    Segment fault MMM-GoogleTTS
    googletts grpc fault
    7 Posts 3 Posters 1.7k Views 3 Watching
      jamesarm
      I have read other messages about doing the node electron rebuild and such and tried all of them. I keep getting a segment fault running the node_grpc binary that is compiled in the TTS node stuff (not at computer to get the exact name), the GRPC bin. I have rebuilt it as suggested and even switched down to gcc-7 from 8 as mentioned also, no luck. This is on a rpi 4b running the latest Raspbian and magicmirrror. Any thought on what else I can try? I can’t be the only person on a pi 4b. I plan on integrating some more google stuff so I need to find a solution somehow.
      -James
      S M 3 Replies Last reply Reply Quote 0
        sdetweil @jamesarm
        @jamesarm the comments on gprc suggest to move the code to @gprc/gprc.js
        it has helped other code I have worked on
        this module hasn’t been updated in a while, so you never know how much work is required to make it work again.
          MMRIZE @jamesarm
          @jamesarm
          I was the original author of it. I’ll look inside tomorrow. I ran away from the my exmodules for personal reasons for a while.
            sdetweil @MMRIZE
            @mmrize we are glad that you are back! your ideas and expertise are wonderful!
              MMRIZE @jamesarm
              @jamesarm
              Hmmm. In my test, there be no issue.
              Anyway, try these steps;
              1. Update and Upgrade your MM to the latest version. If you can, Upgrade Electron and Node also.
              2. Remove MMM-GoogleTTS then reinstall (without electron-rebuild)
              3. Get credentials and config you need.
              4. Try execution.
              5. Is there an error? what kind of? show me.
              6. IF you are doubting electron-rebuild issue, try server only mode. (Still do not electron-rebuild yet)
              7. in server only mode and browser trial, it works?
              8. If it works, now do electron-rebuild process. Is there any error in process?
                jamesarm @MMRIZE
                @mmrize Looks like it is fixed now, from what I can tell it appears the repo has been updated to support grpc.js instead of the deprecated module.
                  MMRIZE @jamesarm
                  @jamesarm
                  Glad to hear it works for you now.
