    Bullseye
    45 Posts 8 Posters 22.7k Views 9 Watching
      sdetweil @BKeyport
      @bkeyport said in Bullseye:
      Nothing but warnings about depreciated modules
      that we can’t do anything about. not our code
      • AssassinsA Offline
        Assassins
        Dont Update, Bulleyes is so much slow, and it not drive 100% yet.
        Buster work 100%, and much faster
          sdetweil @Assassins
          @assassins on what device? pi4 seems faster
          pi3 seems slower
          AssassinsA 1 Reply Last reply Reply Quote 0
            Assassins @sdetweil
            Both, pi3+ is much slower, and pi4 8gb is a little bit slower, But restart Big time hole time, so i mean Bulleyes is not 100% y’et, But Buster run without trouble on both.
            • BKeyportB Offline
              BKeyport Module Developer @Assassins
              An FYI to the issues within Bullseye. If you’re using OMX, it won’t work by default in Bullseye, and as it’s depreciated, we’re kinda on our own. Basically, They’ve gone through and renamed most of the libraries used by OMX.
              Issue these commands in a sudo session to get OMX to work until you figure out a new video streaming solution:
              cd /usr/lib/arm-linux-gnueabihf
              ln -s libmmal_core.so.0 libmmal_core.so
              ln -s libmmal_util.so.0 libmmal_util.so
              ln -s libmmal_vc_client.so.0 libmmal_vc_client.so
              ln -s libbcm_host.so.0 libbcm_host.so
              ln -s libvcsm.so.0 libvcsm.so
              ln -s libvchiq_arm.so.0 libvchiq_arm.so
              ln -s libvcos.so.0 libvcos.so
              curl -sSfLO 'https://raw.githubusercontent.com/raspberrypi/firmware/master/opt/vc/lib/libbrcmEGL.so'
              curl -sSfLO 'https://raw.githubusercontent.com/raspberrypi/firmware/master/opt/vc/lib/libbrcmGLESv2.so'
              curl -sSfLO 'https://raw.githubusercontent.com/raspberrypi/firmware/master/opt/vc/lib/libopenmaxil.so'
              – B
              • 3 / 3
