    Losing display output after 5 minutes
    14 Posts 3 Posters 4.3k Views 3 Watching
      sdetweil @danjvd
      @danjvd weird.
      so next I would disable one module at a time.
      (not the defaults)
      add
      disabled:true,
      after the module: line
        danjvd @sdetweil
        Before I was able to start disabling modules, MM would not start this morning. There are the logs that I got from pm2:
        1 verbose cli [ '/usr/bin/node', '/usr/bin/npm', 'start' ]
        2 info using npm@6.14.12
        3 info using node@v10.24.1
        5 info lifecycle magicmirror@2.17.1~prestart: magicmirror@2.17.1
        6 info lifecycle magicmirror@2.17.1~start: magicmirror@2.17.1
        7 verbose lifecycle magicmirror@2.17.1~start: unsafe-perm in lifecycle true
        8 verbose lifecycle magicmirror@2.17.1~start: PATH: /usr/lib/node_modules/npm/node_modules/npm-lifecycle/node-gyp-bin:/home/pi/MagicMirror/node_modules/.bin:/usr/bin:/bin
        9 verbose lifecycle magicmirror@2.17.1~start: CWD: /home/pi/MagicMirror
        10 silly lifecycle magicmirror@2.17.1~start: Args: [ '-c',
        10 silly lifecycle   'DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js' ]
        11 info lifecycle magicmirror@2.17.1~start: Failed to exec start script
        12 verbose stack Error: magicmirror@2.17.1 start: `DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js`
        12 verbose stack spawn ENOENT
        12 verbose stack     at ChildProcess.<anonymous> (/usr/lib/node_modules/npm/node_modules/npm-lifecycle/lib/spawn.js:48:18)
        12 verbose stack     at ChildProcess.emit (events.js:198:13)
        12 verbose stack     at maybeClose (internal/child_process.js:982:16)
        12 verbose stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:259:5)
        13 verbose pkgid magicmirror@2.17.1
        14 verbose cwd /home/pi/MagicMirror
        15 verbose Linux 5.10.63-v7l+
        16 verbose argv "/usr/bin/node" "/usr/bin/npm" "start"
        17 verbose node v10.24.1
        18 verbose npm  v6.14.12
        19 error code ELIFECYCLE
        20 error syscall spawn
        21 error file sh
        22 error errno ENOENT
        23 error magicmirror@2.17.1 start: `DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js`
        23 error spawn ENOENT
        24 error Failed at the magicmirror@2.17.1 start script.
        24 error This is probably not a problem with npm. There is likely additional logging output above.
        25 verbose exit [ 1, true ]
          danjvd @danjvd
          Give you a little update after finding the error above. I have reinstalled dependency and built electron.
          cd ~/MagicMirror
          npm install
          cd ~/MagicMirror/node_modules/electron/
          node install.js
          The reinstall came with the following warnings
          npm WARN tsutils@3.21.0 requires a peer of typescript@>=2.8.0 || >= 3.2.0-dev || >= 3.3.0-dev || >= 3.4.0-dev || >= 3.5.0-dev || >= 3.6.0-dev || >= 3.6.0-beta || >= 3.7.0-dev || >= 3.7.0-beta but none is installed. You must install peer dependencies yourself.
          npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/fsevents):
          npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
          I restarted MM with npm start, now getting the following:
          [24.11.2021 17:34.23.187] [ERROR] WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module 'valid-url'
          Require stack:
          - /home/pi/MagicMirror/modules/MMM-CalendarExt2/node_helper.js
          I disable that mode and was able to get MM restarted. I’m guessing there is an issue with MMM-CalendarExt2.
            sdetweil @danjvd
            @danjvd valid-url see
