    MMM-MyWastePickup date problem
    18 Posts 7 Posters 6.2k Views 7 Watching
      mayfield
      @bravooscar Check your csv file and make sure all the slashes and commas are in their right places. This happened to me last night with the MMM-MyGarbage module and I noticed some of my entries had commas in the dates instead of slashes.
      M 1 Reply Last reply
        MyMirror @mayfield
        @mayfield
        I have the same problem.
        I just get “loading” …
        During npm install in “MMM-MyWastePickup” i get following:
        pi@MM3:~/MagicMirror $ cd modules/
        pi@MM3:~/MagicMirror/modules $ cd MMM-MyWastePickup/
        pi@MM3:~/MagicMirror/modules/MMM-MyWastePickup $ npm install
        up to date, audited 222 packages in 6s
        11 packages are looking for funding
          run `npm fund` for details
        3 moderate severity vulnerabilities
        To address all issues, run:
          npm audit fix
        Run `npm audit` for details.
        pi@MM3:~/MagicMirror/modules/MMM-MyWastePickup $ npm audit fix
        npm WARN audit fix ansi-regex@5.0.0 node_modules/npm/node_modules/cli-table3/node_modules/ansi-regex
        npm WARN audit fix ansi-regex@5.0.0 is a bundled dependency of
        npm WARN audit fix ansi-regex@5.0.0 npm@8.4.0 at node_modules/npm
        npm WARN audit fix ansi-regex@5.0.0 It cannot be fixed automatically.
        npm WARN audit fix ansi-regex@5.0.0 Check for updates to the npm package.
        npm WARN audit fix ansi-regex@3.0.0 node_modules/npm/node_modules/string-width/node_modules/ansi-regex
        npm WARN audit fix ansi-regex@3.0.0 is a bundled dependency of
        npm WARN audit fix ansi-regex@3.0.0 npm@8.4.0 at node_modules/npm
        npm WARN audit fix ansi-regex@3.0.0 It cannot be fixed automatically.
        npm WARN audit fix ansi-regex@3.0.0 Check for updates to the npm package.
        npm WARN audit fix strip-ansi@4.0.0 node_modules/npm/node_modules/string-width/node_modules/strip-ansi
        npm WARN audit fix strip-ansi@4.0.0 is a bundled dependency of
        npm WARN audit fix strip-ansi@4.0.0 npm@8.4.0 at node_modules/npm
        npm WARN audit fix strip-ansi@4.0.0 It cannot be fixed automatically.
        npm WARN audit fix strip-ansi@4.0.0 Check for updates to the npm package.
        npm WARN audit fix string-width@2.1.1 node_modules/npm/node_modules/string-width
        npm WARN audit fix string-width@2.1.1 is a bundled dependency of
        npm WARN audit fix string-width@2.1.1 npm@8.4.0 at node_modules/npm
        npm WARN audit fix string-width@2.1.1 It cannot be fixed automatically.
        npm WARN audit fix string-width@2.1.1 Check for updates to the npm package.
        # npm audit report
        ansi-regex  >2.1.1 <5.0.1
        Severity: moderate
         Inefficient Regular Expression Complexity in chalk/ansi-regex - https://github.com/advisories/GHSA-93q8-gq69-wqmw
        fix available via `npm audit fix`
          strip-ansi  4.0.0 - 5.2.0
          Depends on vulnerable versions of ansi-regex
            string-width  2.1.0 - 4.1.0
            Depends on vulnerable versions of strip-ansi
          npm audit fix
        How can i fix this?
        Did you solve your problem?
          MyMirror @MyMirror
          Anyone, any idea?
          Who else uses MyWastePickup with Bullseye/MM2.18?
