    MMM-MyWastePickup date problem
    18 Posts 7 Posters 4.4k Views 7 Watching
      BravoOscar
      In 2021 I war running MagicMirror 2.16 with MMM-MyWastePickup and everything was working just fine.
      Here i 2022 I updated MagicMirror to 2.18 and updated MMM-MyWastePickup.
      I then updated the schedule_custom.csv with 2022 dates, and now it dosent work, it just says Loading. If i change dates in schedule_custom.csv to 2021 or 2023, then i says “no schdule”
      Have anybody a clue what to do?
      Is it something with MM 2.18?
      Working, says “No Schdule”
      Calendar,WeekStarting,GreenBin,Garbage,Recycling,YardWaste,ChristmasTree
      Custom,01/02/21,0,1,0,0,0
      Custom,01/07/21,0,1,0,0,0
      Custom,01/12/21,1,0,1,0,1
      Not Working, Says “Loading”
      Custom,01/02/22,0,1,0,0,0
      Custom,01/07/22,0,1,0,0,0
      Custom,01/12/22,1,0,1,0,1
        mayfield
        @bravooscar Check your csv file and make sure all the slashes and commas are in their right places. This happened to me last night with the MMM-MyGarbage module and I noticed some of my entries had commas in the dates instead of slashes.
          MyMirror @mayfield
          @mayfield
          I have the same problem.
          I just get “loading” …
          During npm install in “MMM-MyWastePickup” i get following:
          pi@MM3:~/MagicMirror $ cd modules/
          pi@MM3:~/MagicMirror/modules $ cd MMM-MyWastePickup/
          pi@MM3:~/MagicMirror/modules/MMM-MyWastePickup $ npm install
          up to date, audited 222 packages in 6s
          11 packages are looking for funding
            run `npm fund` for details
          3 moderate severity vulnerabilities
          To address all issues, run:
            npm audit fix
          Run `npm audit` for details.
          pi@MM3:~/MagicMirror/modules/MMM-MyWastePickup $ npm audit fix
          npm WARN audit fix ansi-regex@5.0.0 node_modules/npm/node_modules/cli-table3/node_modules/ansi-regex
          npm WARN audit fix ansi-regex@5.0.0 is a bundled dependency of
          npm WARN audit fix ansi-regex@5.0.0 npm@8.4.0 at node_modules/npm
          npm WARN audit fix ansi-regex@5.0.0 It cannot be fixed automatically.
          npm WARN audit fix ansi-regex@5.0.0 Check for updates to the npm package.
          npm WARN audit fix ansi-regex@3.0.0 node_modules/npm/node_modules/string-width/node_modules/ansi-regex
          npm WARN audit fix ansi-regex@3.0.0 is a bundled dependency of
          npm WARN audit fix ansi-regex@3.0.0 npm@8.4.0 at node_modules/npm
          npm WARN audit fix ansi-regex@3.0.0 It cannot be fixed automatically.
          npm WARN audit fix ansi-regex@3.0.0 Check for updates to the npm package.
          npm WARN audit fix strip-ansi@4.0.0 node_modules/npm/node_modules/string-width/node_modules/strip-ansi
          npm WARN audit fix strip-ansi@4.0.0 is a bundled dependency of
          npm WARN audit fix strip-ansi@4.0.0 npm@8.4.0 at node_modules/npm
          npm WARN audit fix strip-ansi@4.0.0 It cannot be fixed automatically.
          npm WARN audit fix strip-ansi@4.0.0 Check for updates to the npm package.
          npm WARN audit fix string-width@2.1.1 node_modules/npm/node_modules/string-width
          npm WARN audit fix string-width@2.1.1 is a bundled dependency of
          npm WARN audit fix string-width@2.1.1 npm@8.4.0 at node_modules/npm
          npm WARN audit fix string-width@2.1.1 It cannot be fixed automatically.
          npm WARN audit fix string-width@2.1.1 Check for updates to the npm package.
          # npm audit report
          ansi-regex  >2.1.1 <5.0.1
          Severity: moderate
           Inefficient Regular Expression Complexity in chalk/ansi-regex - https://github.com/advisories/GHSA-93q8-gq69-wqmw
          fix available via `npm audit fix`
            strip-ansi  4.0.0 - 5.2.0
            Depends on vulnerable versions of ansi-regex
              string-width  2.1.0 - 4.1.0
              Depends on vulnerable versions of strip-ansi
            npm audit fix
          How can i fix this?
