    Additional backslashes (\) being added on module install, module cannot be found
    3 Posts 2 Posters 918 Views 2 Watching
    • L
      LMAC
      I keep getting Module Not Found errors for certain modules. So far it has happened on CalanderWeekly, Calendar EXT and CalendarEXT2. Every other module I have installed works fine. It looks like the path is being injected with an addition backslash which errors out. Any insight?
      I should also add I am running with “node serveronly” command on windows.
      Here is the log:
      [05.11.2021 20:19.01.432] [LOG] Starting MagicMirror: v2.17.1
      [05.11.2021 20:19.01.435] [LOG] Loading config …
      [05.11.2021 20:19.01.439] [LOG] Loading module helpers …
      [05.11.2021 20:19.01.440] [LOG] No helper found for module: alert.
      [05.11.2021 20:19.01.446] [LOG] Initializing new module helper …
      [05.11.2021 20:19.01.447] [LOG] Module helper loaded: updatenotification
      [05.11.2021 20:19.01.447] [LOG] No helper found for module: clock.
      [05.11.2021 20:19.01.448] [LOG] No helper found for module: calendar_monthly.
      [05.11.2021 20:19.01.510] [LOG] Initializing new module helper …
      [05.11.2021 20:19.01.511] [LOG] Module helper loaded: calendar
      [05.11.2021 20:19.01.515] [LOG] Initializing new module helper …
      [05.11.2021 20:19.01.516] [LOG] Module helper loaded: WallberryTheme
      [05.11.2021 20:19.01.516] [LOG] No helper found for module: weather.
      [05.11.2021 20:19.01.521] [ERROR] WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module ‘request’
      Require stack:
      • C:****\MMM\modules\MMM-CalendarExt2\node_helper.js
      • C:****\MMM\js\app.js
      • C:****\MMM\serveronly\index.js
        [05.11.2021 20:19.01.522] [LOG] Loading module helpers …
        [05.11.2021 20:19.01.522] [LOG] No helper found for module: alert.
        [05.11.2021 20:19.01.522] [LOG] Initializing new module helper …
        [05.11.2021 20:19.01.523] [LOG] Module helper loaded: updatenotification
        [05.11.2021 20:19.01.523] [LOG] No helper found for module: clock.
        [05.11.2021 20:19.01.523] [LOG] No helper found for module: calendar_monthly.
        [05.11.2021 20:19.01.524] [LOG] Initializing new module helper …
        [05.11.2021 20:19.01.524] [LOG] Module helper loaded: calendar
        [05.11.2021 20:19.01.525] [LOG] Initializing new module helper …
        [05.11.2021 20:19.01.525] [LOG] Module helper loaded: WallberryTheme
        [05.11.2021 20:19.01.526] [LOG] No helper found for module: weather.
        [05.11.2021 20:19.01.529] [ERROR] Whoops! There was an uncaught exception…
        [05.11.2021 20:19.01.532] [ERROR] Error: Cannot find module ‘request’
        Require stack:
      • C:*\MMM\serveronly\index.js
        at Function.Module._resolveFilename (node:internal/modules/cjs/loader:933:15)
        at Function.Module._resolveFilename (C:*
        \MMM\node_modules\module-alias\index.js:49:29)
        at Function.Module._load (node:internal/modules/cjs/loader:778:27)
        at Module.require (node:internal/modules/cjs/loader:1005:19)
        at require (node:internal/modules/cjs/helpers:102:18)
        at Object. (C:*\MMM\modules\MMM-CalendarExt2\node_helper.js:4:17)
        at Module._compile (node:internal/modules/cjs/loader:1101:14)
        at Object.Module._extensions…js (node:internal/modules/cjs/loader:1153:10)
        at Module.load (node:internal/modules/cjs/loader:981:32)
        at Function.Module._load (node:internal/modules/cjs/loader:822:12) {
        code: ‘MODULE_NOT_FOUND’,
        requireStack: [
        'C:\
        \MMM\modules\MMM-CalendarExt2\node_helper.js’,
        'C:\
        \MMM\js\app.js’,
        'C:\
        *\MMM\serveronly\index.js’
        [05.11.2021 20:19.01.533] [ERROR] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
        [05.11.2021 20:19.01.533] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
      • L
        LMAC @sdetweil
        Did the trick. Thank you!
          sdetweil @LMAC
          @lmac see
          https://forum.magicmirror.builders/topic/15778/fix-for-black-screen-in-2-16-and-later/11
          L 1 Reply Last reply
          • L
            LMAC @sdetweil
