    OrangePi Zero 2 installation issues
    41 Posts 2 Posters 14.6k Views 2 Watching
      sdetweil @michelw
      @michelw your xwindows might have a different numbering, so use that
        michelw @sdetweil
        @sdetweil said in OrangePi Zero 2 installation issues:
        Not sure what you mean. I am not a linux expert ;)
        michel@magicmirror:~$ pm2 stop all
        [PM2] Applying action stopProcessId on app [all](ids: [ 0 ])
        [PM2] [MagicMirror](0) ✓
        │ id  │ name           │ namespace   │ version │ mode    │ pid      │ uptime │ ↺    │ status    │ cpu      │ mem      │ user     │ watching │
        │ 0   │ MagicMirror    │ default     │ 2.17.1  │ fork    │ 0        │ 0      │ 396  │ stopped   │ 0%       │ 0b       │ michel   │ disabled │
        michel@magicmirror:~$ export DISPLAY=:0
        michel@magicmirror:~$ cd ~/MagicMirror
        michel@magicmirror:~/MagicMirror$ npm start
        > magicmirror@2.17.1 start /home/michel/MagicMirror
        [10.12.2021 22:32.33.528] [LOG]   Starting MagicMirror: v2.17.1
        [10.12.2021 22:32.33.544] [LOG]   Loading config ...
        [10.12.2021 22:32.33.558] [LOG]   Loading module helpers ...
        [10.12.2021 22:32.33.563] [LOG]   No helper found for module: alert.
        [10.12.2021 22:32.33.600] [LOG]   Initializing new module helper ...
        [10.12.2021 22:32.33.603] [LOG]   Module helper loaded: updatenotification
        [10.12.2021 22:32.33.606] [LOG]   No helper found for module: clock.
        [10.12.2021 22:32.33.953] [LOG]   Initializing new module helper ...
        [10.12.2021 22:32.33.955] [LOG]   Module helper loaded: calendar
        [10.12.2021 22:32.33.958] [LOG]   No helper found for module: compliments.
        [10.12.2021 22:32.33.960] [LOG]   No helper found for module: weather.
        [10.12.2021 22:32.33.997] [LOG]   Initializing new module helper ...
        [10.12.2021 22:32.33.999] [LOG]   Module helper loaded: newsfeed
        [10.12.2021 22:32.34.001] [LOG]   All module helpers loaded.
        [10.12.2021 22:32.34.223] [LOG]   Starting server on port 8080 ...
        [10.12.2021 22:32.34.255] [LOG]   Server started ...
        [10.12.2021 22:32.34.258] [LOG]   Connecting socket for: updatenotification
        [10.12.2021 22:32.34.260] [LOG]   Connecting socket for: calendar
        [10.12.2021 22:32.34.262] [LOG]   Starting node helper for: calendar
        [10.12.2021 22:32.34.264] [LOG]   Connecting socket for: newsfeed
        [10.12.2021 22:32.34.266] [LOG]   Starting node helper for: newsfeed
        [10.12.2021 22:32.34.268] [LOG]   Sockets connected & modules started ...
        /home/michel/MagicMirror/node_modules/electron/dist/electron exited with signal SIGSEGV
        npm ERR! code ELIFECYCLE
        npm ERR! errno 1
        npm ERR! magicmirror@2.17.1 start: `DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js`
        npm ERR! Exit status 1
        npm ERR!
        npm ERR! Failed at the magicmirror@2.17.1 start script.
