    MMM-MyWastePickup date problem
    18 Posts 7 Posters 5.1k Views 7 Watching
      BravoOscar
      In 2021 I war running MagicMirror 2.16 with MMM-MyWastePickup and everything was working just fine.
      Here i 2022 I updated MagicMirror to 2.18 and updated MMM-MyWastePickup.
      I then updated the schedule_custom.csv with 2022 dates, and now it dosent work, it just says Loading. If i change dates in schedule_custom.csv to 2021 or 2023, then i says “no schdule”
      Have anybody a clue what to do?
      Is it something with MM 2.18?
      Working, says “No Schdule”
      Calendar,WeekStarting,GreenBin,Garbage,Recycling,YardWaste,ChristmasTree
      Custom,01/02/21,0,1,0,0,0
      Custom,01/07/21,0,1,0,0,0
      Custom,01/12/21,1,0,1,0,1
      Not Working, Says “Loading”
      Custom,01/02/22,0,1,0,0,0
      Custom,01/07/22,0,1,0,0,0
      Custom,01/12/22,1,0,1,0,1
        mayfield
        @bravooscar Check your csv file and make sure all the slashes and commas are in their right places. This happened to me last night with the MMM-MyGarbage module and I noticed some of my entries had commas in the dates instead of slashes.
          MyMirror @mayfield
          @mayfield
          I have the same problem.
          I just get “loading” …
          During npm install in “MMM-MyWastePickup” i get following:
          pi@MM3:~/MagicMirror $ cd modules/
          pi@MM3:~/MagicMirror/modules $ cd MMM-MyWastePickup/
          pi@MM3:~/MagicMirror/modules/MMM-MyWastePickup $ npm install
          up to date, audited 222 packages in 6s
          11 packages are looking for funding
            run `npm fund` for details
          3 moderate severity vulnerabilities
          To address all issues, run:
            npm audit fix
          Run `npm audit` for details.
          pi@MM3:~/MagicMirror/modules/MMM-MyWastePickup $ npm audit fix
          npm WARN audit fix ansi-regex@5.0.0 node_modules/npm/node_modules/cli-table3/node_modules/ansi-regex
          npm WARN audit fix ansi-regex@5.0.0 is a bundled dependency of
          npm WARN audit fix ansi-regex@5.0.0 npm@8.4.0 at node_modules/npm
          npm WARN audit fix ansi-regex@5.0.0 It cannot be fixed automatically.
          npm WARN audit fix ansi-regex@5.0.0 Check for updates to the npm package.
          npm WARN audit fix ansi-regex@3.0.0 node_modules/npm/node_modules/string-width/node_modules/ansi-regex
          npm WARN audit fix ansi-regex@3.0.0 is a bundled dependency of
          npm WARN audit fix ansi-regex@3.0.0 npm@8.4.0 at node_modules/npm
          npm WARN audit fix ansi-regex@3.0.0 It cannot be fixed automatically.
          npm WARN audit fix ansi-regex@3.0.0 Check for updates to the npm package.
          npm WARN audit fix strip-ansi@4.0.0 node_modules/npm/node_modules/string-width/node_modules/strip-ansi
          npm WARN audit fix strip-ansi@4.0.0 is a bundled dependency of
          npm WARN audit fix strip-ansi@4.0.0 npm@8.4.0 at node_modules/npm
          npm WARN audit fix strip-ansi@4.0.0 It cannot be fixed automatically.
          npm WARN audit fix strip-ansi@4.0.0 Check for updates to the npm package.
          npm WARN audit fix string-width@2.1.1 node_modules/npm/node_modules/string-width
          npm WARN audit fix string-width@2.1.1 is a bundled dependency of
          npm WARN audit fix string-width@2.1.1 npm@8.4.0 at node_modules/npm
          npm WARN audit fix string-width@2.1.1 It cannot be fixed automatically.
          npm WARN audit fix string-width@2.1.1 Check for updates to the npm package.
