    v2.18.0 update gave black screen, then nothing.
    73 Posts 4 Posters 45.3k Views 4 Watching
      Richard238 @sdetweil
      what is that? I’m not aware of any code in config for calendar
      No idea, thought it had always been there. I’m not much of a coder, as I’m sure you can tell.
      // added
      pi@magicmirror:~/MagicMirror $ pm2 start MagicMirror
      [PM2] Applying action restartProcessId on app [MagicMirror](ids: [ 0 ])
      [PM2] [MagicMirror](0) ✓
      [PM2] Process successfully started
      │ id │ name               │ mode     │ ↺    │ status    │ cpu      │ memory   │
      │ 0  │ MagicMirror        │ fork     │ 0    │ online    │ 0%       │ 2.4mb    │
      pi@magicmirror:~/MagicMirror $ pm2 logs --lines=50
      [TAILING] Tailing last 50 lines for [all] processes (change the value with --lines option)
      /home/pi/.pm2/pm2.log last 50 lines:
      PM2        | 2022-01-06T14:24:56: PM2 log: App [MagicMirror:0] starting in -fork mode-
      PM2        | 2022-01-06T14:24:56: PM2 log: App [MagicMirror:0] online
      PM2        | 2022-01-06T14:50:49: PM2 log: Stopping app:MagicMirror id:0
      PM2        | 2022-01-06T14:50:49: PM2 log: App [MagicMirror:0] exited with code [0] via signal [SIGINT]
      PM2        | 2022-01-06T14:50:49: PM2 log: pid=12707 msg=process killed
      PM2        | 2022-01-06T14:50:59: PM2 log: App [MagicMirror:0] starting in -fork mode-
      PM2        | 2022-01-06T14:50:59: PM2 log: App [MagicMirror:0] online
      PM2        | 2022-01-06T15:51:52: PM2 log: Stopping app:MagicMirror id:0
      PM2        | 2022-01-06T15:51:53: PM2 log: App [MagicMirror:0] exited with code [0] via signal [SIGINT]
      PM2        | 2022-01-06T15:51:53: PM2 log: pid=18675 msg=process killed
      PM2        | 2022-01-06T15:52:00: PM2 log: App [MagicMirror:0] starting in -fork mode-
      PM2        | 2022-01-06T15:52:00: PM2 log: App [MagicMirror:0] online
      /home/pi/.pm2/logs/MagicMirror-out.log last 50 lines:
      0|MagicMir |
      0|MagicMir | > magicmirror@2.18.0 start
      0|MagicMir | > DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js
      0|MagicMir |
      0|MagicMir |
      0|MagicMir |
      0|MagicMir |
      0|MagicMir |
      /home/pi/.pm2/logs/MagicMirror-error.log last 50 lines:
      0|MagicMir |     at require (node:internal/modules/cjs/helpers:94:18)
      0|MagicMir |     at Object.<anonymous> (/home/pi/MagicMirror/js/electron.js:4:14)
      0|MagicMir |     at Module._compile (node:internal/modules/cjs/loader:1116:14)
      0|MagicMir | (node:18699) [DEP0025] DeprecationWarning: sys is deprecated. Use util instead.
      0|MagicMir | (Use `electron --trace-deprecation ...` to show where the warning was created)
      0|MagicMir | A JavaScript error occurred in the main process
      0|MagicMir | Uncaught Exception:
      0|MagicMir | TypeError: Log.log is not a function
      0|MagicMir |     at Object.<anonymous> (/home/pi/MagicMirror/js/app.js:20:5)
      0|MagicMir |     at Object.Module._extensions..js (node:internal/modules/cjs/loader:1169:10)
      0|MagicMir |     at Module.load (node:internal/modules/cjs/loader:988:32)
      0|MagicMir |     at Module._load (node:internal/modules/cjs/loader:829:12)
      0|MagicMir |     at Function.c._load (node:electron/js2c/asar_bundle:5:13331)
      0|MagicMir |     at Module.require (node:internal/modules/cjs/loader:1012:19)
      0|MagicMir | [18754:0106/145107.193182:ERROR:viz_main_impl.cc(161)] Exiting GPU process due to errors during initialization
      0|MagicMir | [18773:0106/145107.559447:ERROR:sandbox_linux.cc(376)] InitializeSandbox() called with multiple threads in process gpu-process.
      0|MagicMir | /home/pi/MagicMirror/node_modules/electron/dist/electron exited with signal SIGINT
      0|MagicMir | App threw an error during load
      0|MagicMir | (node:32542) [DEP0025] DeprecationWarning: sys is deprecated. Use util instead.
