastormingle
                  @pastormingle Need some help now running two config files for my dual monitor configuration. I have MM directory and a MM1 directory. But it looks like both are reading the same config file… if i go to MM1 and do a DISPLAY=:0 npm start it seem to read the same config files as MM directory. What am i doing wrong here?
                    @pastormingle hm… I do this ALL the time
                    two copies of MM, two config files
                    have to set two different ports too, right?
                    one of 8080 and one on 8090 (thats what I do)
                    • P
                      @sdetweil I’ve been using pm2 to start so not sure how I set up separate ports for that?
                        @pastormingle port is in the config.js
                        also do pm2 status
                        and pm2 info xx
                        where xx is the number
                        to make sure they are starting different scripts…
                        how did u setup the second instance?
                        • P
                          @sdetweil I found it and it’s working great thanks for the help… Now just need to get to start with pm2 and should be good to go…
