    OrangePi Zero 2 installation issues
    41 Posts 2 Posters 15.3k Views 2 Watching
      michelw @michelw
        michelw @michelw
        @michelw said in OrangePi Zero 2 installation issues:
        Not sure I understand what you mean. I’m doing all of this using ssh.
        Does this help?
        michel@orangepizero2:~$ cat /etc/X11/xorg.conf.d/01-orangepi-defaults.conf
        Section "Monitor"
        	Identifier		"Monitor0"
        	Option			"DPMS" "false"
        EndSection
        Section "ServerFlags"
        	Option			"BlankTime" "0"
        	Option			"StandbyTime" "0"
        	Option			"SuspendTime" "0"
        	Option			"OffTime" "0"
        EndSection
        # rotate the screen
        Section "Device"
            Identifier "default"
            Driver "fbdev"
            Option "Rotate" "CCW"
        EndSection
        I just added the rotation part and it rotated the desktop. The identifier seems to be " Monitor0"
          sdetweil @michelw
          @michelw ok, using command line
          export DISPLAY=Monitor0
          npm start
          if that works then edit installers/mm.sh and add that export before the npm start
          then pm2 start should work
          M 1 Reply Last reply
            michelw @sdetweil
            @sdetweil said in OrangePi Zero 2 installation issues:
            npm start
            michel@orangepizero2:~/MagicMirror$ export DISPLAY=Monitor0
            michel@orangepizero2:~/MagicMirror$ npm start
            > magicmirror@2.17.1 start /home/michel/MagicMirror
            [10.12.2021 23:32.41.725] [LOG]   Starting MagicMirror: v2.17.1
            [10.12.2021 23:32.41.743] [LOG]   Loading config ...
            [10.12.2021 23:32.41.757] [LOG]   Loading module helpers ...
            [10.12.2021 23:32.41.762] [LOG]   No helper found for module: alert.
            [10.12.2021 23:32.41.800] [LOG]   Initializing new module helper ...
            [10.12.2021 23:32.41.804] [LOG]   Module helper loaded: updatenotification
            [10.12.2021 23:32.41.807] [LOG]   No helper found for module: clock.
            [10.12.2021 23:32.42.141] [LOG]   Initializing new module helper ...
            [10.12.2021 23:32.42.144] [LOG]   Module helper loaded: calendar
            [10.12.2021 23:32.42.146] [LOG]   No helper found for module: compliments.
            [10.12.2021 23:32.42.149] [LOG]   No helper found for module: weather.
            [10.12.2021 23:32.42.196] [LOG]   Initializing new module helper ...
            [10.12.2021 23:32.42.198] [LOG]   Module helper loaded: newsfeed
            [10.12.2021 23:32.42.200] [LOG]   All module helpers loaded.
            [10.12.2021 23:32.42.420] [LOG]   Starting server on port 8080 ...
            [10.12.2021 23:32.42.453] [LOG]   Server started ...
            [10.12.2021 23:32.42.456] [LOG]   Connecting socket for: updatenotification
            [10.12.2021 23:32.42.459] [LOG]   Connecting socket for: calendar
            [10.12.2021 23:32.42.461] [LOG]   Starting node helper for: calendar
            [10.12.2021 23:32.42.463] [LOG]   Connecting socket for: newsfeed
            [10.12.2021 23:32.42.465] [LOG]   Starting node helper for: newsfeed
            [10.12.2021 23:32.42.467] [LOG]   Sockets connected & modules started ...
            The futex facility returned an unexpected error code.
            /home/michel/MagicMirror/node_modules/electron/dist/electron exited with signal SIGABRT
            npm ERR! code ELIFECYCLE
            npm ERR! errno 1
            npm ERR! magicmirror@2.17.1 start: `DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js`
            npm ERR! Exit status 1
            npm ERR!
            npm ERR! Failed at the magicmirror@2.17.1 start script.
            npm ERR!     /home/michel/.npm/_logs/2021-12-10T23_32_42_717Z-debug.log
              sdetweil @michelw
              @michelw so, no
                @michelw does chromium work?
                S M 2 Replies Last reply
                  @michelw armbian on pi
                  https://9to5linux.com/first-look-at-armbian-linux-on-raspberry-pi-4
                    michelw @sdetweil
                    Yes chromium seems to work. I installed vnc server since this SBC is in my mirror and I have now way to attach a mouse.
                      michelw @sdetweil
                      Not sure what you are trying to say by pointing me to the 9to5 article. Is there something relevant in there i missed? :)
                        michelw @sdetweil
                        I just played around with the DISPLAY parameter and when setting:
                        michel@orangepizero2:~/MagicMirror$ export DISPLAY=:1
                        [11.12.2021 09:15.21.920] [LOG]   Starting MagicMirror: v2.17.1
                        [11.12.2021 09:15.21.937] [LOG]   Loading config ...
