    Any module I add turns to blank screen.
    29 Posts 2 Posters 9.2k Views 2 Watching
      Socrates @sdetweil
      So i have installed mm using your script, and i am up and running, havent installed the modules yet, but that is because i am not able to shutdown mm using pm2 command, mm has been started using pm2 via your script.
      None of these commands work
      pm2 restart mm
      pm2 stop mm
        sdetweil @Socrates
        @socrates said in Any module I add turns to blank screen.:
        pm2 stop mm
        cause its not called mm…
        pm2 status
        will show u the name , you can also use the number
        or all to stop everything
          Socrates
          @sdetweil Dear Sir, you are a genius, i finally got it working. Surely it was an install issue. Using your installation script, and in the past 2 hours i have already inculcated 4 third party modules, and all seems to be working. I might have a question or two later tomorrow when i make more progress, but for now, the main issue is resolved.
            Socrates
            So everything is working out great for me, i have added some great modules, and in the processing of adding more.
            The only one thing i am not able to figure out is the measure of unit for the weather.
            I am in the US, in texas, and even if i use the imperial unit it wont show it correctly and the weather is totally off.
                                    module: "MMM-Weather",
                                    header: "Weather Forecast - Katy, TX",
                                    configDeepMerge: true,
                                    debug: false,
                                    updateInterval: "15m", // 15 minutes
                                    updateFadeSpeed: 500,
                                    api: {
                                      key: "98dbcccba012ef0fd49c86665a0df584",
                                      latitude: "29.71490",
                                      longitude: "95.83688",
                                      units: "imperial"
                                    display: {
                                      CurrentConditions: true,
                                      ExtraCurrentConditions: true,
                                      Summary: true,
                                      ForecastTableColumnHeaderIcons: true,
                                      HourlyForecast: true,
                                      DailyForecast: true,
                                      Precipitation: true,
                                      Wind: true,
                                      InlineIcons: true,
                                      Feels: true,
                                      SunCondition: true,
                                      Humidity: true,
                                      UV: true,
                                      Beaufort: true
                                    personalize: {
                                      hourlyForecastInterval: 3,
                                      maxHourliesToShow: 3,
                                      maxDailiesToShow: 3,
                                      concise: false,
                                      colored : true,
                                      forecastLayout: "table",
                                      forecastHeaderText: ""
                                    labels: {
                                    high: "H",
                                    low: "L",
                                    timeFormat: "kk[h]"
            Have a look a this code.. and the partial screenshot of my magic mirror through vnc viewer
              Socrates
              alt text
                sdetweil @Socrates
                we are west of england, so longitude should be negative (right?)… I am in texas too,
                so, if u fix that and leave units off, it will take from the top of config
                  Socrates @sdetweil
                  Gosh, my parcel got delivered in Europe… :beaming_face_with_smiling_eyes:
                  The dashboard is starting to take shape.
                  alt text
                  A few more important modules and i am set.
                    sdetweil @Socrates
                    more like central China!
                      Socrates @sdetweil
                      hahaha
                        sdetweil @Socrates
                        @socrates easy, maps.google.com, get the map of your location, in the url, delete the minus sign on longitude, and press enter
                        it will map that location… zoom out til u figure out where that is
                          Socrates
                          Thank you for your help. I have successfully managed to add quite a bit of useful modules as per my requirements, and have added styling to the fonts etc.
                          However there are two things I am unable to get around.
                          First is the wallpaper module.
                          If i use the default bing option for the source, it wont show more than 10 wallpapers, i have tried to change the “maximumEntries” to 20 or more and it still wont show more than the original 10 wallpapers it loaded the first day (3 days back). Then i tried to change the source to Flickr groups, and it wont show anything now. Please have a look at my code snippet below.
                                                  module: "MMM-Wallpaper",
                                                  position: "fullscreen_below",
                                                  config: { // See "Configuration options" for more information.
                                                  source: "flickr-group:113291043@N05",
                                                  maximumEntries: "20",
                                                  slideInterval: 60 * 1000 // Change slides every minute
                          The second item is, i am not able to increase the calendar items, right now it only shows me 5 or 6 items, i am trying to increase it to 10 and it still show the default items.
                          see below.
                                                  header: "Holidays & Reminders",
        symbol: "calendar-check",
        url: "webcal://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics",
        maximumEntries: 20,
        url: "https://calendar.google.com/calendar/ical/lxxxxxxxxx.ics",
        maximumEntries: 20
                            sdetweil @Socrates
                            @socrates
                            maximumEntries
                            goes outside the calendars list
                                                           maximumEntries: 10,
                            is ALL calendars,. outside the calendars list
                            Calendar configuration options:
                            is per calendar
                              Socrates @sdetweil
                              GOsh thanks that worked.
                              Any idea about the wallpaper part? I would like to inculcate flickr group, but the code snippet wont work.
                                sdetweil @Socrates
                                maximumEntries: “20”,
                                maybe,
                                numbers should never be in quotes
