    Losing display output after 5 minutes
    14 Posts 3 Posters 5.4k Views 3 Watching
    • D
      danjvd
      I’m have been running into a issue over that past week, were the HDMI connection will drop and the TV will stop displaying. I have check TV setting for a sleep mode, changed out Raspberry Pi’s, updates, and replaced the micro card. I do have the background changing ever 60 sec and still the TV will lose the HDMI signal. Looking for other troubleshooting steps.
        sdetweil @danjvd
        @danjvd are you sure it’s the display turning off ?
        if you do alt-spacebar does the appenubcome down?
        if so, this means the app has crashed, leaving a black screen
        D 1 Reply Last reply
        • D
          danjvd @sdetweil
          @sdetweil I’m able to VNC to the pi, and when I move the mouse the TV will turn back on. It will then stay on for 5 minutes before TV lose HDMI connection. I have also keep the VNC connection open and watch the TV lose signal and the app continue to work.
          I have missed with the PI config file to increase the HDMI signal but same outcome.
          Also, I did setup CEC, 6 months ago, to control when the TV turns on and off. I was thinking there was an issues with the pi, so I created a con job to turn the TV, then restart the PI. This setting worked for about a week. Now if I do not restart the PI it comes up with no HDMI signal.
          I wondering if its an issues with the TV itself?
            sdetweil @danjvd
            @danjvd if you stop MagicMirror, does the screen turn off?
            • D
              danjvd @sdetweil
              @sdetweil I have not tried that. I will let you know later today of the outcome.
              Thanks Sam!
              Z 1 Reply Last reply
              • Z
                Zoltan @danjvd
                @danjvd It sounds as if your screen saver wasn’t disabled correctly?
                https://github.com/MichMich/MagicMirror/wiki/Configuring-the-Raspberry-Pi
                  sdetweil @Zoltan
                  @zoltan if u run my install script it will turn off screensavers if u say yes.
                  also a separate script if u change your mind
                  we are still waiting to see if it’s mm related or not
                  • D
                    danjvd @sdetweil
                    @sdetweil With MM turned off, the Pi keep display HDMI without issues. Are there any error logs that I should look at?
                    @Zoltan Thanks for the steps. I did complete this when I first created the MM pi over a year ago. It always a good thing to veirfy!
                      sdetweil
                      @danjvd ok so this means one of the modules you are using is turning off the display
                      can you do
                      grep module: ~/MagicMirror/config/config.js
                      to show us a list of the modules used
                      • D
                        danjvd @sdetweil
                        @sdetweil said in Losing display output after 5 minutes:
                        Here are the modules that I have been using for the past 6 months before the issues started. I have not added/removed any modules after this setup, only updates.
                          module: "alert",
                          module: 'MMM-BackgroundSlideshow',
                          module: "updatenotification",
                          module: "clock",
                          module: 'MMM-CalendarExt2',
                          module: "MMM-OpenWeatherMapForecast",
                          sdetweil @danjvd
                          @danjvd weird.
                          so next I would disable one module at a time.
                          (not the defaults)
                          add
                          disabled:true,
                          after the module: line
                          • D
                            danjvd @sdetweil
                            Before I was able to start disabling modules, MM would not start this morning. There are the logs that I got from pm2:
                            1 verbose cli [ '/usr/bin/node', '/usr/bin/npm', 'start' ]
                            2 info using npm@6.14.12
                            3 info using node@v10.24.1
                            5 info lifecycle magicmirror@2.17.1~prestart: magicmirror@2.17.1
                            6 info lifecycle magicmirror@2.17.1~start: magicmirror@2.17.1
                            7 verbose lifecycle magicmirror@2.17.1~start: unsafe-perm in lifecycle true
                            8 verbose lifecycle magicmirror@2.17.1~start: PATH: /usr/lib/node_modules/npm/node_modules/npm-lifecycle/node-gyp-bin:/home/pi/MagicMirror/node_modules/.bin:/usr/bin:/bin
                            9 verbose lifecycle magicmirror@2.17.1~start: CWD: /home/pi/MagicMirror
                            10 silly lifecycle magicmirror@2.17.1~start: Args: [ '-c',
                            10 silly lifecycle   'DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js' ]
                            11 info lifecycle magicmirror@2.17.1~start: Failed to exec start script
                            12 verbose stack Error: magicmirror@2.17.1 start: `DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js`
                            12 verbose stack spawn ENOENT
                            12 verbose stack     at ChildProcess.<anonymous> (/usr/lib/node_modules/npm/node_modules/npm-lifecycle/lib/spawn.js:48:18)
                            12 verbose stack     at ChildProcess.emit (events.js:198:13)
                            12 verbose stack     at maybeClose (internal/child_process.js:982:16)
                            12 verbose stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:259:5)
                            13 verbose pkgid magicmirror@2.17.1
                            14 verbose cwd /home/pi/MagicMirror
                            15 verbose Linux 5.10.63-v7l+
                            16 verbose argv "/usr/bin/node" "/usr/bin/npm" "start"
                            17 verbose node v10.24.1
                            18 verbose npm  v6.14.12
                            19 error code ELIFECYCLE
                            20 error syscall spawn
                            21 error file sh
                            22 error errno ENOENT
                            23 error magicmirror@2.17.1 start: `DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js`
                            23 error spawn ENOENT
                            24 error Failed at the magicmirror@2.17.1 start script.
                            24 error This is probably not a problem with npm. There is likely additional logging output above.
                            25 verbose exit [ 1, true ]
                            • D
                              danjvd @danjvd
                              Give you a little update after finding the error above. I have reinstalled dependency and built electron.
                              cd ~/MagicMirror
                              npm install
                              cd ~/MagicMirror/node_modules/electron/
                              node install.js
                              The reinstall came with the following warnings
                              npm WARN tsutils@3.21.0 requires a peer of typescript@>=2.8.0 || >= 3.2.0-dev || >= 3.3.0-dev || >= 3.4.0-dev || >= 3.5.0-dev || >= 3.6.0-dev || >= 3.6.0-beta || >= 3.7.0-dev || >= 3.7.0-beta but none is installed. You must install peer dependencies yourself.
                              npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/fsevents):
                              npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
                              I restarted MM with npm start, now getting the following:
                              [24.11.2021 17:34.23.187] [ERROR] WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module 'valid-url'
                              Require stack:
                              - /home/pi/MagicMirror/modules/MMM-CalendarExt2/node_helper.js
                              I disable that mode and was able to get MM restarted. I’m guessing there is an issue with MMM-CalendarExt2.
                                sdetweil @danjvd
                                @danjvd valid-url see