          BR
          Jens
            @mymirror you are on the wrong node version
            need 14 or preferably 16
            the steps outlined here might help
            https://github.com/MichMich/MagicMirror/issues/2772
            my mm install script does that as part of mm install
              MyMirror @sdetweil
              Hi Sam,
              i’ve downgraded node but without success. MMM-MyWastePickup is still “Loading”
              pi@MM3:~ $ node -v
              v16.13.2
              pi@MM3:~ $ npm -v
              8.1.2
              The content (test entries) of my schedule_custom.csv:
              Calendar,WeekStarting,GreenBin,Garbage,Recycling,YardWaste,ChristmasTree
              Custom,02/07/22,0,1,0,0,0
              Custom,02/08/22,0,0,1,0,0
              Custom,03/02/22,0,1,0,0,0
              Custom,03/09/22,0,1,0,0,0
              Custom,03/10/22,1,0,0,0,0
              Aus der Config.js:
                                      module: "MMM-MyWastePickup",
                                      position: "top_center",
                //                    header: "M&uuml;llabfuhr",
                                      header: "WASTE",
                                              collectionCalendar: "Custom",
                                              weeksToDisplay: "2"
              pm2 log:
              pi@MM3:~/MagicMirror $ pm2 log
              /home/pi/.pm2/pm2.log last 15 lines:
              PM2        | 2022-02-06T22:00:22: PM2 log: PM2 version          : 5.1.2
              PM2        | 2022-02-06T22:00:22: PM2 log: Node.js version      : 17.4.0
              PM2        | 2022-02-06T22:00:22: PM2 log: Current arch         : arm
              PM2        | 2022-02-06T22:00:22: PM2 log: PM2 home             : /home/pi/.pm2
              PM2        | 2022-02-06T22:00:22: PM2 log: PM2 PID file         : /home/pi/.pm2/pm2.pid
              PM2        | 2022-02-06T22:00:22: PM2 log: RPC socket file      : /home/pi/.pm2/rpc.sock
              PM2        | 2022-02-06T22:00:22: PM2 log: BUS socket file      : /home/pi/.pm2/pub.sock
              PM2        | 2022-02-06T22:00:22: PM2 log: Application log path : /home/pi/.pm2/logs
              PM2        | 2022-02-06T22:00:22: PM2 log: Worker Interval      : 30000
              PM2        | 2022-02-06T22:00:22: PM2 log: Process dump file    : /home/pi/.pm2/dump.pm2
              PM2        | 2022-02-06T22:00:22: PM2 log: Concurrent actions   : 2
              PM2        | 2022-02-06T22:00:22: PM2 log: SIGTERM timeout      : 1600
              PM2        | 2022-02-06T22:00:22: PM2 log: ===============================================================================
              PM2        | 2022-02-06T22:00:22: PM2 log: App [mm:0] starting in -fork mode-
              PM2        | 2022-02-06T22:00:22: PM2 log: App [mm:0] online
              /home/pi/.pm2/logs/MagicMirror-error.log last 15 lines:
              0|mm       |     at /home/pi/MagicMirror/modules/MMM-MyWastePickup/node_helper.js:36:9
              0|mm       |     at FSReqCallback.readFileAfterClose [as oncomplete] (node:internal/fs/read_file_context:68:3)
              0|mm       | [06.02.2022 21:37.41.484] [ERROR] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
              0|mm       | [06.02.2022 21:37.41.485] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
              0|mm       | [1468:0100/000000.525475:ERROR:connection.cc(66)] X connection error received.
              0|mm       | [07.02.2022 06:05.42.345] [WARN]  The module 'weatherforecast' is deprecated in favor of the 'weather'-module, please refer to the documentation for a migration path
              0|mm       | [1440:0207/060546.132881:ERROR:viz_main_impl.cc(161)] Exiting GPU process due to errors during initialization
              0|mm       | [1483:0207/060547.287531:ERROR:viz_main_impl.cc(161)] Exiting GPU process due to errors during initialization
              0|mm       | [1502:0207/060550.327609:ERROR:sandbox_linux.cc(376)] InitializeSandbox() called with multiple threads in process gpu-process.
              0|mm       | [07.02.2022 06:05.57.254] [ERROR] Whoops! There was an uncaught exception...
              0|mm       | [07.02.2022 06:05.57.264] [ERROR] TypeError: parse is not a function
              0|mm       | [07.02.2022 06:05.57.266] [ERROR] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
              0|mm       | [07.02.2022 06:05.57.267] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
              /home/pi/.pm2/logs/MagicMirror-out.log last 15 lines:
              0|mm       | [07.02.2022 06:05.42.349] [LOG]   Starting node helper for: newsfeed
              0|mm       | [07.02.2022 06:05.42.350] [LOG]   Sockets connected & modules started ...
              0|mm       | [07.02.2022 06:05.43.840] [LOG]   Launching application.
              0|mm       | [07.02.2022 06:05.56.764] [LOG]   Create new newsfetcher for url: https://rss.nytimes.com/services/xml/rss/nyt/HomePage.xml - Interval: 300000
              0|mm       | [07.02.2022 06:05.56.895] [INFO]  Checking git for module: MMM-MyWastePickup
              0|mm       | [07.02.2022 06:05.57.216] [INFO]  Checking git for module: MMM-Fuel
              0|mm       | [07.02.2022 06:05.57.294] [INFO]  Checking git for module: MMM-OpenWeather24Hours
              0|mm       | [07.02.2022 06:05.57.357] [INFO]  Checking git for module: default
              0|mm       | [07.02.2022 06:05.58.648] [INFO]  Newsfeed-Fetcher: Broadcasting 61 items.
              0|mm       | [07.02.2022 06:10.59.278] [INFO]  Newsfeed-Fetcher: Broadcasting 62 items.
              0|mm       | [07.02.2022 06:15.59.864] [INFO]  Newsfeed-Fetcher: Broadcasting 62 items.
              0|mm       | [07.02.2022 06:21.00.369] [INFO]  Newsfeed-Fetcher: Broadcasting 62 items.
              0|mm       | [07.02.2022 06:26.00.875] [INFO]  Newsfeed-Fetcher: Broadcasting 62 items.
              BR
              Jens
              M S 2 Replies Last reply
                MyMirror @MyMirror
                And the output of your script (test run):
                pi@MM3:~/MagicMirror $ bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)"
                No LSB modules are available.