      0|MagicMir | [32574:0106/155207.031878:ERROR:viz_main_impl.cc(161)] Exiting GPU process due to errors during initialization
      0|MagicMir | [32615:0106/155207.383004:ERROR:sandbox_linux.cc(376)] InitializeSandbox() called with multiple threads in process gpu-process.
      S 3 Replies Last reply Reply Quote 0
        sdetweil @Richard238
        @richard238 added it to me config.js and it doesn’t matter…
          @richard238 ok, lets start back somewhere
          save your config.js
          copy the sample back to config.js
          and start
          this should work …
            @richard238 i copied your config above to my system
            and it starts ok…
            my node/npm are
            node -v
            v16.1.0
            npm -v
            7.24.2
            so, lets try that , we will use the node version of node version manager (nvm) called n
            # install n globally
            npm i n -g
            # install node version 16.1.0
            n i 16.1.0
            # use the setup path from node version install
            PATH="$PATH"
            # verify node and npm versions
            node -v
            npm -v
              run those from
              or
              pi@magicmirror:~ $
              Or, does it not matter?
                @richard238 does not matter
                not MM specific
                  @richard238 did u try the initial config.js
                    No, took me a while to restore one back from archive, but it’s there now, ready to go.
                    /* Magic Mirror Config Sample
                     * MIT Licensed.
                    var config = {
                    	port: 8080,
                    	ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1"],
                    	language: 'en',
                    	timeFormat: 24,
                    	units: 'metric',
                    			module: 'alert',
                    			module: "updatenotification",
                    			position: "top_bar"
                    			module: 'clock',
                    			position: 'top_left'
                    			module: 'calendar',
                    			header: 'US Holidays',
                    			position: 'top_left',
                    						symbol: 'calendar-check-o ',
                    						url: 'webcal://www.calendarlabs.com/templates/ical/US-Holidays.ics'
                    			module: 'compliments',
                    			position: 'lower_third'
                    			module: 'currentweather',
                    			position: 'top_right',
                    				locationID: '',  //ID from http://www.openweathermap.org
                    				appid: 'YOUR_OPENWEATHER_API_KEY'
                    			module: 'weatherforecast',
                    			header: 'Weather Forecast',
                    				locationID: '5128581',  //ID from http://www.openweathermap.org
                    			module: 'newsfeed',
                    			position: 'bottom_bar',
                    				feeds: [
                    						title: "New York Times",
                    				showSourceTitle: true,
                    				showPublishDate: true
                    My versions:
                    pi@magicmirror:~ $ node -v
                    v16.1.0
                    pi@magicmirror:~ $ npm -v
                    7.11.2
                    NPM is different to yours, but OK to try?
                      @richard238 said in v2.18.0 update gave black screen, then nothing.:
                      in the config folder is the config.js.sample file which is what I wanted you to use
                      just to eliminate other things,
                      but
                      cd ~/MagicMirror
                      npm start
                      may have to clean and nom install again as node version changed…
                        It’s still throwing the log.log error!
                        pi@magicmirror:~/MagicMirror $ npm start
                        (node:6752) [DEP0025] DeprecationWarning: sys is deprecated. Use util instead.
                        Uncaught Exception:
                        [6808:0106/162138.316545:ERROR:viz_main_impl.cc(161)] Exiting GPU process due to errors during initialization
                        [6828:0106/162138.716857:ERROR:sandbox_linux.cc(376)] InitializeSandbox() called with multiple threads in process gpu-process.
                          @richard238 ok, fun times…
                          so, do
                          cd ~
                          mv MagicMirror MagicMirror.save
                          git clone  https://github.com/MichMich/MagicMirror.git
                          cd MagicMirror
                          npm install --only=prod
                          cd config
                          cp config.js.sample config.js
                          cd ..
                          then npm start
                            Clean install - works perfectly! :)
                            pi@magicmirror:~/MagicMirror $ cd config
                            pi@magicmirror:~/MagicMirror/config $ cp config.js.sample config.js
                            pi@magicmirror:~/MagicMirror/config $ cd ..
                            [06.01.2022 16:30.01.197] [LOG]   Starting MagicMirror: v2.18.0
                            [06.01.2022 16:30.01.222] [LOG]   Loading config ...
                            [06.01.2022 16:30.01.238] [LOG]   Loading module helpers ...
                            [06.01.2022 16:30.01.243] [LOG]   No helper found for module: alert.
                            [06.01.2022 16:30.01.307] [LOG]   Initializing new module helper ...
                            [06.01.2022 16:30.01.311] [LOG]   Module helper loaded: updatenotification
                            [06.01.2022 16:30.01.315] [LOG]   No helper found for module: clock.
                            [06.01.2022 16:30.01.765] [LOG]   Initializing new module helper ...
                            [06.01.2022 16:30.01.768] [LOG]   Module helper loaded: calendar
                            [06.01.2022 16:30.01.771] [LOG]   No helper found for module: compliments.