        npm ERR!     /home/michel/.npm/_logs/2021-12-10T21_32_34_516Z-debug.log
        Found this somewhere:
        michel@magicmirror:~/MagicMirror$ ps -u $(id -u) -o pid= \
        >     | xargs -I PID -r cat /proc/PID/environ 2> /dev/null \
        >     | tr '\0' '\n' \
        >     | grep ^DISPLAY=: \
        >     | sort -u
        DISPLAY=:0
          sdetweil @michelw
          @michelw xwindows has logical displays, using numbers for the ‘identifiet’
          :0
          etc…
          some systems use different numbering
          my zorin system uses :10
          electron expects that I’d to be in the DISPLAY environment variable
          so, open a terminal window and do
          env
          show the result
            michelw @sdetweil
            env
            michel@orangepizero2:~$ env
            SHELL=/bin/bash
            LANGUAGE=en_US.UTF-8
            PWD=/home/michel
            LOGNAME=michel
            XDG_SESSION_TYPE=tty
            HOME=/home/michel
            LANG=en_US.UTF-8
            LS_COLORS=rs=0:di=01;34:ln=01;36:mh=00:pi=40;33:so=01;35:do=01;35:bd=40;33;01:cd=40;33;01:or=40;31;01:mi=00:su=37;41:sg=30;43:ca=30;41:tw=30;42:ow=34;42:st=37;44:ex=01;32:*.tar=01;31:*.tgz=01;31:*.arc=01;31:*.arj=01;31:*.taz=01;31:*.lha=01;31:*.lz4=01;31:*.lzh=01;31:*.lzma=01;31:*.tlz=01;31:*.txz=01;31:*.tzo=01;31:*.t7z=01;31:*.zip=01;31:*.z=01;31:*.dz=01;31:*.gz=01;31:*.lrz=01;31:*.lz=01;31:*.lzo=01;31:*.xz=01;31:*.zst=01;31:*.tzst=01;31:*.bz2=01;31:*.bz=01;31:*.tbz=01;31:*.tbz2=01;31:*.tz=01;31:*.deb=01;31:*.rpm=01;31:*.jar=01;31:*.war=01;31:*.ear=01;31:*.sar=01;31:*.rar=01;31:*.alz=01;31:*.ace=01;31:*.zoo=01;31:*.cpio=01;31:*.7z=01;31:*.rz=01;31:*.cab=01;31:*.wim=01;31:*.swm=01;31:*.dwm=01;31:*.esd=01;31:*.jpg=01;35:*.jpeg=01;35:*.mjpg=01;35:*.mjpeg=01;35:*.gif=01;35:*.bmp=01;35:*.pbm=01;35:*.pgm=01;35:*.ppm=01;35:*.tga=01;35:*.xbm=01;35:*.xpm=01;35:*.tif=01;35:*.tiff=01;35:*.png=01;35:*.svg=01;35:*.svgz=01;35:*.mng=01;35:*.pcx=01;35:*.mov=01;35:*.mpg=01;35:*.mpeg=01;35:*.m2v=01;35:*.mkv=01;35:*.webm=01;35:*.ogm=01;35:*.mp4=01;35:*.m4v=01;35:*.mp4v=01;35:*.vob=01;35:*.qt=01;35:*.nuv=01;35:*.wmv=01;35:*.asf=01;35:*.rm=01;35:*.rmvb=01;35:*.flc=01;35:*.avi=01;35:*.fli=01;35:*.flv=01;35:*.gl=01;35:*.dl=01;35:*.xcf=01;35:*.xwd=01;35:*.yuv=01;35:*.cgm=01;35:*.emf=01;35:*.ogv=01;35:*.ogx=01;35:*.aac=00;36:*.au=00;36:*.flac=00;36:*.m4a=00;36:*.mid=00;36:*.midi=00;36:*.mka=00;36:*.mp3=00;36:*.mpc=00;36:*.ogg=00;36:*.ra=00;36:*.wav=00;36:*.oga=00;36:*.opus=00;36:*.spx=00;36:*.xspf=00;36:
            SSH_CONNECTION=192.168.207.6 61754 192.168.207.243 22
            XDG_SESSION_CLASS=user
            TERM=xterm-256color
            USER=michel
            SHLVL=1
            LC_MESSAGES=en_US.UTF-8
            XDG_SESSION_ID=4
            LC_CTYPE=UTF-8
            XDG_RUNTIME_DIR=/run/user/1001
            SSH_CLIENT=192.168.207.6 61754 22
            LC_ALL=en_US.UTF-8
            PATH=/usr/local/bin:/usr/bin:/bin:/usr/local/games:/usr/games
            MAIL=/var/mail/michel
            SSH_TTY=/dev/pts/0
            _=/usr/bin/env
              sdetweil @michelw
              @michelw that was a window opened via the desktop right?
