    OrangePi Zero 2 installation issues
    41 Posts 2 Posters 10.3k Views 2 Watching
      sdetweil @michelw
      @michelw and when u are using vnc, the monitor is showing the desktop, right?
        michelw
        Ah right.
        I would like to thank you very much for all your help.
        Went looking for a second hand Raspberry PI 4B 1G today and found one. A little expensive but at least I have something more compatible now so I at least can get the magicmirror running :)
        Still willing to help out (testing) if you would like to make your script Orange Pi Zero 2 compatible. That might help others.
          michelw @sdetweil
          @sdetweil said in OrangePi Zero 2 installation issues:
          Yes, that is correct.
            sdetweil @michelw
            @michelw it’s not the script, it’s the assumption by the mm startup, defined in package.json), that DISPLAY needs to be :0 if not already set.
              sdetweil
              which image did u try?
              debian or Ubuntu?
                michelw
                I tried all of them, the latest I tried was : Orangepizero2_2.1.6_debian_buster_desktop_linux4.9.170.img
                  sdetweil @michelw
                  @michelw installed XFCE desktop armbian on pi4(4gb)…
                  opened terminal on desktop, see
                  DISPLAY=:0.0
                  installing MM now
                  DISPLAY not set on ssh session
                  SLOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOW!
                    michelw @sdetweil
                    Any results?
                      sdetweil @michelw
                      @michelw no, looks like I picked a bad SD card.
                      have to try again. hour or so
                        @sdetweil armbian on pi worked as expected…
                        i used the xfce image…
                        • 4 / 5