                            [06.01.2022 16:30.01.773] [LOG]   No helper found for module: weather.
                            [06.01.2022 16:30.01.843] [LOG]   Initializing new module helper ...
                            [06.01.2022 16:30.01.845] [LOG]   Module helper loaded: newsfeed
                            [06.01.2022 16:30.01.848] [LOG]   All module helpers loaded.
                            [06.01.2022 16:30.02.152] [LOG]   Starting server on port 8080 ...
                            [06.01.2022 16:30.02.183] [LOG]   Server started ...
                            [06.01.2022 16:30.02.185] [LOG]   Connecting socket for: updatenotification
                            [06.01.2022 16:30.02.187] [LOG]   Starting module helper: updatenotification
                            [06.01.2022 16:30.02.189] [LOG]   Connecting socket for: calendar
                            [06.01.2022 16:30.02.190] [LOG]   Starting node helper for: calendar
                            [06.01.2022 16:30.02.191] [LOG]   Connecting socket for: newsfeed
                            [06.01.2022 16:30.02.192] [LOG]   Starting node helper for: newsfeed
                            [06.01.2022 16:30.02.193] [LOG]   Sockets connected & modules started ...
                            [06.01.2022 16:30.02.845] [LOG]   Launching application.
                            [8846:0106/163005.246382:ERROR:viz_main_impl.cc(161)] Exiting GPU process due to errors during initialization
                            [8886:0106/163005.631441:ERROR:sandbox_linux.cc(376)] InitializeSandbox() called with multiple threads in process gpu-process.
                            [06.01.2022 16:30.12.077] [LOG]   Create new calendarfetcher for url: http://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics - Interval: 300000
                            [06.01.2022 16:30.12.157] [LOG]   Create new newsfetcher for url: https://rss.nytimes.com/services/xml/rss/nyt/HomePage.xml - Interval: 300000
                            [06.01.2022 16:30.12.258] [INFO]  Checking git for module: default
                            [06.01.2022 16:30.13.590] [INFO]  Calendar-Fetcher: Broadcasting 10 events.
                            [06.01.2022 16:30.13.638] [INFO]  Newsfeed-Fetcher: Broadcasting 64 items.
                              @richard238 ok!.. run this to get rid of the sandbox problem
                              bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/fixsandbox)"
                              then
                              cd ~/MagicMirror/modules
                              # save the new default modules folder
                              mv default default.new
                              cd ..
                              # copy all the modules from old install (incl default) preserve ownership and dates, need sudo to copy git info
                              sudo cp -r -p ~/MagicMirror.save/modules/* modules
                              cd modules
                              # remove the copied default modules
                              rm -rf default
                              # restore the saved default
                              mv default.new default
                              copy your full function config.js to MagicMirror/config
                              and try it out
                              cd ~/MagicMirror
                              npm start
                                pi@magicmirror:~ $ cd ~/MagicMirror/modules
                                pi@magicmirror:~/MagicMirror/modules $ mv default default.new
                                pi@magicmirror:~/MagicMirror/modules $ sudo cp -r -p ~/MagicMirror.save/modules/* modules
                                cp: target 'modules' is not a directory
                                Tried it without the space…
                                pi@magicmirror:~/MagicMirror/modules $ sudo cp -r -p ~/MagicMirror.save/modules/*modules
                                cp: missing destination file operand after '/home/pi/MagicMirror.save/modules/*modules'
                                Try 'cp --help' for more information.
                                  Richard238 @Richard238
                                  @richard238
                                  I have to leave shortly Sam.
                                  Thank you for all your help with this today, I’ll try again tomorrow.
                                  Richard.
                                    @richard238 ok
                                    you forgot the cd …
                                    cd ..
                                      Trying to rename config.js to sample,
                                      Error when getting information for file “/home/pi/MagicMirror/config/config.js”: No such file or directory
                                      Error renaming file /home/pi/MagicMirror/config/config.js: No such file or directory
                                      Yet I can see it, I can query it for permissions…
                                      Back tomorrow.
                                      Richard.
                                        you need to copy from save
                                        cd ~/MagicMirror.save/config
                                        cp -p config.js ~/Magicmirror/config
                                          Good morning Sam.
                                          Tried that late yesterday, and yes, it works.
                                          And this morning, I copied
                                          custom.css
                                          from
                                          /home/pi/MagicMirror.save/css
                                          to
                                          /home/pi/MagicMirror/css
                                          This too is working perfectly.
                                          Is there anything else to do, housekeeping maybe, or is that it now?
                                            @richard238 if everything is running ok then I think you are done, and can delete the
                                            MagicMirror.save folder
                                            • 3 / 4
