    How can I ensure I get regular update notifications?
    11 Posts 3 Posters 4.0k Views 3 Watching
      Richard238
      Magic Mirror - long time, no updates I thought, so ran the update script with the apply suffix.
      Without the apply suffix, I was 4130 commits behind!
      Update seems to have worked, version now shows as 2.16.0
      Current Weather not showing though?
      (Seems it needed a bit longer to load, it’s OK now.)
      And how can I ensure I get regular update notifications?
      config is set to get update notifications:
      { module: "updatenotification", position: "top_bar" },
      Thank you.
        sdetweil @Richard238
        @richard238 the module just checks the git remote for mm. ( and same for each active module)
        so, if you were running off a fork, then u wouldn’t see the original
        if u still have the old mm folder do
        git remote -v
          MajorC Project Sponsor @sdetweil
          the same here. I have module: “newsfeed” in the top_bar position and get no notifications on any update.
            sdetweil @MajorC
            @majorc it’s part of the base. so u won’t get individual module updates for default modules
              @sdetweil But I didn’t get a notice when MM changed from v.2.15.0 to v.2.16.0 either.
                sdetweil @MajorC
                @majorc can u do a git remote -v in the MM folder
                  @sdetweil than it is shown:
                  origin  https://github.com/MichMich/MagicMirror.git (fetch)
                  origin  https://github.com/MichMich/MagicMirror.git (push)
                    sdetweil @MajorC
                    @majorc that should watch and provide updates… once every 90 days… next Oct 1.
                      Richard238 @sdetweil
                      Likewise, I also get:
                      And I received no notification of the upgrade to 2.15, or to 2.16.
                      Thank you.
                        @richard238 @MajorC
                        I would post an issue to the MM github issues list.
