    MMM-MyWastePickup date problem
    18 Posts 7 Posters 6.2k Views 7 Watching
      @mymirror you are on the wrong node version
      need 14 or preferably 16
      the steps outlined here might help
      https://github.com/MichMich/MagicMirror/issues/2772
      my mm install script does that as part of mm install
      M 1 Reply Last reply
        MyMirror @sdetweil
        Hi Sam,
        i’ve downgraded node but without success. MMM-MyWastePickup is still “Loading”
        pi@MM3:~ $ node -v
        v16.13.2
        pi@MM3:~ $ npm -v
        8.1.2
        The content (test entries) of my schedule_custom.csv:
        Calendar,WeekStarting,GreenBin,Garbage,Recycling,YardWaste,ChristmasTree
        Custom,02/07/22,0,1,0,0,0
        Custom,02/08/22,0,0,1,0,0
        Custom,03/02/22,0,1,0,0,0
        Custom,03/09/22,0,1,0,0,0
        Custom,03/10/22,1,0,0,0,0
        Aus der Config.js:
                                module: "MMM-MyWastePickup",
                                position: "top_center",
          //                    header: "Müllabfuhr",
                                header: "WASTE",
                                        collectionCalendar: "Custom",
                                        weeksToDisplay: "2"
        pm2 log:
        pi@MM3:~/MagicMirror $ pm2 log
        /home/pi/.pm2/pm2.log last 15 lines:
        PM2        | 2022-02-06T22:00:22: PM2 log: PM2 version          : 5.1.2
        PM2        | 2022-02-06T22:00:22: PM2 log: Node.js version      : 17.4.0
        PM2        | 2022-02-06T22:00:22: PM2 log: Current arch         : arm
        PM2        | 2022-02-06T22:00:22: PM2 log: PM2 home             : /home/pi/.pm2
        PM2        | 2022-02-06T22:00:22: PM2 log: PM2 PID file         : /home/pi/.pm2/pm2.pid
        PM2        | 2022-02-06T22:00:22: PM2 log: RPC socket file      : /home/pi/.pm2/rpc.sock
        PM2        | 2022-02-06T22:00:22: PM2 log: BUS socket file      : /home/pi/.pm2/pub.sock
        PM2        | 2022-02-06T22:00:22: PM2 log: Application log path : /home/pi/.pm2/logs
        PM2        | 2022-02-06T22:00:22: PM2 log: Worker Interval      : 30000
        PM2        | 2022-02-06T22:00:22: PM2 log: Process dump file    : /home/pi/.pm2/dump.pm2
        PM2        | 2022-02-06T22:00:22: PM2 log: Concurrent actions   : 2
        PM2        | 2022-02-06T22:00:22: PM2 log: SIGTERM timeout      : 1600
        PM2        | 2022-02-06T22:00:22: PM2 log: ===============================================================================
        PM2        | 2022-02-06T22:00:22: PM2 log: App [mm:0] starting in -fork mode-
        PM2        | 2022-02-06T22:00:22: PM2 log: App [mm:0] online
        /home/pi/.pm2/logs/MagicMirror-error.log last 15 lines:
        0|mm       |     at /home/pi/MagicMirror/modules/MMM-MyWastePickup/node_helper.js:36:9
        0|mm       |     at FSReqCallback.readFileAfterClose [as oncomplete] (node:internal/fs/read_file_context:68:3)
        0|mm       | [06.02.2022 21:37.41.484] [ERROR] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
        0|mm       | [06.02.2022 21:37.41.485] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
        0|mm       | [1468:0100/000000.525475:ERROR:connection.cc(66)] X connection error received.
        0|mm       | [07.02.2022 06:05.42.345] [WARN]  The module 'weatherforecast' is deprecated in favor of the 'weather'-module, please refer to the documentation for a migration path
        0|mm       | [1440:0207/060546.132881:ERROR:viz_main_impl.cc(161)] Exiting GPU process due to errors during initialization
        0|mm       | [1483:0207/060547.287531:ERROR:viz_main_impl.cc(161)] Exiting GPU process due to errors during initialization
        0|mm       | [1502:0207/060550.327609:ERROR:sandbox_linux.cc(376)] InitializeSandbox() called with multiple threads in process gpu-process.
        0|mm       | [07.02.2022 06:05.57.254] [ERROR] Whoops! There was an uncaught exception...
        0|mm       | [07.02.2022 06:05.57.264] [ERROR] TypeError: parse is not a function
        0|mm       | [07.02.2022 06:05.57.266] [ERROR] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
        0|mm       | [07.02.2022 06:05.57.267] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
        /home/pi/.pm2/logs/MagicMirror-out.log last 15 lines:
        0|mm       | [07.02.2022 06:05.42.349] [LOG]   Starting node helper for: newsfeed
        0|mm       | [07.02.2022 06:05.42.350] [LOG]   Sockets connected & modules started ...
        0|mm       | [07.02.2022 06:05.43.840] [LOG]   Launching application.
        0|mm       | [07.02.2022 06:05.56.764] [LOG]   Create new newsfetcher for url: https://rss.nytimes.com/services/xml/rss/nyt/HomePage.xml - Interval: 300000
        0|mm       | [07.02.2022 06:05.56.895] [INFO]  Checking git for module: MMM-MyWastePickup
        0|mm       | [07.02.2022 06:05.57.216] [INFO]  Checking git for module: MMM-Fuel
        0|mm       | [07.02.2022 06:05.57.294] [INFO]  Checking git for module: MMM-OpenWeather24Hours
        0|mm       | [07.02.2022 06:05.57.357] [INFO]  Checking git for module: default
        0|mm       | [07.02.2022 06:05.58.648] [INFO]  Newsfeed-Fetcher: Broadcasting 61 items.