                michelw @sdetweil
                Not sure I understand what you mean. I’m doing all of this using ssh.
                  michelw @michelw
                    michelw @michelw
                    @michelw said in OrangePi Zero 2 installation issues:
                    Does this help?
                    michel@orangepizero2:~$ cat /etc/X11/xorg.conf.d/01-orangepi-defaults.conf
                    Section "Monitor"
                    	Identifier		"Monitor0"
                    	Option			"DPMS" "false"
                    EndSection
                    Section "ServerFlags"
                    	Option			"BlankTime" "0"
                    	Option			"StandbyTime" "0"
                    	Option			"SuspendTime" "0"
                    	Option			"OffTime" "0"
                    EndSection
                    # rotate the screen
                    Section "Device"
                        Identifier "default"
                        Driver "fbdev"
                        Option "Rotate" "CCW"
                    EndSection
                    I just added the rotation part and it rotated the desktop. The identifier seems to be " Monitor0"
                      sdetweil @michelw
                      @michelw ok, using command line
                      export DISPLAY=Monitor0
                      npm start
                      if that works then edit installers/mm.sh and add that export before the npm start
                      then pm2 start should work
                        michelw @sdetweil
                        npm start
                        michel@orangepizero2:~/MagicMirror$ export DISPLAY=Monitor0
                        michel@orangepizero2:~/MagicMirror$ npm start
                        [10.12.2021 23:32.41.725] [LOG]   Starting MagicMirror: v2.17.1
                        [10.12.2021 23:32.41.743] [LOG]   Loading config ...
                        [10.12.2021 23:32.41.757] [LOG]   Loading module helpers ...
                        [10.12.2021 23:32.41.762] [LOG]   No helper found for module: alert.
                        [10.12.2021 23:32.41.800] [LOG]   Initializing new module helper ...
                        [10.12.2021 23:32.41.804] [LOG]   Module helper loaded: updatenotification
                        [10.12.2021 23:32.41.807] [LOG]   No helper found for module: clock.
                        [10.12.2021 23:32.42.141] [LOG]   Initializing new module helper ...
                        [10.12.2021 23:32.42.144] [LOG]   Module helper loaded: calendar
                        [10.12.2021 23:32.42.146] [LOG]   No helper found for module: compliments.
                        [10.12.2021 23:32.42.149] [LOG]   No helper found for module: weather.
                        [10.12.2021 23:32.42.196] [LOG]   Initializing new module helper ...
                        [10.12.2021 23:32.42.198] [LOG]   Module helper loaded: newsfeed
                        [10.12.2021 23:32.42.200] [LOG]   All module helpers loaded.
                        [10.12.2021 23:32.42.420] [LOG]   Starting server on port 8080 ...
                        [10.12.2021 23:32.42.453] [LOG]   Server started ...
                        [10.12.2021 23:32.42.456] [LOG]   Connecting socket for: updatenotification
                        [10.12.2021 23:32.42.459] [LOG]   Connecting socket for: calendar
                        [10.12.2021 23:32.42.461] [LOG]   Starting node helper for: calendar
                        [10.12.2021 23:32.42.463] [LOG]   Connecting socket for: newsfeed
                        [10.12.2021 23:32.42.465] [LOG]   Starting node helper for: newsfeed
                        [10.12.2021 23:32.42.467] [LOG]   Sockets connected & modules started ...
                        The futex facility returned an unexpected error code.
                        /home/michel/MagicMirror/node_modules/electron/dist/electron exited with signal SIGABRT
                        npm ERR! errno 1
                        npm ERR!
                        npm ERR!     /home/michel/.npm/_logs/2021-12-10T23_32_42_717Z-debug.log
                          sdetweil @michelw
                          @michelw so, no
                            @michelw does chromium work?
