    Any module I add turns to blank screen.
    29 Posts 2 Posters 8.6k Views 2 Watching
      Socrates @sdetweil
      Let me give you an example of one of the module I am trying to work with. MMM-DynamicWeather
      See the error logs.
      > magicmirror@2.17.1 start /home/pi/MagicMirror
      [25.10.2021 10:06.30.558] [LOG]   Starting MagicMirror: v2.17.1
      [25.10.2021 10:06.30.570] [LOG]   Loading config ...
      [25.10.2021 10:06.30.577] [LOG]   Loading module helpers ...
      [25.10.2021 10:06.30.579] [LOG]   No helper found for module: alert.
      [25.10.2021 10:06.30.595] [LOG]   Initializing new module helper ...
      [25.10.2021 10:06.30.597] [LOG]   Module helper loaded: updatenotification
      [25.10.2021 10:06.30.598] [LOG]   No helper found for module: clock.
      [25.10.2021 10:06.30.753] [LOG]   Initializing new module helper ...
      [25.10.2021 10:06.30.754] [LOG]   Module helper loaded: calendar
      [25.10.2021 10:06.30.755] [LOG]   No helper found for module: compliments.
      [25.10.2021 10:06.30.758] [ERROR] WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module 'request'
      Require stack:
      - /home/pi/MagicMirror/modules/MMM-DynamicWeather/node_helper.js
      /* Magic Mirror Config Sample
       * By Michael Teeuw https://michaelteeuw.nl
       * MIT Licensed.
       * see https://docs.magicmirror.builders/getting-started/configuration.html#general
       * and https://docs.magicmirror.builders/modules/configuration.html
      let config = {
      	address: "localhost", 	// Address to listen on, can be:
      	port: 8555,
      	basePath: "/", 	// The URL path where MagicMirror is hosted. If you are using a Reverse proxy
      	ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1"], 	// Set [] to allow all IP addresses
      	language: "en",
      	locale: "en-US",
      	timeFormat: 24,
      //	units: "metric",
      			module: "alert",
      			module: "updatenotification",
      			position: "top_bar"
      			module: "clock",
      			position: "top_left"
      			header: "iUS Holidays",
      						symbol: "calendar-check",
      						url: "webcal://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics",
      						symbol: "Koshy-Family-Calendar",
      						url: "https://calendar.google.com/calendar/ical/luvology%40gmail.com/public/basic.ics"
      			module: "compliments",
      			position: "lower_third"
      //			module: "weather",
      //			position: "top_right",
      //			config: {
      //				weatherProvider: "openweathermap",
      //				type: "current",
      //				location: "Houston",
      //				units: "imperial",
      //				locationID: "2646507", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
      //				apiKey: "98dbcccba012ef0fd49c86665a0df584"
      //			module: "weatherforecast",
      //			header: "Weather Forecast",
      //			config: {
      //				locationID: '2646507',
      //				app_id: '98dbcccba012ef0fd49c86665a0df584',
      //				units: 'imperial'
      		module: "MMM-DynamicWeather",
      		position: "fullscreen_above",
      		config: { // See https://github.com/scottcl88/MMM-DynamicWeather for more information.
       			api_key: "98dbcccba012ef0fd49c86665a0df584",
       			effects: [
          					month: "10",
          					day: "25",
          					year: "2021",
          					images: ["heart1.png", "heart2.png"],
          					direction: "up"
      			module: "newsfeed",
      			position: "bottom_bar",
      				feeds: [
      						title: "CNN News",
      						url: "http://rss.cnn.com/rss/cnn_world.rss"
      				showSourceTitle: true,
      				showPublishDate: true,
      				broadcastNewsFeeds: true,
      				broadcastNewsUpdates: true
        Socrates
        More troubleshooting logs as per the link provided in this post.
        pi@raspberrypi:~/MagicMirror/modules/MMM-Dynamic-Modules $ npm install request
        npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
        npm WARN deprecated har-validator@5.1.5: this library is no longer supported
        npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
        + request@2.88.2
        updated 1 package and audited 48 packages in 2.163s
        found 0 vulnerabilities
        pi@raspberrypi:~/MagicMirror/modules/MMM-Dynamic-Modules $ npm install uuid
        + uuid@8.3.2
        added 1 package from 5 contributors, updated 1 package and audited 49 packages in 1.85s
        2 packages are looking for funding
          run `npm fund` for details
        pi@raspberrypi:~/MagicMirror/modules/MMM-Dynamic-Modules $ npm fund
        MMM-Dynamic-Modules@1.0.0
        ├─┬ https://github.com/sponsors/feross
        │ └── safe-buffer@5.2.1
        ├─┬ https://www.patreon.com/feross
        ├─┬ https://feross.org/support
        └─┬ https://github.com/sponsors/epoberezkin
          └── ajv@6.12.6
          sdetweil @Socrates
          @socrates said in Any module I add turns to blank screen.:
          Cannot find module ‘request’
          see the link I gave you in my 1st reply
          but looks like u are moving in the right direction
            Socrates @sdetweil
            @sdetweil thanks see my third post , i have the logs uploaded when i tried to install request using
            npm install request
            and then it shows three more packages that are depreciated.
            Not able to install none of those.
            S S 2 Replies Last reply Reply Quote 0
              sdetweil @Socrates
              don’t worry about that… one step at a time…
              don’t do npm fund unless u want to contribute money to other developers (outside MM)
                Socrates @Socrates
                Do u think i should install MM some other way? I cannot think of anything else.
                  sdetweil @Socrates
                  @socrates well, i would start with one module at a time…
                  save the current config.js
                  copy the config.js.sample to config.js
                  confirm MM runs
                  add one module
                  resolve any missing dependencies
                  i don’t THINK u need to resinstall, but if u want to
                  then use my install script… see
                  it doesn’t look like config.js editing is the problem, but if so, try my MMM-Config module which generates a form for config , see
                  https://github.com/sdetweil/MMM-Config
                  but missing libs are a pain in the rear… just no way to know when it will hit
                  note that the instructions link I posted will load ‘request’ or any other missing lib
                  IN THE MODULE folder
                  so, if u find ANOTHER module with the same problem, then u have to load it THERE TOO
                  over and over
                  you can do it in the MM folder instead, BUT… be warned… if you do an upgrade, the libs will be tossed as they are not referenced by the base, and are considered a security risk (in NPM, not the MM code) so, you could get to do it all over again, …
                  (I am considering making a change to my upgrade script to try and detect this… not sure yet)
                    Socrates @sdetweil
                    @sdetweil Thanks i am gonna follow these steps and let you know.
                    I am literally installing one module at a time, but none of the 3rd party module works. Even if i try to edit the inbuilt module that MM came with for eg:- the calendar, i try to add my own google calendar, it wont work. (meaning my calendar wont show up).
                    Do u have recommendations of which modules i can initially start with so that all the basic pre-requisite libraries get installed?
                      sdetweil @Socrates
                      @socrates the defaults ones work pretty reliably…
                      for mail, the url for the cal ics lnk should download the ics file when used in a browser…
                      that is what the cal modules uses
                      what modules have u been trying over than default?
                        Socrates @sdetweil
                        I have tried todoist, the calander ext2 module, dynamic weather module, several others. I think i might have an installation issue… I will just reformat my card and re-install using your script.
                        So after i install rpi, do i run ur script in terminal, and follow the prompts?
                        • 3 / 3