          # npm audit report
          ansi-regex  >2.1.1 <5.0.1
          Severity: moderate
           Inefficient Regular Expression Complexity in chalk/ansi-regex - https://github.com/advisories/GHSA-93q8-gq69-wqmw
          fix available via `npm audit fix`
            strip-ansi  4.0.0 - 5.2.0
            Depends on vulnerable versions of ansi-regex
              string-width  2.1.0 - 4.1.0
              Depends on vulnerable versions of strip-ansi
            npm audit fix
          How can i fix this?
          Did you solve your problem?
            MyMirror @MyMirror
            Anyone, any idea?
            Who else uses MyWastePickup with Bullseye/MM2.18?
            BR
            Jens
              @mymirror you are on the wrong node version
              need 14 or preferably 16
              the steps outlined here might help
              https://github.com/MichMich/MagicMirror/issues/2772
              my mm install script does that as part of mm install
                MyMirror @sdetweil
                Hi Sam,
                i’ve downgraded node but without success. MMM-MyWastePickup is still “Loading”
                pi@MM3:~ $ node -v
                v16.13.2
                pi@MM3:~ $ npm -v
                8.1.2
                The content (test entries) of my schedule_custom.csv:
                Custom,02/07/22,0,1,0,0,0
                Custom,02/08/22,0,0,1,0,0
                Custom,03/02/22,0,1,0,0,0
                Custom,03/09/22,0,1,0,0,0
                Custom,03/10/22,1,0,0,0,0
                Aus der Config.js:
                                        module: "MMM-MyWastePickup",
                                        position: "top_center",
                  //                    header: "M&uuml;llabfuhr",
                                        header: "WASTE",
                                                collectionCalendar: "Custom",
                                                weeksToDisplay: "2"
                pm2 log:
                pi@MM3:~/MagicMirror $ pm2 log
                /home/pi/.pm2/pm2.log last 15 lines:
                PM2        | 2022-02-06T22:00:22: PM2 log: PM2 version          : 5.1.2
                PM2        | 2022-02-06T22:00:22: PM2 log: Node.js version      : 17.4.0
                PM2        | 2022-02-06T22:00:22: PM2 log: Current arch         : arm
                PM2        | 2022-02-06T22:00:22: PM2 log: PM2 home             : /home/pi/.pm2
                PM2        | 2022-02-06T22:00:22: PM2 log: PM2 PID file         : /home/pi/.pm2/pm2.pid
                PM2        | 2022-02-06T22:00:22: PM2 log: RPC socket file      : /home/pi/.pm2/rpc.sock
                PM2        | 2022-02-06T22:00:22: PM2 log: BUS socket file      : /home/pi/.pm2/pub.sock
                PM2        | 2022-02-06T22:00:22: PM2 log: Application log path : /home/pi/.pm2/logs
                PM2        | 2022-02-06T22:00:22: PM2 log: Worker Interval      : 30000
                PM2        | 2022-02-06T22:00:22: PM2 log: Process dump file    : /home/pi/.pm2/dump.pm2
                PM2        | 2022-02-06T22:00:22: PM2 log: Concurrent actions   : 2
                PM2        | 2022-02-06T22:00:22: PM2 log: SIGTERM timeout      : 1600
                PM2        | 2022-02-06T22:00:22: PM2 log: ===============================================================================
                PM2        | 2022-02-06T22:00:22: PM2 log: App [mm:0] starting in -fork mode-
                PM2        | 2022-02-06T22:00:22: PM2 log: App [mm:0] online
                /home/pi/.pm2/logs/MagicMirror-error.log last 15 lines:
                0|mm       |     at /home/pi/MagicMirror/modules/MMM-MyWastePickup/node_helper.js:36:9
                0|mm       |     at FSReqCallback.readFileAfterClose [as oncomplete] (node:internal/fs/read_file_context:68:3)
                0|mm       | [06.02.2022 21:37.41.484] [ERROR] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                0|mm       | [06.02.2022 21:37.41.485] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                0|mm       | [1468:0100/000000.525475:ERROR:connection.cc(66)] X connection error received.