                              @michelw armbian on pi
                              https://9to5linux.com/first-look-at-armbian-linux-on-raspberry-pi-4
                                michelw @sdetweil
                                Yes chromium seems to work. I installed vnc server since this SBC is in my mirror and I have now way to attach a mouse.
                                  michelw @sdetweil
                                  Not sure what you are trying to say by pointing me to the 9to5 article. Is there something relevant in there i missed? :)
                                    michelw @sdetweil
                                    I just played around with the DISPLAY parameter and when setting:
                                    michel@orangepizero2:~/MagicMirror$ export DISPLAY=:1
                                    [11.12.2021 09:15.21.920] [LOG]   Starting MagicMirror: v2.17.1
                                    [11.12.2021 09:15.21.937] [LOG]   Loading config ...
                                    [11.12.2021 09:15.21.952] [LOG]   Loading module helpers ...
                                    [11.12.2021 09:15.21.957] [LOG]   No helper found for module: alert.
                                    [11.12.2021 09:15.21.994] [LOG]   Initializing new module helper ...
                                    [11.12.2021 09:15.21.998] [LOG]   Module helper loaded: updatenotification
                                    [11.12.2021 09:15.22.001] [LOG]   No helper found for module: clock.
                                    [11.12.2021 09:15.22.350] [LOG]   Initializing new module helper ...
                                    [11.12.2021 09:15.22.353] [LOG]   Module helper loaded: calendar
                                    [11.12.2021 09:15.22.355] [LOG]   No helper found for module: compliments.
                                    [11.12.2021 09:15.22.358] [LOG]   No helper found for module: weather.
                                    [11.12.2021 09:15.22.404] [LOG]   Initializing new module helper ...
                                    [11.12.2021 09:15.22.406] [LOG]   Module helper loaded: newsfeed
                                    [11.12.2021 09:15.22.408] [LOG]   All module helpers loaded.
                                    [11.12.2021 09:15.22.633] [LOG]   Starting server on port 8080 ...
                                    [11.12.2021 09:15.22.669] [LOG]   Server started ...
                                    [11.12.2021 09:15.22.672] [LOG]   Connecting socket for: updatenotification
                                    [11.12.2021 09:15.22.676] [LOG]   Connecting socket for: calendar
                                    [11.12.2021 09:15.22.678] [LOG]   Starting node helper for: calendar
                                    [11.12.2021 09:15.22.680] [LOG]   Connecting socket for: newsfeed
                                    [11.12.2021 09:15.22.683] [LOG]   Starting node helper for: newsfeed
                                    [11.12.2021 09:15.22.685] [LOG]   Sockets connected & modules started ...
                                    [11.12.2021 09:15.23.736] [LOG]   Launching application.
                                    [11.12.2021 09:15.29.501] [LOG]   Create new calendarfetcher for url: http://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics - Interval: 300000
                                    [11.12.2021 09:15.29.593] [LOG]   Create new newsfetcher for url: https://rss.nytimes.com/services/xml/rss/nyt/HomePage.xml - Interval: 300000
                                    [11.12.2021 09:15.29.661] [INFO]  Checking git for module: default
                                    [11.12.2021 09:15.31.393] [INFO]  Calendar-Fetcher: Broadcasting 10 events.
                                    [11.12.2021 09:15.31.553] [INFO]  Newsfeed-Fetcher: Broadcasting 58 items.
                                    I get the magic mirror in the VNC session (but not on the monitor)
                                    So this seems to be related to the output somehow.
                                      sdetweil @michelw
                                      @michelw no, but I can try armbian on my pi now
                                        sdetweil @michelw
                                        @michelw and when u are using vnc, the monitor is showing the desktop, right?
                                          michelw
                                          Ah right.
                                          I would like to thank you very much for all your help.
                                          Went looking for a second hand Raspberry PI 4B 1G today and found one. A little expensive but at least I have something more compatible now so I at least can get the magicmirror running :)
                                          Still willing to help out (testing) if you would like to make your script Orange Pi Zero 2 compatible. That might help others.
                                            michelw @sdetweil
                                            Yes, that is correct.
                                            • 2 / 3
