    v2.18.0 update gave black screen, then nothing.
    73 Posts 4 Posters 37.5k Views 4 Watching
      sdetweil @Richard238
      @richard238 ok, fun times…
      so, do
      cd ~
      mv MagicMirror MagicMirror.save
      git clone  https://github.com/MichMich/MagicMirror.git
      cd MagicMirror
      npm install --only=prod
      cd config
      cp config.js.sample config.js
      cd ..
      then npm start
        Richard238 @sdetweil
        Clean install - works perfectly! :)
        pi@magicmirror:~/MagicMirror $ cd config
        pi@magicmirror:~/MagicMirror/config $ cp config.js.sample config.js
        pi@magicmirror:~/MagicMirror/config $ cd ..
        pi@magicmirror:~/MagicMirror $ npm start
        > magicmirror@2.18.0 start
        [06.01.2022 16:30.01.197] [LOG]   Starting MagicMirror: v2.18.0
        [06.01.2022 16:30.01.222] [LOG]   Loading config ...
        [06.01.2022 16:30.01.238] [LOG]   Loading module helpers ...
        [06.01.2022 16:30.01.243] [LOG]   No helper found for module: alert.
        [06.01.2022 16:30.01.307] [LOG]   Initializing new module helper ...
        [06.01.2022 16:30.01.311] [LOG]   Module helper loaded: updatenotification
        [06.01.2022 16:30.01.315] [LOG]   No helper found for module: clock.
        [06.01.2022 16:30.01.765] [LOG]   Initializing new module helper ...
        [06.01.2022 16:30.01.768] [LOG]   Module helper loaded: calendar
        [06.01.2022 16:30.01.771] [LOG]   No helper found for module: compliments.
        [06.01.2022 16:30.01.773] [LOG]   No helper found for module: weather.
        [06.01.2022 16:30.01.843] [LOG]   Initializing new module helper ...
        [06.01.2022 16:30.01.845] [LOG]   Module helper loaded: newsfeed
        [06.01.2022 16:30.01.848] [LOG]   All module helpers loaded.
        [06.01.2022 16:30.02.152] [LOG]   Starting server on port 8080 ...
        [06.01.2022 16:30.02.183] [LOG]   Server started ...
        [06.01.2022 16:30.02.185] [LOG]   Connecting socket for: updatenotification
        [06.01.2022 16:30.02.187] [LOG]   Starting module helper: updatenotification
        [06.01.2022 16:30.02.189] [LOG]   Connecting socket for: calendar
        [06.01.2022 16:30.02.190] [LOG]   Starting node helper for: calendar
        [06.01.2022 16:30.02.191] [LOG]   Connecting socket for: newsfeed
        [06.01.2022 16:30.02.192] [LOG]   Starting node helper for: newsfeed
        [06.01.2022 16:30.02.193] [LOG]   Sockets connected & modules started ...
        [06.01.2022 16:30.02.845] [LOG]   Launching application.
        [8846:0106/163005.246382:ERROR:viz_main_impl.cc(161)] Exiting GPU process due to errors during initialization
        [8886:0106/163005.631441:ERROR:sandbox_linux.cc(376)] InitializeSandbox() called with multiple threads in process gpu-process.
        [06.01.2022 16:30.12.077] [LOG]   Create new calendarfetcher for url: http://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics - Interval: 300000
        [06.01.2022 16:30.12.157] [LOG]   Create new newsfetcher for url: https://rss.nytimes.com/services/xml/rss/nyt/HomePage.xml - Interval: 300000
        [06.01.2022 16:30.12.258] [INFO]  Checking git for module: default
        [06.01.2022 16:30.13.590] [INFO]  Calendar-Fetcher: Broadcasting 10 events.
        [06.01.2022 16:30.13.638] [INFO]  Newsfeed-Fetcher: Broadcasting 64 items.
          @richard238 ok!.. run this to get rid of the sandbox problem
          bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/fixsandbox)"
          then
          cd ~/MagicMirror/modules
          # save the new default modules folder
          mv default default.new
          cd ..
          # copy all the modules from old install (incl default) preserve ownership and dates, need sudo to copy git info
          sudo cp -r -p ~/MagicMirror.save/modules/* modules
          cd modules
          # remove the copied default modules
          rm -rf default
          # restore the saved default
          mv default.new default
          copy your full function config.js to MagicMirror/config
          and try it out
          cd ~/MagicMirror
          npm start
            pi@magicmirror:~ $ cd ~/MagicMirror/modules
            pi@magicmirror:~/MagicMirror/modules $ mv default default.new
            pi@magicmirror:~/MagicMirror/modules $ sudo cp -r -p ~/MagicMirror.save/modules/* modules
            cp: target 'modules' is not a directory
            Tried it without the space…
            pi@magicmirror:~/MagicMirror/modules $ sudo cp -r -p ~/MagicMirror.save/modules/*modules
            cp: missing destination file operand after '/home/pi/MagicMirror.save/modules/*modules'
            Try 'cp --help' for more information.
              Richard238 @Richard238
              @richard238
              I have to leave shortly Sam.
              Thank you for all your help with this today, I’ll try again tomorrow.
              Richard.
                @richard238 ok
                you forgot the cd …
                cd ..
                  Trying to rename config.js to sample,
                  Error when getting information for file “/home/pi/MagicMirror/config/config.js”: No such file or directory
                  Error renaming file /home/pi/MagicMirror/config/config.js: No such file or directory
                  Yet I can see it, I can query it for permissions…
                  Back tomorrow.
                  Richard.
                    @richard238 said in v2.18.0 update gave black screen, then nothing.:
                    you need to copy from save
                    cd ~/MagicMirror.save/config
                    cp -p config.js ~/Magicmirror/config
                      Good morning Sam.
                      Tried that late yesterday, and yes, it works.
                      And this morning, I copied
                      custom.css
                      from
                      /home/pi/MagicMirror.save/css
                      to
                      /home/pi/MagicMirror/css
                      This too is working perfectly.
                      Is there anything else to do, housekeeping maybe, or is that it now?
                        @richard238 if everything is running ok then I think you are done, and can delete the
                        MagicMirror.save folder
                        • 6
                        • 7
                        • 8
                        • 6 / 8
