    OrangePi Zero 2 installation issues
    41 Posts 2 Posters 15.3k Views 2 Watching
      michelw @michelw
      @michelw said in OrangePi Zero 2 installation issues:
      Not sure I understand what you mean. I’m doing all of this using ssh.
      Does this help?
      michel@orangepizero2:~$ cat /etc/X11/xorg.conf.d/01-orangepi-defaults.conf
      Section "Monitor"
      	Identifier		"Monitor0"
      	Option			"DPMS" "false"
      EndSection
      Section "ServerFlags"
      	Option			"BlankTime" "0"
      	Option			"StandbyTime" "0"
      	Option			"SuspendTime" "0"
      	Option			"OffTime" "0"
      EndSection
      # rotate the screen
      Section "Device"
          Identifier "default"
          Driver "fbdev"
          Option "Rotate" "CCW"
      EndSection
      I just added the rotation part and it rotated the desktop. The identifier seems to be " Monitor0"
        sdetweil @michelw
        @michelw ok, using command line
        export DISPLAY=Monitor0
        npm start
        if that works then edit installers/mm.sh and add that export before the npm start
        then pm2 start should work
        M 1 Reply Last reply
          michelw @sdetweil
          @sdetweil said in OrangePi Zero 2 installation issues:
          npm start
          michel@orangepizero2:~/MagicMirror$ export DISPLAY=Monitor0
          michel@orangepizero2:~/MagicMirror$ npm start
          > magicmirror@2.17.1 start /home/michel/MagicMirror
          [10.12.2021 23:32.41.725] [LOG]   Starting MagicMirror: v2.17.1
          [10.12.2021 23:32.41.743] [LOG]   Loading config ...
          [10.12.2021 23:32.41.757] [LOG]   Loading module helpers ...
          [10.12.2021 23:32.41.762] [LOG]   No helper found for module: alert.
          [10.12.2021 23:32.41.800] [LOG]   Initializing new module helper ...
          [10.12.2021 23:32.41.804] [LOG]   Module helper loaded: updatenotification
          [10.12.2021 23:32.41.807] [LOG]   No helper found for module: clock.
          [10.12.2021 23:32.42.141] [LOG]   Initializing new module helper ...
          [10.12.2021 23:32.42.144] [LOG]   Module helper loaded: calendar
          [10.12.2021 23:32.42.146] [LOG]   No helper found for module: compliments.
          [10.12.2021 23:32.42.149] [LOG]   No helper found for module: weather.
          [10.12.2021 23:32.42.196] [LOG]   Initializing new module helper ...
          [10.12.2021 23:32.42.198] [LOG]   Module helper loaded: newsfeed
          [10.12.2021 23:32.42.200] [LOG]   All module helpers loaded.
          [10.12.2021 23:32.42.420] [LOG]   Starting server on port 8080 ...
          [10.12.2021 23:32.42.453] [LOG]   Server started ...
          [10.12.2021 23:32.42.456] [LOG]   Connecting socket for: updatenotification
          [10.12.2021 23:32.42.459] [LOG]   Connecting socket for: calendar
          [10.12.2021 23:32.42.461] [LOG]   Starting node helper for: calendar
          [10.12.2021 23:32.42.463] [LOG]   Connecting socket for: newsfeed
          [10.12.2021 23:32.42.465] [LOG]   Starting node helper for: newsfeed
          [10.12.2021 23:32.42.467] [LOG]   Sockets connected & modules started ...
          The futex facility returned an unexpected error code.
          /home/michel/MagicMirror/node_modules/electron/dist/electron exited with signal SIGABRT
          npm ERR! code ELIFECYCLE
          npm ERR! errno 1
          npm ERR! magicmirror@2.17.1 start: `DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js`
          npm ERR! Exit status 1
          npm ERR!
          npm ERR! Failed at the magicmirror@2.17.1 start script.
          npm ERR!     /home/michel/.npm/_logs/2021-12-10T23_32_42_717Z-debug.log
            sdetweil @michelw
            @michelw so, no
              @michelw does chromium work?
              S M 2 Replies Last reply
                @michelw armbian on pi
                https://9to5linux.com/first-look-at-armbian-linux-on-raspberry-pi-4
                  michelw @sdetweil
                  Yes chromium seems to work. I installed vnc server since this SBC is in my mirror and I have now way to attach a mouse.
                    michelw @sdetweil
                    Not sure what you are trying to say by pointing me to the 9to5 article. Is there something relevant in there i missed? :)
                      michelw @sdetweil
                      I just played around with the DISPLAY parameter and when setting:
                      michel@orangepizero2:~/MagicMirror$ export DISPLAY=:1
                      [11.12.2021 09:15.21.920] [LOG]   Starting MagicMirror: v2.17.1
                      [11.12.2021 09:15.21.937] [LOG]   Loading config ...
