    OrangePi Zero 2 installation issues
    41 Posts 2 Posters 14.6k Views 2 Watching
      sdetweil @michelw
      @michelw no, but I can try armbian on my pi now
        sdetweil @michelw
        @michelw and when u are using vnc, the monitor is showing the desktop, right?
          michelw
          Ah right.
          I would like to thank you very much for all your help.
          Went looking for a second hand Raspberry PI 4B 1G today and found one. A little expensive but at least I have something more compatible now so I at least can get the magicmirror running :)
          Still willing to help out (testing) if you would like to make your script Orange Pi Zero 2 compatible. That might help others.
            michelw @sdetweil
            @sdetweil said in OrangePi Zero 2 installation issues:
            Yes, that is correct.
              sdetweil @michelw
              @michelw it’s not the script, it’s the assumption by the mm startup, defined in package.json), that DISPLAY needs to be :0 if not already set.
                which image did u try?
                debian or Ubuntu?
                  michelw
                  I tried all of them, the latest I tried was : Orangepizero2_2.1.6_debian_buster_desktop_linux4.9.170.img
                    sdetweil @michelw
                    @michelw installed XFCE desktop armbian on pi4(4gb)…
                    opened terminal on desktop, see
                    DISPLAY=:0.0
                    installing MM now
                    DISPLAY not set on ssh session
                    SLOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOW!
                      michelw @sdetweil
                      Any results?
                        sdetweil @michelw
                        @michelw no, looks like I picked a bad SD card.
                        have to try again. hour or so
                          @sdetweil armbian on pi worked as expected…
                          i used the xfce image…
                            michelw @sdetweil
                            Thanks for testing. This sadly did not work for me on the Orange Pi Zero 2.
                            • 2 / 3
