    How to send a notification
    35 Posts 3 Posters 6.5k Views 3 Watching
      sdetweil @Alyx
      @alyx so, now open the developers window, ctrl-shift-i, and look at the console tab
      u may be able to see some module report the notification
      or install my samplemodule as it reports all notifications received
      https://github.com/sdetweil/SampleModule
      in the Alexa app u can control devices manually, so that makes testing a lot easier
        Alyx @sdetweil
        @sdetweil Hi sam,
        Great so i can see that the notification isnt being sent via the dev console, it shows up via Alexa app but isnt communicating to the MM. Would you happen to know the cause?
                module: 'MMM-AlexaControl',
                position: 'middle_center',
        	config:{
                    image: true,
        	    deviceName: "mirror",
                    pm2ProcessName: "mm",
                    vcgencmd: "hide",
        	    startPort: 11001,
        	    refresh: true,
        	    restart: true,
        	    //stop: true,
        	    reboot: true,
        	    shutdown: true,
        	    monitorToggle: true,
        	    //cecAddress: "0.0.0.0",
        	    //usb: false
        	    pages: 3,
        	    notifications:[
                port: 11102,
                OnOff: false,
                notification: ["PAGE_INCREMENT", 'payload']
                port: 11103,
                OnOff: false,
                notification: ["PAGE_DECREMENT", 'payload']
                port: 11104,
                OnOff: false,
                notification: ["SELFIE_SHOOT", 'payload']
          sdetweil @Alyx
          @alyx not really. if u stop MagicMirror, and then tell Alexa to turn on your notification device, you should get a ‘not responding’ message from alexa
          that will tell you the two are really connected.
          Alexa turn on selfie
            Alyx @sdetweil
            @sdetweil Yep that makes sense but it isnt popping up below is a quick snapshot of the dev panel
            MMM-MotionDetector.js:75 MMM-MotionDetector: DiffCamEngine init successful.
            module.js:195 MMM-AlexaControl is suspended.
            module.js:195 MMM-NASA is suspended.
            module.js:195 MMM-ISS-Live is suspended.
            module.js:195 MMM-MotionDetector is suspended.
            module.js:195 lifecounter is suspended.
            module.js:195 compliments is suspended.
            module.js:195 MMM-chromecast is suspended.
            MMM-NASA.js:132 Hailing NASA
            module.js:202 MMM-page-indicator is resumed.
            module.js:202 MMM-Selfieshot is resumed.
            module.js:202 MMM-Astro is resumed.
            module.js:202 MMM-MoonPhase is resumed.
            module.js:202 clock is resumed.
            eventtracking-log.services.video.ibm.com/eventtracking.web.player/:1 Failed to load resource: net::ERR_BLOCKED_BY_CLIENT
            MMM-AlexaControl.js:75 RECEIVE monitor NOTIFICATION=SLEEP_WAKE
            MMM-AlexaControl.js:75 RECEIVE monitor NOTIFICATION=SLEEP_HIDE
            MMM-pages.js:97
            The errors lead to this page
            400 Bad Request
            ‘json’ or ‘msgpack’ parameter is required
              sdetweil @Alyx
              @alyx said in How to send a notification:
              one thing at a time
              you didn’t answer the question about connection
                Alyx @sdetweil
                @sdetweil Apoligies, tested there.
                So I stopped magic mirror/ restarted the pi and it came up with device unresponsive.
                  sdetweil @Alyx
                  @alyx ok, and when MM is running you get the completion sound from alexa, correct?
                    Alyx @sdetweil
                    @sdetweil what do mean by a completion sound? Do you mean the confirmation of ‘ok’ after? If so then yes
                      sdetweil @Alyx
                      @alyx when u turn on or off a device, alexa does tada sound… to says it processed your request
                        Alyx @sdetweil
                        @sdetweil ah my one says ‘ok’ but id assume its the same
                        • 2 / 4
