    Install-Problem
    4 Posts 2 Posters 3.1k Views 2 Watching
    • G Offline
      geetsche
      Hey Guys,
      i’m really fascinated by the magic mirror but however i can’t manage to install it.
      I have a brand new RP 3 with a SanDisk ultra 16 GB sd card
      i started the “normal” installation by using the install bash - there are already some small errors that something should be installed with -g (as you probably noticed i don’t really have a clue of the whole subject)
      Than later when i want to start the MagicMirror program there is this error in the terminal:
      "pi@raspberrypi:~ $ npm start
      npm ERR! Linux 4.4.34-v7+
      npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "start"
      npm ERR! node v6.9.4
      npm ERR! npm  v3.10.10
      npm ERR! path /home/pi/package.json
      npm ERR! code ENOENT
      npm ERR! errno -2
      npm ERR! syscall open
      npm ERR! enoent ENOENT: no such file or directory, open '/home/pi/package.json'
      npm ERR! enoent This is most likely not a problem with npm itself
      npm ERR! enoent and is related to npm not being able to find a file.
      npm ERR! enoent
      npm ERR!     /home/pi/npm-debug.log"
      and in the npm-debug.log it says:
      1 verbose cli [ '/usr/bin/nodejs', '/usr/bin/npm', 'start' ]
      2 info using npm@3.10.10
      3 info using node@v6.9.4
      4 verbose config Skipping project config: /home/pi/.npmrc. (matches userconfig)
      5 verbose stack Error: ENOENT: no such file or directory, open '/home/pi/package.json'
      5 verbose stack     at Error (native)
      6 verbose cwd /home/pi
      7 error Linux 4.4.34-v7+
      8 error argv "/usr/bin/nodejs" "/usr/bin/npm" "start"
      9 error node v6.9.4
      10 error npm  v3.10.10
      11 error path /home/pi/package.json
      12 error code ENOENT
      13 error errno -2
      14 error syscall open
      15 error enoent ENOENT: no such file or directory, open '/home/pi/package.json'
      16 error enoent ENOENT: no such file or directory, open '/home/pi/package.json'
      16 error enoent This is most likely not a problem with npm itself
      16 error enoent and is related to npm not being able to find a file.
      17 verbose exit [ -2, true ]
      so i really hope someone can help me out.
      thank you and greetings
      G
      Edited by moderator: Please use Markdown on code snippets for easier reading! :bow:
      • yawnsY Offline
        yawns Moderator
        cd MagicMirror
        npm start
        • G Offline
          geetsche
          oh that’s quite embarrassing :D thank you
          • yawnsY Offline
            yawns Moderator
            Sometimes it’s that easy. Enjoy the development of your magic mirror