                        [11.12.2021 09:15.21.952] [LOG]   Loading module helpers ...
                        [11.12.2021 09:15.21.957] [LOG]   No helper found for module: alert.
                        [11.12.2021 09:15.21.994] [LOG]   Initializing new module helper ...
                        [11.12.2021 09:15.21.998] [LOG]   Module helper loaded: updatenotification
                        [11.12.2021 09:15.22.001] [LOG]   No helper found for module: clock.
                        [11.12.2021 09:15.22.350] [LOG]   Initializing new module helper ...
                        [11.12.2021 09:15.22.353] [LOG]   Module helper loaded: calendar
                        [11.12.2021 09:15.22.355] [LOG]   No helper found for module: compliments.
                        [11.12.2021 09:15.22.358] [LOG]   No helper found for module: weather.
                        [11.12.2021 09:15.22.404] [LOG]   Initializing new module helper ...
                        [11.12.2021 09:15.22.406] [LOG]   Module helper loaded: newsfeed
                        [11.12.2021 09:15.22.408] [LOG]   All module helpers loaded.
                        [11.12.2021 09:15.22.633] [LOG]   Starting server on port 8080 ...
                        [11.12.2021 09:15.22.669] [LOG]   Server started ...
                        [11.12.2021 09:15.22.672] [LOG]   Connecting socket for: updatenotification
                        [11.12.2021 09:15.22.676] [LOG]   Connecting socket for: calendar
                        [11.12.2021 09:15.22.678] [LOG]   Starting node helper for: calendar
                        [11.12.2021 09:15.22.680] [LOG]   Connecting socket for: newsfeed
                        [11.12.2021 09:15.22.683] [LOG]   Starting node helper for: newsfeed
                        [11.12.2021 09:15.22.685] [LOG]   Sockets connected & modules started ...
                        [11.12.2021 09:15.23.736] [LOG]   Launching application.
                        [11.12.2021 09:15.29.501] [LOG]   Create new calendarfetcher for url: http://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics - Interval: 300000
                        [11.12.2021 09:15.29.593] [LOG]   Create new newsfetcher for url: https://rss.nytimes.com/services/xml/rss/nyt/HomePage.xml - Interval: 300000
                        [11.12.2021 09:15.29.661] [INFO]  Checking git for module: default
                        [11.12.2021 09:15.31.393] [INFO]  Calendar-Fetcher: Broadcasting 10 events.
                        [11.12.2021 09:15.31.553] [INFO]  Newsfeed-Fetcher: Broadcasting 58 items.
                        I get the magic mirror in the VNC session (but not on the monitor)
                        So this seems to be related to the output somehow.
                          sdetweil @michelw
                          @michelw no, but I can try armbian on my pi now
                            sdetweil @michelw
                            @michelw and when u are using vnc, the monitor is showing the desktop, right?
                              michelw
                              Ah right.
                              I would like to thank you very much for all your help.
                              Went looking for a second hand Raspberry PI 4B 1G today and found one. A little expensive but at least I have something more compatible now so I at least can get the magicmirror running :)
                              Still willing to help out (testing) if you would like to make your script Orange Pi Zero 2 compatible. That might help others.
                                michelw @sdetweil
                                Yes, that is correct.
                                  sdetweil @michelw
                                  @michelw it’s not the script, it’s the assumption by the mm startup, defined in package.json), that DISPLAY needs to be :0 if not already set.
                                    which image did u try?
                                    debian or Ubuntu?
                                      michelw
                                      I tried all of them, the latest I tried was : Orangepizero2_2.1.6_debian_buster_desktop_linux4.9.170.img
                                        sdetweil @michelw
                                        @michelw installed XFCE desktop armbian on pi4(4gb)…
                                        opened terminal on desktop, see
                                        DISPLAY=:0.0
                                        installing MM now
                                        DISPLAY not set on ssh session
                                        SLOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOW!
                                          michelw @sdetweil
                                          Any results?
                                            sdetweil @michelw
                                            @michelw no, looks like I picked a bad SD card.
                                            have to try again. hour or so
                                            • 2 / 3
