    MMM-MyWastePickup date problem
    18 Posts 7 Posters 6.0k Views 7 Watching
      MyMirror @MyMirror
      And the output of your script (test run):
      pi@MM3:~/MagicMirror $ bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)"
      No LSB modules are available.
      Minimum Node version: v16.9.1
      Installed Node version: v16.13.2
      No Node.js upgrade necessary.
      Minimum npm version: V7.11.2
      Installed npm version: V8.1.2
      No npm upgrade necessary.
      saving custom.css
      upgrading from version 2.18.0 to 2.18.0
      fetching latest revisions
      there are 2 local files that are different than the master repo
         installers/mm.sh
         package.json
      do you want to save these files for later   (Y/n)?
      	 require for request in module MMM-SystemStats not found in package.json package.json for module MMM-SystemStats
      		  bypass installing request for module MMM-SystemStats , doing test run
      processing for module MMM-MyWastePickup please wait
      skipped processing for MMM-MyWastePickup, doing test run
      processing complete for module MMM-MyWastePickup
      processing for module MMM-Fuel please wait
      skipped processing for MMM-Fuel, doing test run
      processing complete for module MMM-Fuel
      restoring custom.css
      test run, restoring files stashed
        sdetweil @MyMirror
        @mymirror said in MMM-MyWastePickup date problem:
        ! There was an uncaught exception…
        0|mm | [07.02.2022 06:05.57.264] [ERROR] TypeError: parse is not a function
        0|mm | at /home/pi/MagicMirror/modules/MMM-MyWastePickup/node_helper.js:36:9
        the module is having a problem, I would report that to the module GitHub page
          mickecarlsson @BravoOscar
          @bravooscar said in MMM-MyWastePickup date problem:
          MMM-MyWastePickup
          Make sure that you only have one (1) empty line after the last in the schedule_custom.csv. If you have more empty lines it will break.
            MyMirror @mickecarlsson
            @mickecarlsson
            Thanks for your hint.
            i actually had 2 blank lines at the end of the list.
            But nothing changed, no matter if there were 2, 1 or no blank lines at the end of the list (not even after a restart of the MM or of the whole Pi.
            Jens
              JohndB @MyMirror
              @mymirror
              Hi there,
              I recently installed this module and found no problems.
              Hereby a screenshot from the last lines in the csv file.f482bdba-87ed-40fb-9e4a-58c38f2e0755-image.png
              and a screenshot to show you that it works;
              Best regards,
              John
                MyMirror @JohndB
                @johndb
                ?? Without “Custom” in the beginning of every line?
                As described here https://github.com/jclarke0000/MMM-MyWastePickup, however, it should look like this:
                Calendar,WeekStarting,GreenBin,Garbage,Recycling,YardWaste,ChristmasTree
                Custom,03/07/18,1,0,1,0,0
                Custom,03/14/18,1,1,1,0,0
                Custom,03/21/18,1,0,1,0,0
                Custom,03/28/18,1,1,1,0,0
                And then there is the error message (see above).
                I have the version 2.18 of the MM running under Bullseye.
                M J 2 Replies Last reply Reply Quote 0
                  MyMirror @MyMirror
                  @all
                  Who can help?
                  I think the problem is here:
                  Jens
                    JohndB @MyMirror
                    @mymirror
                    correct without “Custom” in the beginning of each line.
                    My first lines;
                      MyMirror @JohndB
                      @johndb
                      Did not work on my site:
                      Just shows “Loading …”
                      My modules/MMM-MyWastePickup/schedule_custom.csv :
                      02/09/22,0,1,0,0,0
                      02/10/22,0,0,1,0,0
                      03/02/22,0,1,0,0,0
                      03/09/22,0,1,0,0,0
                      03/10/22,1,0,0,0,0
                      But on github (https://github.com/jclarke0000/MMM-MyWastePickup) is following:
                      Using Your Own Custom Schedule
                      If you live outside of Toronto and you’d like to use this module, you can create your own schedule to use with this module.
                      First, in your config specify collectionCalendar: ‘Custom’.
                      Create a CSV based on the following template:
                      Add lines for each pickup date as needed
                      I did so before Bullseye and everything was fine.
                      Now with Bullseye, MM 2.18 and new node, npm i have a problem.
                      Ideas?
                        mr_cd @MyMirror
                        @mymirror have you already found a solution?
                          sdetweil @mr_cd
                          @mr_cd can u show the config section from config.js?
                          the code checks
                          this.config.collectionCalendar
                            this.scheduleCSVFile = this.path + "/schedule.csv";
                              this.scheduleCustomCSVFile = this.path + "/schedule_custom.csv";
                          if not found it sets to look for
                          var scheduleFile = this.scheduleCSVFile;
                                if (payload.collectionCalendar == "Custom") {
                                  scheduleFile = this.scheduleCustomCSVFile;
                          if you don’t have the collectionCalendar set
                          then it will use “schedule.csv”;
                            MyMirror @mr_cd
                            @mr_cd
                            Not really. I took another module for now. Here I have no foliage or Christmas trees, but until that applies, it still takes a little.
                                                    module: 'MMM-MyGarbage',
                                                    position: 'top_left',
                                                    header: 'Müllabfuhr',
                                                            alert: 4,
                                                            weeksToDisplay: 2,
                                                            limitTo: 99,
                                                            fade: true,
                                                            dateFormat: "dddd D MMMM",
                                                            fadePoint: 0.25
