    MMM-compliment showing evening compliment anytime
    24 Posts 2 Posters 7.6k Views 2 Watching
      selyjohns
      I’ve a problem with MMM-compliment that showing evening compliment at anytime…
      The config is correct.
      I’ve adding hour configuration to be sure with morningStartTime, morningEndTime, afternoonStartTime and afternoonEndTime but problem persist…my MM say good night on morning…
      The date/time of my rpi3 is correct…any idea ?
      Thank you
        sdetweil @selyjohns
        @selyjohns did u look at any issues in the module github , issues tab?
          selyjohns @sdetweil
          @sdetweil No, nothing…
                                  module: 'compliments',
                                  position: 'lower_third',
                                          morningStartTime:3,
                                          morningEndTime:10,
                                          afternoonStartTime:13,
                                          afternoonEndTime:18,
                                          remoteFile: 'compliments.json'
          compliments.json is stored in MagicMirror/modules/default/compliments/ :) This part is good.
            sdetweil @selyjohns
            @selyjohns ok, one thing
            MMM-compliment means some external additional module
            module: ‘compliments’,
            means the one shipped with MagicMirror…
              selyjohns @sdetweil
              @sdetweil said in MMM-compliment showing evening compliment anytime:
              Oh OK, not evident.
              I speak about the module ‘compliments’, integrated with MM in default folder :)
                sdetweil @selyjohns
                @selyjohns well, you have a gap
                                                morningEndTime:10,
                can’t have a gap
                else it the same as ANY OTHER time but morning or afternoon…
                so 10:01->>> 12:59 OR 18:01 ->>>> 02:59
                note the defaults are
                		morningStartTime: 3,
                		morningEndTime: 12,
                		afternoonStartTime: 12,
                		afternoonEndTime: 17,
                morning 3-12, afternoon 12-17, rest 17-3
                  selyjohns @sdetweil
                  @sdetweil Ok, but i’ve added this configuration because i had the problem with default configuration.
                  I can delete it. Normally we don’t need this, right ?
                    sdetweil @selyjohns
                    @selyjohns if u don’t need a different time set, then you would use the default…
                    all I was saying is that you have a gap in the time, and the code design demands no gap.
                    the code has
                    morning
                    afternoon
                    everything else
                      selyjohns @sdetweil
                      @sdetweil Ok thank you.
                      Trying with no specific configuration -> MM say “goodnight” or “good evening” but it’s only 4 PM
                      Trying with specifig configuration with no gap, same result :(
                                                      morningStartTime:3,
                                                      morningEndTime:12,
                                                      afternoonStartTime:12,
                        sdetweil @selyjohns
                        @selyjohns what does the remotefile look like?
                        I just want the things to the left of :
                        default is this
                        		compliments: {
                        			anytime: ["Hey there sexy!"],
                        			morning: ["Good morning, handsome!", "Enjoy your day!", "How was your sleep?"],
                        			afternoon: ["Hello, beauty!", "You look sexy!", "Looking good today!"],
                        			evening: ["Wow, you look hot!", "You look nice!", "Hi, sexy!"],
                        			"....-01-01": ["Happy new year!"]
                          selyjohns @sdetweil
                          Here’s :)
                          	"anytime": [
                          			"Comment ça va ?",
                          			"Bonjour"
                          	"morning": [
                          			"Un petit café ?",
                          			"Bien dormi ?",
                          			"Bonne journée !"
                          	"evening": [
                          			"Bonne soirée !",
                          			"Bonne nuit...",
                          			"Agréable soirée"
                          	"day_sunny": [
                          			"Le temps est ensoleillé aujourd'hui !",
                          			"C'est une belle journée"
                          	"day_cloudy": [
                          			"C'est nuageux aujourd'hui..."
                          	"snow": [
                          			"Bataille de boules de neige !!!"
                          	"rain": [
                          			"N'oublie pas ton parapluie...",
                          			"Et si on restait au sec aujourd'hui ?"
                          With " as indicated on the readme when using remote file.
