    So I have a question about backup
    24 Posts 6 Posters 9.8k Views 5 Watching
      sdetweil @Ray
      @ray said in So I have a question about backup:
      I’m fairly new at writing scripts. They are a lot of fun
      yes, indeed… i learn new stuff all the time (like parameter handling this time)
      • AssassinsA Offline
        Assassins
        Or you Can backup the Hole disk up with :
        https://github.com/The-Exterminator/PiShrink-to-Crontab
          Ray @sdetweil
          @sdetweil sorry it’s been so long since I replied to this form.
          So I wanted to just let you know I did make my own backup and restore scripts.
          The backup is pretty simple. It just makes a copy of my modules folder and stores it in a safe place.
          The restore is a little bit different. It will restore the module folder to its original location and then use npm install in each folder.
          It worked perfectly
          I tested it Under virtual disk. I install magic. Mayor the traditional way and then use my restore program and it worked perfectly.
          I wanted to thank you for all your help and your ideas
            sdetweil @Ray
            @ray no problem… the fact that you have backup and restore is the good thing…