                0|mm       | [07.02.2022 06:05.42.345] [WARN]  The module 'weatherforecast' is deprecated in favor of the 'weather'-module, please refer to the documentation for a migration path
                0|mm       | [1440:0207/060546.132881:ERROR:viz_main_impl.cc(161)] Exiting GPU process due to errors during initialization
                0|mm       | [1483:0207/060547.287531:ERROR:viz_main_impl.cc(161)] Exiting GPU process due to errors during initialization
                0|mm       | [1502:0207/060550.327609:ERROR:sandbox_linux.cc(376)] InitializeSandbox() called with multiple threads in process gpu-process.
                0|mm       | [07.02.2022 06:05.57.254] [ERROR] Whoops! There was an uncaught exception...
                0|mm       | [07.02.2022 06:05.57.264] [ERROR] TypeError: parse is not a function
                0|mm       | [07.02.2022 06:05.57.266] [ERROR] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                0|mm       | [07.02.2022 06:05.57.267] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                /home/pi/.pm2/logs/MagicMirror-out.log last 15 lines:
                0|mm       | [07.02.2022 06:05.42.349] [LOG]   Starting node helper for: newsfeed
                0|mm       | [07.02.2022 06:05.42.350] [LOG]   Sockets connected & modules started ...
                0|mm       | [07.02.2022 06:05.43.840] [LOG]   Launching application.
                0|mm       | [07.02.2022 06:05.56.764] [LOG]   Create new newsfetcher for url: https://rss.nytimes.com/services/xml/rss/nyt/HomePage.xml - Interval: 300000
                0|mm       | [07.02.2022 06:05.56.895] [INFO]  Checking git for module: MMM-MyWastePickup
                0|mm       | [07.02.2022 06:05.57.216] [INFO]  Checking git for module: MMM-Fuel
                0|mm       | [07.02.2022 06:05.57.294] [INFO]  Checking git for module: MMM-OpenWeather24Hours
                0|mm       | [07.02.2022 06:05.57.357] [INFO]  Checking git for module: default
                0|mm       | [07.02.2022 06:05.58.648] [INFO]  Newsfeed-Fetcher: Broadcasting 61 items.
                0|mm       | [07.02.2022 06:10.59.278] [INFO]  Newsfeed-Fetcher: Broadcasting 62 items.
                0|mm       | [07.02.2022 06:15.59.864] [INFO]  Newsfeed-Fetcher: Broadcasting 62 items.
                0|mm       | [07.02.2022 06:21.00.369] [INFO]  Newsfeed-Fetcher: Broadcasting 62 items.
                0|mm       | [07.02.2022 06:26.00.875] [INFO]  Newsfeed-Fetcher: Broadcasting 62 items.
                BR
                Jens
                M S 2 Replies Last reply Reply Quote 0
                  MyMirror @MyMirror
                  And the output of your script (test run):
                  pi@MM3:~/MagicMirror $ bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)"
                  No LSB modules are available.
                  Minimum Node version: v16.9.1
                  Installed Node version: v16.13.2
                  No Node.js upgrade necessary.
                  Minimum npm version: V7.11.2
                  Installed npm version: V8.1.2
                  No npm upgrade necessary.
                  saving custom.css
                  upgrading from version 2.18.0 to 2.18.0
                  fetching latest revisions
                  there are 2 local files that are different than the master repo
                     installers/mm.sh
                     package.json
                  do you want to save these files for later   (Y/n)?
                  	 require for request in module MMM-SystemStats not found in package.json package.json for module MMM-SystemStats
                  		  bypass installing request for module MMM-SystemStats , doing test run
                  processing for module MMM-MyWastePickup please wait
                  skipped processing for MMM-MyWastePickup, doing test run
                  processing complete for module MMM-MyWastePickup
                  processing for module MMM-Fuel please wait
                  skipped processing for MMM-Fuel, doing test run
                  processing complete for module MMM-Fuel
                  restoring custom.css
                  test run, restoring files stashed
                    sdetweil @MyMirror
                    @mymirror said in MMM-MyWastePickup date problem:
                    ! There was an uncaught exception…
                    the module is having a problem, I would report that to the module GitHub page
                      mickecarlsson @BravoOscar
                      @bravooscar said in MMM-MyWastePickup date problem:
                      MMM-MyWastePickup
                      Make sure that you only have one (1) empty line after the last in the schedule_custom.csv. If you have more empty lines it will break.