          Did you solve your problem?
            MyMirror @MyMirror
            Anyone, any idea?
            Who else uses MyWastePickup with Bullseye/MM2.18?
            BR
            Jens
              sdetweil
              @mymirror you are on the wrong node version
              need 14 or preferably 16
              the steps outlined here might help
              https://github.com/MichMich/MagicMirror/issues/2772
              my mm install script does that as part of mm install
                MyMirror @sdetweil
                Hi Sam,
                i’ve downgraded node but without success. MMM-MyWastePickup is still “Loading”
                pi@MM3:~ $ node -v
                v16.13.2
                pi@MM3:~ $ npm -v
                8.1.2
                The content (test entries) of my schedule_custom.csv:
                Custom,02/07/22,0,1,0,0,0
                Custom,02/08/22,0,0,1,0,0
                Custom,03/02/22,0,1,0,0,0
                Custom,03/09/22,0,1,0,0,0
                Custom,03/10/22,1,0,0,0,0
                Aus der Config.js:
                                        module: "MMM-MyWastePickup",
                                        position: "top_center",
                  //                    header: "M&uuml;llabfuhr",
                                        header: "WASTE",
                                                collectionCalendar: "Custom",
                                                weeksToDisplay: "2"
                pm2 log:
                pi@MM3:~/MagicMirror $ pm2 log
                [TAILING] Tailing last 15 lines for [all] processes (change the value with --lines option)
                /home/pi/.pm2/pm2.log last 15 lines:
                PM2        | 2022-02-06T22:00:22: PM2 log: PM2 version          : 5.1.2
                PM2        | 2022-02-06T22:00:22: PM2 log: Node.js version      : 17.4.0
                PM2        | 2022-02-06T22:00:22: PM2 log: Current arch         : arm
                PM2        | 2022-02-06T22:00:22: PM2 log: PM2 home             : /home/pi/.pm2
                PM2        | 2022-02-06T22:00:22: PM2 log: PM2 PID file         : /home/pi/.pm2/pm2.pid
                PM2        | 2022-02-06T22:00:22: PM2 log: RPC socket file      : /home/pi/.pm2/rpc.sock
                PM2        | 2022-02-06T22:00:22: PM2 log: BUS socket file      : /home/pi/.pm2/pub.sock
                PM2        | 2022-02-06T22:00:22: PM2 log: Application log path : /home/pi/.pm2/logs
                PM2        | 2022-02-06T22:00:22: PM2 log: Worker Interval      : 30000
                PM2        | 2022-02-06T22:00:22: PM2 log: Process dump file    : /home/pi/.pm2/dump.pm2
                PM2        | 2022-02-06T22:00:22: PM2 log: Concurrent actions   : 2
                PM2        | 2022-02-06T22:00:22: PM2 log: SIGTERM timeout      : 1600
                PM2        | 2022-02-06T22:00:22: PM2 log: ===============================================================================
                PM2        | 2022-02-06T22:00:22: PM2 log: App [mm:0] starting in -fork mode-
                PM2        | 2022-02-06T22:00:22: PM2 log: App [mm:0] online
                /home/pi/.pm2/logs/MagicMirror-error.log last 15 lines:
                0|mm       |     at /home/pi/MagicMirror/modules/MMM-MyWastePickup/node_helper.js:36:9
                0|mm       |     at FSReqCallback.readFileAfterClose [as oncomplete] (node:internal/fs/read_file_context:68:3)
                0|mm       | [06.02.2022 21:37.41.484] [ERROR] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                0|mm       | [06.02.2022 21:37.41.485] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                0|mm       | [1468:0100/000000.525475:ERROR:connection.cc(66)] X connection error received.
                0|mm       | [07.02.2022 06:05.42.345] [WARN]  The module 'weatherforecast' is deprecated in favor of the 'weather'-module, please refer to the documentation for a migration path
                0|mm       | [1440:0207/060546.132881:ERROR:viz_main_impl.cc(161)] Exiting GPU process due to errors during initialization
                0|mm       | [1483:0207/060547.287531:ERROR:viz_main_impl.cc(161)] Exiting GPU process due to errors during initialization
                0|mm       | [1502:0207/060550.327609:ERROR:sandbox_linux.cc(376)] InitializeSandbox() called with multiple threads in process gpu-process.
