    Icons not showing on screen but webinterface ok
    10 Posts 4 Posters 3.2k Views 4 Watching
    • P Offline
      Pade2204
      Hi guys.
      Icons not showing on the normal mirror screen -> hdmi output on RaspberryPi (shows white boxes in feed)
      …but in webinterface it displays the icons fine.
      What could be wrong here?
      It is calendar feed from ics / upcoming soccer matches (icon show the sport, ie soccer, handball etc.)
        sdetweil @Pade2204
        @pade2204 the standard calendar doesn’t do the icons from the event info
        • P Offline
          Pade2204
          That doesnt sound good. Am I able to provent the feed from trying to show them, maybe?
          Mirror Output:
          Mirror webinterface:
          S luisestradaL 2 Replies Last reply Reply Quote 0
            sdetweil @Pade2204
            @pade2204 maybe u have to install the icons,
            I don’t know
              also. MagicMirror is a web interface, using the electron browser.
                joecas65
                Same problem here with module MMM-homeassistant-sensors. Icons not showing on Magic Mirror but web interface from chrome browser it’s ok.
                May be an electron problem ?
                  sdetweil @joecas65
                  @joecas65 open the developers wi Dow and check the path to the icons
                    joecas65 @sdetweil
                    @sdetweil said in Icons not showing on screen but webinterface ok:
                    Thanks for the answer, but why i have to check the path to the icons if it works from web interface ?
                      sdetweil @joecas65
                      @joecas65 i am just giving options to debug
                      MM s NOT a full browser like chrome/firefox/edge…
                      unless your module is using an iframe to display the exact page , it is getting data via some api (with possibly embedded links), and that data has to be manipulated usually to make it work…
                      • luisestradaL Offline
                        luisestrada @Pade2204
                        @Pade2204 said in Icons not showing on screen but webinterface ok:
                        Mirror Output:
                        Try this https://github.com/samuelngs/apple-emoji-linux