                        MyMirror @mickecarlsson
                        @mickecarlsson
                        Thanks for your hint.
                        i actually had 2 blank lines at the end of the list.
                        But nothing changed, no matter if there were 2, 1 or no blank lines at the end of the list (not even after a restart of the MM or of the whole Pi.
                        Jens
                          JohndB @MyMirror
                          @mymirror
                          Hi there,
                          I recently installed this module and found no problems.
                          Hereby a screenshot from the last lines in the csv file.f482bdba-87ed-40fb-9e4a-58c38f2e0755-image.png
                          and a screenshot to show you that it works;
                          Best regards,
                          John
                            MyMirror @JohndB
                            @johndb
                            ?? Without “Custom” in the beginning of every line?
                            As described here https://github.com/jclarke0000/MMM-MyWastePickup, however, it should look like this:
                            Custom,03/07/18,1,0,1,0,0
                            Custom,03/14/18,1,1,1,0,0
                            Custom,03/21/18,1,0,1,0,0
                            Custom,03/28/18,1,1,1,0,0
                            And then there is the error message (see above).
                            I have the version 2.18 of the MM running under Bullseye.
                            M J 2 Replies Last reply Reply Quote 0
                              MyMirror @MyMirror
                              @all
                              Who can help?
                              I think the problem is here:
                              Jens
                                JohndB @MyMirror
                                @mymirror
                                correct without “Custom” in the beginning of each line.
                                My first lines;
                                  MyMirror @JohndB
                                  @johndb
                                  Did not work on my site:
                                  Just shows “Loading …”
                                  My modules/MMM-MyWastePickup/schedule_custom.csv :
                                  02/09/22,0,1,0,0,0
                                  02/10/22,0,0,1,0,0
                                  03/02/22,0,1,0,0,0
                                  03/09/22,0,1,0,0,0
                                  03/10/22,1,0,0,0,0
                                  But on github (https://github.com/jclarke0000/MMM-MyWastePickup) is following:
                                  Using Your Own Custom Schedule
                                  If you live outside of Toronto and you’d like to use this module, you can create your own schedule to use with this module.
                                  First, in your config specify collectionCalendar: ‘Custom’.
                                  Create a CSV based on the following template:
                                  Add lines for each pickup date as needed
                                  I did so before Bullseye and everything was fine.
                                  Now with Bullseye, MM 2.18 and new node, npm i have a problem.
                                  Ideas?
                                    mr_cd @MyMirror
                                    @mymirror have you already found a solution?
                                      sdetweil @mr_cd
                                      @mr_cd can u show the config section from config.js?
                                      the code checks
                                      this.config.collectionCalendar
                                        this.scheduleCSVFile = this.path + "/schedule.csv";
                                          this.scheduleCustomCSVFile = this.path + "/schedule_custom.csv";
                                      if not found it sets to look for
                                      var scheduleFile = this.scheduleCSVFile;
                                            if (payload.collectionCalendar == "Custom") {
                                              scheduleFile = this.scheduleCustomCSVFile;
                                      if you don’t have the collectionCalendar set
                                      then it will use “schedule.csv”;
                                        MyMirror @mr_cd
                                        @mr_cd
                                        Not really. I took another module for now. Here I have no foliage or Christmas trees, but until that applies, it still takes a little.
        module: 'MMM-MyGarbage',
        position: 'top_left',
        header: 'M&uuml;llabfuhr',
        alert: 4,
        weeksToDisplay: 2,
        limitTo: 99,
        fade: true,
        dateFormat: "dddd D MMMM",
        fadePoint: 0.25