                0|mm       | [07.02.2022 06:05.57.254] [ERROR] Whoops! There was an uncaught exception...
                0|mm       | [07.02.2022 06:05.57.264] [ERROR] TypeError: parse is not a function
                0|mm       | [07.02.2022 06:05.57.266] [ERROR] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                0|mm       | [07.02.2022 06:05.57.267] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                /home/pi/.pm2/logs/MagicMirror-out.log last 15 lines:
                0|mm       | [07.02.2022 06:05.42.349] [LOG]   Starting node helper for: newsfeed
                0|mm       | [07.02.2022 06:05.42.350] [LOG]   Sockets connected & modules started ...
                0|mm       | [07.02.2022 06:05.43.840] [LOG]   Launching application.
                0|mm       | [07.02.2022 06:05.56.764] [LOG]   Create new newsfetcher for url: https://rss.nytimes.com/services/xml/rss/nyt/HomePage.xml - Interval: 300000
                0|mm       | [07.02.2022 06:05.56.895] [INFO]  Checking git for module: MMM-MyWastePickup
                0|mm       | [07.02.2022 06:05.57.216] [INFO]  Checking git for module: MMM-Fuel
                0|mm       | [07.02.2022 06:05.57.294] [INFO]  Checking git for module: MMM-OpenWeather24Hours
                0|mm       | [07.02.2022 06:05.57.357] [INFO]  Checking git for module: default
                0|mm       | [07.02.2022 06:05.58.648] [INFO]  Newsfeed-Fetcher: Broadcasting 61 items.
                0|mm       | [07.02.2022 06:10.59.278] [INFO]  Newsfeed-Fetcher: Broadcasting 62 items.
                0|mm       | [07.02.2022 06:15.59.864] [INFO]  Newsfeed-Fetcher: Broadcasting 62 items.
                0|mm       | [07.02.2022 06:21.00.369] [INFO]  Newsfeed-Fetcher: Broadcasting 62 items.
                0|mm       | [07.02.2022 06:26.00.875] [INFO]  Newsfeed-Fetcher: Broadcasting 62 items.
                BR
                Jens
                M S 2 Replies Last reply Reply Quote 0
                  MyMirror @MyMirror
                  And the output of your script (test run):
                  pi@MM3:~/MagicMirror $ bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)"
                  No LSB modules are available.
                  doing test run = true, NO updates will be applied!
                  update log will be in /home/pi/MagicMirror/installers/upgrade.log
                  Check current Node installation ...
                  Node currently installed. Checking version number.
                  Minimum Node version: v16.9.1
                  Installed Node version: v16.13.2
                  No Node.js upgrade necessary.
                  Check current NPM installation ...
                  NPM currently installed. Checking version number.
                  Minimum npm version: V7.11.2
                  Installed npm version: V8.1.2
                  No npm upgrade necessary.
                  saving custom.css
                  upgrading from version 2.18.0 to 2.18.0
                  fetching latest revisions
                  there are 2 local files that are different than the master repo
                     installers/mm.sh
                     package.json
                  do you want to save these files for later   (Y/n)?
                  Checking for modules with removed libraries
                  	 require for request in module MMM-SystemStats not found in package.json package.json for module MMM-SystemStats
                  		  bypass installing request for module MMM-SystemStats , doing test run
                  processing dependency changes for active modules with package.json files
                  processing for module MMM-MyWastePickup please wait
                  skipped processing for MMM-MyWastePickup, doing test run
                  processing complete for module MMM-MyWastePickup
                  processing for module MMM-Fuel please wait
                  skipped processing for MMM-Fuel, doing test run
                  processing complete for module MMM-Fuel
                  restoring custom.css
                  test run, restoring files stashed
                    sdetweil @MyMirror
                    @mymirror said in MMM-MyWastePickup date problem:
                    ! There was an uncaught exception…
                    the module is having a problem, I would report that to the module GitHub page
                      mickecarlsson @BravoOscar
                      @bravooscar said in MMM-MyWastePickup date problem:
                      MMM-MyWastePickup
                      Make sure that you only have one (1) empty line after the last in the schedule_custom.csv. If you have more empty lines it will break.
                        MyMirror @mickecarlsson
                        @mickecarlsson
                        Thanks for your hint.
                        i actually had 2 blank lines at the end of the list.
                        But nothing changed, no matter if there were 2, 1 or no blank lines at the end of the list (not even after a restart of the MM or of the whole Pi.
                        Jens
