    Any module I add turns to blank screen.
    29 Posts 2 Posters 10.8k Views 2 Watching
      Socrates
      @sdetweil Dear Sir, you are a genius, i finally got it working. Surely it was an install issue. Using your installation script, and in the past 2 hours i have already inculcated 4 third party modules, and all seems to be working. I might have a question or two later tomorrow when i make more progress, but for now, the main issue is resolved.
        Socrates
        So everything is working out great for me, i have added some great modules, and in the processing of adding more.
        The only one thing i am not able to figure out is the measure of unit for the weather.
        I am in the US, in texas, and even if i use the imperial unit it wont show it correctly and the weather is totally off.
                                module: "MMM-Weather",
                                header: "Weather Forecast - Katy, TX",
                                configDeepMerge: true,
                                debug: false,
                                updateInterval: "15m", // 15 minutes
                                updateFadeSpeed: 500,
                                api: {
                                  key: "98dbcccba012ef0fd49c86665a0df584",
                                  latitude: "29.71490",
                                  longitude: "95.83688",
                                  units: "imperial"
                                display: {
                                  CurrentConditions: true,
                                  ExtraCurrentConditions: true,
                                  Summary: true,
                                  ForecastTableColumnHeaderIcons: true,
                                  HourlyForecast: true,
                                  DailyForecast: true,
                                  Precipitation: true,
                                  Wind: true,
                                  InlineIcons: true,
                                  Feels: true,
                                  SunCondition: true,
                                  Humidity: true,
                                  UV: true,
                                  Beaufort: true
                                personalize: {
                                  hourlyForecastInterval: 3,
                                  maxHourliesToShow: 3,
                                  maxDailiesToShow: 3,
                                  concise: false,
                                  colored : true,
                                  forecastLayout: "table",
                                  forecastHeaderText: ""
                                labels: {
                                high: "H",
                                low: "L",
                                timeFormat: "kk[h]"
        Have a look a this code.. and the partial screenshot of my magic mirror through vnc viewer
          Socrates
          alt text
            sdetweil @Socrates
            @socrates said in Any module I add turns to blank screen.:
            we are west of england, so longitude should be negative (right?)… I am in texas too,
            so, if u fix that and leave units off, it will take from the top of config
              Socrates @sdetweil
              Gosh, my parcel got delivered in Europe… :beaming_face_with_smiling_eyes:
              The dashboard is starting to take shape.
              alt text
              A few more important modules and i am set.
                sdetweil @Socrates
                more like central China!
                  Socrates @sdetweil
                  hahaha
                    sdetweil @Socrates
                    @socrates easy, maps.google.com, get the map of your location, in the url, delete the minus sign on longitude, and press enter
                    it will map that location… zoom out til u figure out where that is
                      Socrates
                      Thank you for your help. I have successfully managed to add quite a bit of useful modules as per my requirements, and have added styling to the fonts etc.
                      However there are two things I am unable to get around.
                      First is the wallpaper module.
                      If i use the default bing option for the source, it wont show more than 10 wallpapers, i have tried to change the “maximumEntries” to 20 or more and it still wont show more than the original 10 wallpapers it loaded the first day (3 days back). Then i tried to change the source to Flickr groups, and it wont show anything now. Please have a look at my code snippet below.
                                              module: "MMM-Wallpaper",
                                              position: "fullscreen_below",
                                              config: { // See "Configuration options" for more information.
                                              source: "flickr-group:113291043@N05",
                                              maximumEntries: "20",
                                              slideInterval: 60 * 1000 // Change slides every minute
                      The second item is, i am not able to increase the calendar items, right now it only shows me 5 or 6 items, i am trying to increase it to 10 and it still show the default items.
                      see below.
                                              header: "Holidays & Reminders",
        symbol: "calendar-check",
        url: "webcal://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics",
        maximumEntries: 20,
        url: "https://calendar.google.com/calendar/ical/lxxxxxxxxx.ics",
        maximumEntries: 20
                        sdetweil @Socrates
                        @socrates
                        maximumEntries
                        goes outside the calendars list
                                                       maximumEntries: 10,
                        is ALL calendars,. outside the calendars list
                        Calendar configuration options:
                        is per calendar
                          Socrates @sdetweil
                          GOsh thanks that worked.
                          Any idea about the wallpaper part? I would like to inculcate flickr group, but the code snippet wont work.
                            sdetweil @Socrates
                            maximumEntries: “20”,
                            maybe,
                            numbers should never be in quotes
