    MMM-compliment showing evening compliment anytime
    24 Posts 2 Posters 6.5k Views 2 Watching
      selyjohns @sdetweil
      @sdetweil said in MMM-compliment showing evening compliment anytime:
      @selyjohns ok, one thing
      MMM-compliment means some external additional module
      module: ‘compliments’,
      means the one shipped with MagicMirror…
      Oh OK, not evident.
      I speak about the module ‘compliments’, integrated with MM in default folder :)
        sdetweil @selyjohns
        @selyjohns well, you have a gap
                                        morningEndTime:10,
                                        afternoonStartTime:13,
        can’t have a gap
        else it the same as ANY OTHER time but morning or afternoon…
        so 10:01->>> 12:59 OR 18:01 ->>>> 02:59
        note the defaults are
        		morningStartTime: 3,
        		morningEndTime: 12,
        		afternoonStartTime: 12,
        		afternoonEndTime: 17,
        morning 3-12, afternoon 12-17, rest 17-3
          selyjohns @sdetweil
          @sdetweil Ok, but i’ve added this configuration because i had the problem with default configuration.
          I can delete it. Normally we don’t need this, right ?
            sdetweil @selyjohns
            @selyjohns if u don’t need a different time set, then you would use the default…
            all I was saying is that you have a gap in the time, and the code design demands no gap.
            the code has
            morning
            afternoon
            everything else
              selyjohns @sdetweil
              @sdetweil Ok thank you.
              Trying with no specific configuration -> MM say “goodnight” or “good evening” but it’s only 4 PM
              Trying with specifig configuration with no gap, same result :(
                                      module: 'compliments',
                                      position: 'lower_third',
                                              morningStartTime:3,
                                              morningEndTime:12,
                                              afternoonStartTime:12,
                                              afternoonEndTime:18,
                                              remoteFile: 'compliments.json'
                sdetweil @selyjohns
                @selyjohns what does the remotefile look like?
                I just want the things to the left of :
                default is this
                		compliments: {
                			anytime: ["Hey there sexy!"],
                			morning: ["Good morning, handsome!", "Enjoy your day!", "How was your sleep?"],
                			afternoon: ["Hello, beauty!", "You look sexy!", "Looking good today!"],
                			evening: ["Wow, you look hot!", "You look nice!", "Hi, sexy!"],
                			"....-01-01": ["Happy new year!"]
                  selyjohns @sdetweil
                  Here’s :)
                  	"anytime": [
                  			"Comment ça va ?",
                  			"Bonjour"
                  	"morning": [
                  			"Un petit café ?",
                  			"Bien dormi ?",
                  			"Bonne journée !"
                  	"evening": [
                  			"Bonne soirée !",
                  			"Bonne nuit...",
                  			"Agréable soirée"
                  	"day_sunny": [
                  			"Le temps est ensoleillé aujourd'hui !",
                  			"C'est une belle journée"
                  	"day_cloudy": [
                  			"C'est nuageux aujourd'hui..."
                  	"snow": [
                  			"Bataille de boules de neige !!!"
                  	"rain": [
                  			"N'oublie pas ton parapluie...",
                  			"Et si on restait au sec aujourd'hui ?"
                  With " as indicated on the readme when using remote file.
                  But, i had the problem before using remote file, i’ve do this hoping this would resolve the problem, but it’s dont.
                  Is it possible to “remove/reinstall” default module like compliments ?
                    sdetweil @selyjohns
                    @selyjohns said in MMM-compliment showing evening compliment anytime:
                    no, but u can get the original code back (which you shouldn’t have changed)
                    do
                    cd ~/MagicMirror
                    check for changed files
                    git status
                    if the compliments module has anything is listed as modified
                    git checkout modules/default/compliments/compliments.js   (or whatever filename
                      @sdetweil ok, looking at the code again, duh
                      it takes the time period AND the anytime, mashes them together and then randomly picks one of the list
                      so, if u don’t want ‘anytime’ , then remove it… or understand it will happen ‘anytime’
                        selyjohns @sdetweil
                        @sdetweil Thank you for your time :)
                        The problem doesn’t concern “anytime” values, but “evening”.
                        Anytime is anytime and it’s normal that compliment in this section can be displayed at anytime…:)
                        Compliments define in “evening” are displayed all the day, not only on the evening. This is my problem. The MM showing evening compliment at anytime…
                        With my exemple, the MM display “Bonne soirée” or “Bonne nuit…”, also the morning, or afternon. Like this compliment was positionned in “anytime”
                        • 3 / 3