        0|mm       | [07.02.2022 06:10.59.278] [INFO]  Newsfeed-Fetcher: Broadcasting 62 items.
        0|mm       | [07.02.2022 06:15.59.864] [INFO]  Newsfeed-Fetcher: Broadcasting 62 items.
        0|mm       | [07.02.2022 06:21.00.369] [INFO]  Newsfeed-Fetcher: Broadcasting 62 items.
        0|mm       | [07.02.2022 06:26.00.875] [INFO]  Newsfeed-Fetcher: Broadcasting 62 items.
        BR
        Jens
        M S 2 Replies Last reply
          MyMirror @MyMirror
          And the output of your script (test run):
          pi@MM3:~/MagicMirror $ bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)"
          No LSB modules are available.
          Minimum Node version: v16.9.1
          Installed Node version: v16.13.2
          No Node.js upgrade necessary.
          Minimum npm version: V7.11.2
          Installed npm version: V8.1.2
          No npm upgrade necessary.
          saving custom.css
          upgrading from version 2.18.0 to 2.18.0
          fetching latest revisions
          there are 2 local files that are different than the master repo
             installers/mm.sh
             package.json
          do you want to save these files for later   (Y/n)?
          	 require for request in module MMM-SystemStats not found in package.json package.json for module MMM-SystemStats
          		  bypass installing request for module MMM-SystemStats , doing test run
          processing for module MMM-MyWastePickup please wait
          skipped processing for MMM-MyWastePickup, doing test run
          processing complete for module MMM-MyWastePickup
          processing for module MMM-Fuel please wait
          skipped processing for MMM-Fuel, doing test run
          processing complete for module MMM-Fuel
          restoring custom.css
          test run, restoring files stashed
            sdetweil @MyMirror
            @mymirror said in MMM-MyWastePickup date problem:
            ! There was an uncaught exception…
            the module is having a problem, I would report that to the module GitHub page
              mickecarlsson @BravoOscar
              @bravooscar said in MMM-MyWastePickup date problem:
              MMM-MyWastePickup
              Make sure that you only have one (1) empty line after the last in the schedule_custom.csv. If you have more empty lines it will break.
                MyMirror @mickecarlsson
                @mickecarlsson
                Thanks for your hint.
                i actually had 2 blank lines at the end of the list.
                But nothing changed, no matter if there were 2, 1 or no blank lines at the end of the list (not even after a restart of the MM or of the whole Pi.
                Jens
                J 1 Reply Last reply
                  JohndB @MyMirror
                  @mymirror
                  Hi there,
                  I recently installed this module and found no problems.
                  Hereby a screenshot from the last lines in the csv file.f482bdba-87ed-40fb-9e4a-58c38f2e0755-image.png
                  and a screenshot to show you that it works;
                  Best regards,
                  John
                    MyMirror @JohndB
                    @johndb
                    ?? Without “Custom” in the beginning of every line?
                    As described here https://github.com/jclarke0000/MMM-MyWastePickup, however, it should look like this:
                    Custom,03/07/18,1,0,1,0,0
                    Custom,03/14/18,1,1,1,0,0
                    Custom,03/21/18,1,0,1,0,0
                    Custom,03/28/18,1,1,1,0,0
                    And then there is the error message (see above).
                    I have the version 2.18 of the MM running under Bullseye.
                    M J 2 Replies Last reply
                      MyMirror @MyMirror
                      @all
                      Who can help?
                      I think the problem is here:
                      Jens
                        JohndB @MyMirror
                        @mymirror
                        correct without “Custom” in the beginning of each line.
                        My first lines;
                          MyMirror @JohndB
                          @johndb
                          Did not work on my site:
                          Just shows “Loading …”
                          My modules/MMM-MyWastePickup/schedule_custom.csv :
                          02/09/22,0,1,0,0,0
                          02/10/22,0,0,1,0,0
                          03/02/22,0,1,0,0,0
                          03/09/22,0,1,0,0,0
                          03/10/22,1,0,0,0,0
                          But on github (https://github.com/jclarke0000/MMM-MyWastePickup) is following:
                          Using Your Own Custom Schedule
                          If you live outside of Toronto and you’d like to use this module, you can create your own schedule to use with this module.
                          First, in your config specify collectionCalendar: ‘Custom’.
                          Create a CSV based on the following template:
                          Add lines for each pickup date as needed
                          I did so before Bullseye and everything was fine.
                          Now with Bullseye, MM 2.18 and new node, npm i have a problem.
                          Ideas?
                            mr_cd @MyMirror
                            @mymirror have you already found a solution?
                            S M 2 Replies Last reply
                              sdetweil @mr_cd
                              @mr_cd can u show the config section from config.js?
                              the code checks
                              this.config.collectionCalendar
                                this.scheduleCSVFile = this.path + "/schedule.csv";
                                  this.scheduleCustomCSVFile = this.path + "/schedule_custom.csv";
                              if not found it sets to look for
                              var scheduleFile = this.scheduleCSVFile;
                                    if (payload.collectionCalendar == "Custom") {
                                      scheduleFile = this.scheduleCustomCSVFile;
                              if you don’t have the collectionCalendar set
                              then it will use “schedule.csv”;
                                MyMirror @mr_cd
                                @mr_cd
                                Not really. I took another module for now. Here I have no foliage or Christmas trees, but until that applies, it still takes a little.
                                                        module: 'MMM-MyGarbage',
                                                        position: 'top_left',
                                                        header: 'Müllabfuhr',
        alert: 4,
        weeksToDisplay: 2,
        limitTo: 99,
        fade: true,
        dateFormat: "dddd D MMMM",
        fadePoint: 0.25
