    Adding animated weather radar map
    10 Posts 7 Posters 5.2k Views 7 Watching
    • T Offline
      Tragus52
      Need help as a newbie to Magic Mirror. Would like to add an animated weather radar map to display, but have no real idea as to even get started. Having used Dakboard before they copy an annimation file from https://www.wunderground.com/maps/radar/current, and use the resulting url.
      Any help would be much appreciated.
      KamiSchamiK 1 Reply Last reply Reply Quote 0
      • KamiSchamiK Offline
        KamiSchami @Tragus52
        @tragus52 Hi, have you already tried an iframe module?
        Real programmers never work 9 to 5. If they are around at 9 AM, it’s because they were up all night.
        karsten13K 1 Reply Last reply Reply Quote 1
        • karsten13K Offline
          karsten13 @KamiSchami
          there is already a module for this https://github.com/jalibu/MMM-RAIN-MAP
          • T Offline
            Tragus52 @karsten13
            @karsten13 Thanks for the link, will give it a shot. Appreciate the help and support.
            • C Offline
              colel83
              I use MMM-EyeCandy on my mirror and put the url of the animated weather radar image as the source. I have the module update and fetch the latest radar image every 15 minutes.
              KamiSchamiK S 2 Replies Last reply Reply Quote 0
                KamiSchami @colel83
                @colel83 … the interval can be changed ? Greetings form Germany
                  sil3ntstorm @colel83
                  @colel83 Can you show us your config.js entry here?
                  plainbrokeP 1 Reply Last reply Reply Quote 0
                  • plainbrokeP Offline
                    plainbroke @sil3ntstorm
                    @colel83
                    Could you possibly show us your module configuration.
                      sdetweil @plainbroke
                      @plainbroke you know he posted 3 yrs ago
                      plainbrokeP 1 Reply Last reply Reply Quote 1
                        plainbroke @sdetweil
                        Yes, I was just hoping that he would respond since he was on here 30 days ago…
                        Worth a try at least…
