    Any module I add turns to blank screen.
    29 Posts 2 Posters 10.8k Views 2 Watching
      sdetweil @Socrates
      @socrates said in Any module I add turns to blank screen.:
      do i run ur script in terminal, and follow the prompts?
      yes, just copy paste the one line for install in a terminal window
        Socrates @sdetweil
        So i have installed mm using your script, and i am up and running, havent installed the modules yet, but that is because i am not able to shutdown mm using pm2 command, mm has been started using pm2 via your script.
        None of these commands work
        pm2 restart mm
        pm2 stop mm
          sdetweil @Socrates
          pm2 stop mm
          cause its not called mm…
          pm2 status
          will show u the name , you can also use the number
          or all to stop everything
            Socrates
            @sdetweil Dear Sir, you are a genius, i finally got it working. Surely it was an install issue. Using your installation script, and in the past 2 hours i have already inculcated 4 third party modules, and all seems to be working. I might have a question or two later tomorrow when i make more progress, but for now, the main issue is resolved.
              Socrates
              So everything is working out great for me, i have added some great modules, and in the processing of adding more.
              The only one thing i am not able to figure out is the measure of unit for the weather.
              I am in the US, in texas, and even if i use the imperial unit it wont show it correctly and the weather is totally off.
                                      module: "MMM-Weather",
                                      header: "Weather Forecast - Katy, TX",
                                      configDeepMerge: true,
                                      debug: false,
                                      updateInterval: "15m", // 15 minutes
                                      updateFadeSpeed: 500,
                                      api: {
                                        key: "98dbcccba012ef0fd49c86665a0df584",
                                        latitude: "29.71490",
                                        longitude: "95.83688",
                                        units: "imperial"
                                      display: {
                                        CurrentConditions: true,
                                        ExtraCurrentConditions: true,
                                        Summary: true,
                                        ForecastTableColumnHeaderIcons: true,
                                        HourlyForecast: true,
                                        DailyForecast: true,
                                        Precipitation: true,
                                        Wind: true,
                                        InlineIcons: true,
                                        Feels: true,
                                        SunCondition: true,
                                        Humidity: true,
                                        UV: true,
                                        Beaufort: true
                                      personalize: {
                                        hourlyForecastInterval: 3,
                                        maxHourliesToShow: 3,
                                        maxDailiesToShow: 3,
                                        concise: false,
                                        colored : true,
                                        forecastLayout: "table",
                                        forecastHeaderText: ""
                                      labels: {
                                      high: "H",
                                      low: "L",
                                      timeFormat: "kk[h]"
              Have a look a this code.. and the partial screenshot of my magic mirror through vnc viewer
                Socrates
                alt text
                  sdetweil @Socrates
                  we are west of england, so longitude should be negative (right?)… I am in texas too,
                  so, if u fix that and leave units off, it will take from the top of config
                    Socrates @sdetweil
                    Gosh, my parcel got delivered in Europe… :beaming_face_with_smiling_eyes:
                    The dashboard is starting to take shape.
                    alt text
                    A few more important modules and i am set.
                      sdetweil @Socrates
                      more like central China!
                        Socrates @sdetweil
                        hahaha
                          sdetweil @Socrates
                          @socrates easy, maps.google.com, get the map of your location, in the url, delete the minus sign on longitude, and press enter
                          it will map that location… zoom out til u figure out where that is
                            Socrates
                            Thank you for your help. I have successfully managed to add quite a bit of useful modules as per my requirements, and have added styling to the fonts etc.
                            However there are two things I am unable to get around.
                            First is the wallpaper module.
                            If i use the default bing option for the source, it wont show more than 10 wallpapers, i have tried to change the “maximumEntries” to 20 or more and it still wont show more than the original 10 wallpapers it loaded the first day (3 days back). Then i tried to change the source to Flickr groups, and it wont show anything now. Please have a look at my code snippet below.
                                                    module: "MMM-Wallpaper",
                                                    position: "fullscreen_below",
                                                    config: { // See "Configuration options" for more information.
                                                    source: "flickr-group:113291043@N05",
                                                    maximumEntries: "20",
                                                    slideInterval: 60 * 1000 // Change slides every minute
                            The second item is, i am not able to increase the calendar items, right now it only shows me 5 or 6 items, i am trying to increase it to 10 and it still show the default items.
                            see below.
                                                    header: "Holidays & Reminders",
        symbol: "calendar-check",
        url: "webcal://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics",
        maximumEntries: 20,
        url: "https://calendar.google.com/calendar/ical/lxxxxxxxxx.ics",
        maximumEntries: 20
                              sdetweil @Socrates
                              @socrates
                              maximumEntries
                              goes outside the calendars list
                                                             maximumEntries: 10,
                              is ALL calendars,. outside the calendars list
                              Calendar configuration options:
                              is per calendar
                                Socrates @sdetweil
                                GOsh thanks that worked.
                                Any idea about the wallpaper part? I would like to inculcate flickr group, but the code snippet wont work.
                                  sdetweil @Socrates
                                  maximumEntries: “20”,
                                  maybe,
                                  numbers should never be in quotes
