    Approach to show message in MM once an RF signal was detected
    1 Posts 1 Posters 974 Views 1 Watching
    • M
      MAF1981
      Hi there,
      I’m looking for an approach to accomplish the following:
      I have some (remote) radio controlled power outlets (on 433 MHz signals). Currently I have 4 of these outlets, so 8 different codes (on /off). I would like to display a message on my MagicMirror once a particular power outlet has been switched on. The message should disappear if the particular power outlet has been switched off again.
      I have a wireless receiver for my Pi up and running and also found a RFSniffer (https://github.com/ninjablocks/433Utils/tree/master/RPi_utils) written in C++ which works fine so far. I can see all codes for each outlet if I switch it on/off by the remote control.
      Now I’m struggling with the implementation in my module for MM. I understand that I have to use the node_helper.js somehow to receive notifications. But I only found a way to get results of Python scripts back to the node_helper. I don’t find a RFSniffer tool written in Python.
      Question 1: Is there any Python RFSniffer available?
      Question 2: How can I get the result from the C++ Sniffer to the node_helper.js to evaluate it in my module? Is there a way without having a Python script inbetween? If not, is there any tutorial or similar code available that I can use as template to solve my requirement?
      Thanks in advance!
      MAF1981