                      [11.12.2021 09:15.21.952] [LOG]   Loading module helpers ...
                      [11.12.2021 09:15.21.957] [LOG]   No helper found for module: alert.
                      [11.12.2021 09:15.21.994] [LOG]   Initializing new module helper ...
                      [11.12.2021 09:15.21.998] [LOG]   Module helper loaded: updatenotification
                      [11.12.2021 09:15.22.001] [LOG]   No helper found for module: clock.
                      [11.12.2021 09:15.22.350] [LOG]   Initializing new module helper ...
                      [11.12.2021 09:15.22.353] [LOG]   Module helper loaded: calendar
                      [11.12.2021 09:15.22.355] [LOG]   No helper found for module: compliments.
                      [11.12.2021 09:15.22.358] [LOG]   No helper found for module: weather.
                      [11.12.2021 09:15.22.404] [LOG]   Initializing new module helper ...
                      [11.12.2021 09:15.22.406] [LOG]   Module helper loaded: newsfeed
                      [11.12.2021 09:15.22.408] [LOG]   All module helpers loaded.
                      [11.12.2021 09:15.22.633] [LOG]   Starting server on port 8080 ...
                      [11.12.2021 09:15.22.669] [LOG]   Server started ...
                      [11.12.2021 09:15.22.672] [LOG]   Connecting socket for: updatenotification
                      [11.12.2021 09:15.22.676] [LOG]   Connecting socket for: calendar
                      [11.12.2021 09:15.22.678] [LOG]   Starting node helper for: calendar
                      [11.12.2021 09:15.22.680] [LOG]   Connecting socket for: newsfeed
                      [11.12.2021 09:15.22.683] [LOG]   Starting node helper for: newsfeed
                      [11.12.2021 09:15.22.685] [LOG]   Sockets connected & modules started ...
                      [11.12.2021 09:15.23.736] [LOG]   Launching application.
                      [11.12.2021 09:15.29.501] [LOG]   Create new calendarfetcher for url: http://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics - Interval: 300000
                      [11.12.2021 09:15.29.593] [LOG]   Create new newsfetcher for url: https://rss.nytimes.com/services/xml/rss/nyt/HomePage.xml - Interval: 300000
                      [11.12.2021 09:15.29.661] [INFO]  Checking git for module: default
                      [11.12.2021 09:15.31.393] [INFO]  Calendar-Fetcher: Broadcasting 10 events.
                      [11.12.2021 09:15.31.553] [INFO]  Newsfeed-Fetcher: Broadcasting 58 items.
                      I get the magic mirror in the VNC session (but not on the monitor)
                      So this seems to be related to the output somehow.
                        sdetweil @michelw
                        @michelw no, but I can try armbian on my pi now
                          sdetweil @michelw
                          @michelw and when u are using vnc, the monitor is showing the desktop, right?
                            michelw
                            Ah right.
                            I would like to thank you very much for all your help.
                            Went looking for a second hand Raspberry PI 4B 1G today and found one. A little expensive but at least I have something more compatible now so I at least can get the magicmirror running :)
                            Still willing to help out (testing) if you would like to make your script Orange Pi Zero 2 compatible. That might help others.
                              michelw @sdetweil
                              Yes, that is correct.
                                sdetweil @michelw
                                @michelw it’s not the script, it’s the assumption by the mm startup, defined in package.json), that DISPLAY needs to be :0 if not already set.
                                  which image did u try?
                                  debian or Ubuntu?
                                    michelw
                                    I tried all of them, the latest I tried was : Orangepizero2_2.1.6_debian_buster_desktop_linux4.9.170.img
                                      sdetweil @michelw
                                      @michelw installed XFCE desktop armbian on pi4(4gb)…
                                      opened terminal on desktop, see
                                      DISPLAY=:0.0
                                      installing MM now
                                      DISPLAY not set on ssh session
                                      SLOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOW!
                                        michelw @sdetweil
                                        Any results?
                                          sdetweil @michelw
                                          @michelw no, looks like I picked a bad SD card.
                                          have to try again. hour or so
                                            @sdetweil armbian on pi worked as expected…
                                            i used the xfce image…
                                            • 2 / 3
