    Does anyone know how to make the iFrame module refresh periodically?
    28 Posts 6 Posters 21.9k Views 6 Watching
    • C Offline
      cnelso24 @strawberry 3.141
      @strawberry-3.141
      Thanks for the suggestion. I wouldn’t know where to start with that though. I tried this module which did not work refresh for me either.
      strawberry 3.141S K 2 Replies Last reply Reply Quote 0
      • strawberry 3.141S Offline
        strawberry 3.141 Project Sponsor Module Developer @cnelso24
        @cnelso24 the problem is probably that there isnt a change detected when updating the dom, try to add a timestamp attribute to the iframe.
        • K Offline
          kevsfastz @cnelso24
          @cnelso24
          I have found a fix for this module which I posted here:
          https://github.com/TheBogueRat/MMM-iFrameReload/issues/2
          Kev
          C 2 Replies Last reply Reply Quote 1
          • C Offline
            cnelso24 @kevsfastz
            @kevsfastz
            Thank you!! I will check it out when I get home.
            • C Offline
              cnelso24 @kevsfastz
              @kevsfastz
              Just got a chance to try this. Works like a charm! Thank you!
              • foxF Offline
                fox
                @kevsfastz is it possible to show simple html content and update periodically?
                • K Offline
                  kevsfastz @fox
                  @fox
                  The simple answer is yes it is possible. What is your goal specifically?
                  foxF 1 Reply Last reply Reply Quote 0
                  • Mitch1138M Offline
                    Mitch1138
                    Many thanks, I have bee looking for a way to do this for some time. I loaded iFrameReload with the following url. It will load, but not update. Any suggestions as to what I am missing?
                    url: “http://tides.tidegraph.com/api/tidegraph.php?bg=black&scale=.8&station=Old Frenchtown Wharf, Elk River, Maryland”,
                    Many thanks
                    • K Offline
                      kevsfastz @Mitch1138
                      @Mitch1138
                      As mentioned above, I have provided a fix or adjustment by adjusting the MMM-IframeReload.js below:
                        Mitch1138
                        My mistake, I thought this was updated in the .git. I added the timestamp as you suggested (iframe.src = this.config.url + new Date().getTime();). The url does update now, but since the url displays the tides at a location embedded in the url, it looks like the timestamp is appended to the location. With this added, it is not a valid location and the tides don’t display.
                        Again, many thanks for your help.
                        • 2 / 3