                Minimum Node version: v16.9.1
                Installed Node version: v16.13.2
                No Node.js upgrade necessary.
                Minimum npm version: V7.11.2
                Installed npm version: V8.1.2
                No npm upgrade necessary.
                saving custom.css
                upgrading from version 2.18.0 to 2.18.0
                fetching latest revisions
                there are 2 local files that are different than the master repo
                   installers/mm.sh
                   package.json
                do you want to save these files for later   (Y/n)?
                	 require for request in module MMM-SystemStats not found in package.json package.json for module MMM-SystemStats
                		  bypass installing request for module MMM-SystemStats , doing test run
                processing for module MMM-MyWastePickup please wait
                skipped processing for MMM-MyWastePickup, doing test run
                processing complete for module MMM-MyWastePickup
                processing for module MMM-Fuel please wait
                skipped processing for MMM-Fuel, doing test run
                processing complete for module MMM-Fuel
                restoring custom.css
                test run, restoring files stashed
                  sdetweil @MyMirror
                  @mymirror said in MMM-MyWastePickup date problem:
                  ! There was an uncaught exception…
                  the module is having a problem, I would report that to the module GitHub page
                    mickecarlsson @BravoOscar
                    @bravooscar said in MMM-MyWastePickup date problem:
                    MMM-MyWastePickup
                    Make sure that you only have one (1) empty line after the last in the schedule_custom.csv. If you have more empty lines it will break.
                      MyMirror @mickecarlsson
                      @mickecarlsson
                      Thanks for your hint.
                      i actually had 2 blank lines at the end of the list.
                      But nothing changed, no matter if there were 2, 1 or no blank lines at the end of the list (not even after a restart of the MM or of the whole Pi.
                      Jens
                      J 1 Reply Last reply
                        JohndB @MyMirror
                        @mymirror
                        Hi there,
                        I recently installed this module and found no problems.
                        Hereby a screenshot from the last lines in the csv file.f482bdba-87ed-40fb-9e4a-58c38f2e0755-image.png
                        and a screenshot to show you that it works;
                        Best regards,
                        John
                          MyMirror @JohndB
                          @johndb
                          ?? Without “Custom” in the beginning of every line?
                          As described here https://github.com/jclarke0000/MMM-MyWastePickup, however, it should look like this:
                          Custom,03/07/18,1,0,1,0,0
                          Custom,03/14/18,1,1,1,0,0
                          Custom,03/21/18,1,0,1,0,0
                          Custom,03/28/18,1,1,1,0,0
                          And then there is the error message (see above).
                          I have the version 2.18 of the MM running under Bullseye.
                          M J 2 Replies Last reply
                            MyMirror @MyMirror
                            @all
                            Who can help?
                            I think the problem is here:
                            Jens
                              JohndB @MyMirror
                              @mymirror
                              correct without “Custom” in the beginning of each line.
                              My first lines;
                                MyMirror @JohndB
                                @johndb
                                Did not work on my site:
                                Just shows “Loading …”
                                My modules/MMM-MyWastePickup/schedule_custom.csv :
                                02/09/22,0,1,0,0,0
                                02/10/22,0,0,1,0,0
                                03/02/22,0,1,0,0,0
                                03/09/22,0,1,0,0,0
                                03/10/22,1,0,0,0,0
                                But on github (https://github.com/jclarke0000/MMM-MyWastePickup) is following:
                                Using Your Own Custom Schedule
                                If you live outside of Toronto and you’d like to use this module, you can create your own schedule to use with this module.
                                First, in your config specify collectionCalendar: ‘Custom’.
                                Create a CSV based on the following template:
                                Add lines for each pickup date as needed
                                I did so before Bullseye and everything was fine.
                                Now with Bullseye, MM 2.18 and new node, npm i have a problem.
                                Ideas?
                                  mr_cd @MyMirror
                                  @mymirror have you already found a solution?
                                  S M 2 Replies Last reply
                                    sdetweil @mr_cd
                                    @mr_cd can u show the config section from config.js?
                                    the code checks
                                    this.config.collectionCalendar
                                      this.scheduleCSVFile = this.path + "/schedule.csv";
                                        this.scheduleCustomCSVFile = this.path + "/schedule_custom.csv";
                                    if not found it sets to look for
                                    var scheduleFile = this.scheduleCSVFile;
                                          if (payload.collectionCalendar == "Custom") {
                                            scheduleFile = this.scheduleCustomCSVFile;
                                    if you don’t have the collectionCalendar set
                                    then it will use “schedule.csv”;
                                      MyMirror @mr_cd
                                      @mr_cd
                                      Not really. I took another module for now. Here I have no foliage or Christmas trees, but until that applies, it still takes a little.
                                                              module: 'MMM-MyGarbage',
                                                              position: 'top_left',
                                                              header: 'M&uuml;llabfuhr',
        alert: 4,
        weeksToDisplay: 2,
        limitTo: 99,
        fade: true,
        dateFormat: "dddd D MMMM",
        fadePoint: 0.25