                          But, i had the problem before using remote file, i’ve do this hoping this would resolve the problem, but it’s dont.
                          Is it possible to “remove/reinstall” default module like compliments ?
                            sdetweil @selyjohns
                            @selyjohns said in MMM-compliment showing evening compliment anytime:
                            no, but u can get the original code back (which you shouldn’t have changed)
                            do
                            cd ~/MagicMirror
                            check for changed files
                            git status
                            if the compliments module has anything is listed as modified
                            git checkout modules/default/compliments/compliments.js   (or whatever filename
                              @sdetweil ok, looking at the code again, duh
                              it takes the time period AND the anytime, mashes them together and then randomly picks one of the list
                              so, if u don’t want ‘anytime’ , then remove it… or understand it will happen ‘anytime’
                                selyjohns @sdetweil
                                @sdetweil Thank you for your time :)
                                The problem doesn’t concern “anytime” values, but “evening”.
                                Anytime is anytime and it’s normal that compliment in this section can be displayed at anytime…:)
                                Compliments define in “evening” are displayed all the day, not only on the evening. This is my problem. The MM showing evening compliment at anytime…
                                With my exemple, the MM display “Bonne soirée” or “Bonne nuit…”, also the morning, or afternon. Like this compliment was positionned in “anytime”
                                  sdetweil @selyjohns
                                  @selyjohns I copied your compliments to my config, and do not see that
                                  the code gets the current system time hour (in 24 hour format)
                                  and only uses the evening list if neither morning nor afternoon ranges include the current hour (all OTHER time)
                                  then adds anytime if specified to that list
                                  then adds weather related if specified
                                  then picks one
                                    selyjohns @sdetweil
                                    Ok, thank you for your test.
                                    So maybe a problem on my system time. However it seem to be correct. Another solution to verify that ? (Other than timedatectl ?)
                                    Is it possible to have verbose log to see the how the module decide to display compliment ?
                                      sdetweil @selyjohns
                                      @selyjohns there is no debug on how it decided, but you could walk thru the code.
                                      open the developers window ctrl-shift-i and select the source tab, and navigate the left lane to modules , default, compliments, compliments.js
                                      the code will appear in the right pane
                                      scroll down to
                                      let compliments;
                                      the next line of code is using the hour
                                      to test if in between morning, then afternoon
                                      the the else for evening of some
                                      click the number in the left column, turns blue
                                      hit F5 to reload the page. will stop there
                                      you can hover the mouse over variables to examine their value
                                      blue arrow upper right to run , or circle be t to step one instruction
                                        selyjohns @sdetweil
                                        @sdetweil Hi,
                                        Ok great.
                                        I be able to see the value of hour variable.
                                        It seem to be correct because it’s 17.
                                        Condition of morning not verified.
                                        Condition of afternoon verified, so the line is executed (because 17 is between 12 and 18)
                                        compliments = this.config.compliments.afternoon.slice(0);
                                        I don’t know why evening compliments are displayed…it’s very strange
                                          sdetweil @selyjohns
                                          @selyjohns there are a few more lines of code to step thru…
                                          when it gets to the return compliments u can go er over compliments and then expand the array to see what is in there
                                            selyjohns @sdetweil
                                            @sdetweil Yes ! Problem found…
                                            Step by step, i’ve understand
                                            		if (hour >= this.config.morningStartTime && hour < this.config.morningEndTime && this.config.compliments.hasOwnProperty("morning")) {
                                            			compliments = this.config.compliments.morning.slice(0);
                                            		} else if (hour >= this.config.afternoonStartTime && hour < this.config.afternoonEndTime && this.config.compliments.hasOwnProperty("afternoon")) {
                                            		} else if (this.config.compliments.hasOwnProperty("evening")) {
                                            			compliments = this.config.compliments.evening.slice(0);
                                            The JS need to have a “morning” and “afternoon” compliments define, else it choosing “evening” by default if define.
                                            My problem was i don’t had afternoon compliment define…but i’ve evening one.
                                            Thank you very much for your time and your time :) It was very helpful.
