    Screen shifts position after page refresh
    4 Posts 3 Posters 882 Views 3 Watching
      jvaittinen
      Hi all,
      I am having a rather mysterious problem.
      When Magic Mirror is started, my screen looks as I thought it would:
      If I do a page refresh (Ctrl-R), then the sceen position is shifted upwards:
      I tried to research this, and it looks like it is the Body-element that is shifted upwards (not 100% shure).
      Looking at the dev-tools, it looks like that all the CSS-files etc. are loaded similarily after start and after page refresh. Doing a forced reload (Ctrl-Shift-R) or disabling cache (in dev-tools) doesn’t help.
      This started to happen after I updated from 2.10.1 to 2.16.0 (big leap, I know, but MMM-spotify did not start without upgrade). I have even tried to use the main.css from my old install, but that did nothing either.
      Any clues what to still investigate or has anybody had similar symptoms?
      Thanks in advance!
        sdetweil @jvaittinen
        @jvaittinen don’t know, but why are u doing refresh? that’s not typical usage
        the mm screen is like the old corkboard. you don’t take everything off to change one area.
        in mm modules are supposed to update themselves
        swvalentiS 1 Reply Last reply Reply Quote 0
        • swvalentiS Offline
          swvalenti Project Sponsor @sdetweil
          Could it be a module causing this behavior. Disable one by one to troubleshoot and see which one could be the culprit?
            jvaittinen @swvalenti
            @swvalenti MMM-Carousel seems to be the culprit. Will have to look at this modules behaviour.
            @sdetweil I am using netatmo-module, which stops updating its data sooner or later. I used MMM-auto-refresh to reload the page and get the netatmo module updating again.
            It looks like there are new forks to this original netatmo-module, so maybe I could try if they are more stable, and page refresh is not needed anymore.
