    New MM install- Raspberry pi 4 shuts off on its own
    4 Posts 2 Posters 856 Views 2 Watching
    • N Offline
      Nneuland
      I recently had a problem with my pi and decided to start fresh.
      Things are looking well, but my pi is shutting off on it’s own after apx 5 minutes.
      I was remoting via VNC and lost connection and froze the screen.
      Is there a default screensaver that I’m forgetting ?
      Nick
      S N 2 Replies Last reply Reply Quote 0
        sdetweil @Nneuland
        @nneuland there is screen blanking… in the pi preferences.
        how did u install MM? if you used mys script it would have asked if u wanted to disable screen saver
        see https://github.com/sdetweil/MagicMirror_scripts
        • N Offline
          Nneuland @Nneuland
          @nneuland
          Thank you Sam. I used MichMich’s install.
          https://docs.magicmirror.builders/getting-started/installation.html#manual-installation
          Thank you for the script.
            sdetweil @Nneuland
            @nneuland yeh, mine is listed in the ‘alternative’ section below manual
            note that I have a script to disable screensaver down at the bottom too
