    v2.18.0 update gave black screen, then nothing.
    73 Posts 4 Posters 43.9k Views 4 Watching
    • mumblebajM Offline
      mumblebaj Module Developer @Richard238
      @richard238 In the MMM-MysqlQuery folder, npm i mysql
        Richard238 @mumblebaj
        @mumblebaj
        pi@magicmirror:~/MagicMirror/modules/MMM-MysqlQuery $ npm i mysql
        npm ERR! code ERESOLVE
        npm ERR! ERESOLVE unable to resolve dependency tree
        npm ERR!
        npm ERR! While resolving: mmm-mysqlquery@1.0.0
        npm ERR! Found: stylelint@8.4.0
        npm ERR! node_modules/stylelint
        npm ERR!   dev stylelint@"^8.3.0" from the root project
        npm ERR!
        npm ERR! Could not resolve dependency:
        npm ERR! peer stylelint@"^14.0.0" from grunt-stylelint@0.17.0
        npm ERR! node_modules/grunt-stylelint
        npm ERR!   dev grunt-stylelint@"latest" from the root project
        npm ERR!
        npm ERR! Fix the upstream dependency conflict, or retry
        npm ERR! this command with --force, or --legacy-peer-deps
        npm ERR! to accept an incorrect (and potentially broken) dependency resolution.
        npm ERR!
        npm ERR! See /home/pi/.npm/eresolve-report.txt for a full report.
        npm ERR!     /home/pi/.npm/_logs/2022-01-06T14_02_53_804Z-debug-0.log
          @richard238 run npm i mysql --force The stylint is a dev dependency.
          R S 2 Replies Last reply Reply Quote 0
            @mumblebaj
            Looking better…
            pi@magicmirror:~/MagicMirror/modules/MMM-MysqlQuery $ npm i mysql --force
            npm WARN using --force Recommended protections disabled.
            npm WARN ERESOLVE overriding peer dependency
            npm WARN While resolving: grunt-stylelint@0.17.0
            npm WARN Found: stylelint@8.4.0
            npm WARN node_modules/stylelint
            npm WARN   dev stylelint@"^8.3.0" from the root project
            npm WARN
            npm WARN Could not resolve dependency:
            npm WARN peer stylelint@"^14.0.0" from grunt-stylelint@0.17.0
            npm WARN node_modules/grunt-stylelint
            npm WARN   dev grunt-stylelint@"latest" from the root project
            npm WARN
            npm WARN Conflicting peer dependency: stylelint@14.2.0
            npm WARN While resolving: stylelint-config-standard@24.0.0
            npm WARN
            npm WARN peer stylelint@"^14.0.0" from stylelint-config-standard@24.0.0
            npm WARN node_modules/stylelint-config-standard
            npm WARN   dev stylelint-config-standard@"latest" from the root project
            npm WARN
            npm WARN deprecated har-validator@5.1.5: this library is no longer supported
            npm WARN deprecated browserslist@2.11.3: Browserslist 2 could fail on reading Browserslist >3.0 config used in other tools.
            npm WARN deprecated circular-json@0.3.3: CircularJSON is in maintenance only, flatted is its successor.
            npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
            npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
            added 606 packages, and audited 1043 packages in 3m
            49 packages are looking for funding
              run `npm fund` for details
            29 vulnerabilities (1 low, 17 moderate, 11 high)
            To address issues that do not require attention, run:
              npm audit fix
            To address all issues (including breaking changes), run:
              npm audit fix --force
            Run `npm audit` for details.
              sdetweil @mumblebaj
              @mumblebaj why my install script does npm install --only=prod
              to remove the dev dependencies
                mumblebaj Module Developer @sdetweil
                @sdetweil :thumbs_up:
                  What are “dev dependencies” to the uninitiated?
                  S R 2 Replies Last reply Reply Quote 0
                    sdetweil @Richard238
                    @richard238 there are dependencies
                    things needed to RUN
                    and dev dependencies,
                    things needed to DEVELOP for existing or new function
                    things like syntax checkers, format checkers, test cases, … 99% of users don’t need that stuff on their disc
                    in the package.json are two lists of dependencies
                    “devDependencies”: {
                    “dependencies”: {
                    unless u specify only runtime (production) , you get both …
                      Richard238 @Richard238
                      Still no MM though. Status says online, but it’s not launching MM.
                      I’ll reboot, because, why not…
                      pi@magicmirror:~/MagicMirror $ pm2 start MagicMirror
                      [PM2] Applying action restartProcessId on app [MagicMirror](ids: [ 0 ])
                      [PM2] [MagicMirror](0) ✓
                      [PM2] Process successfully started
                      │ id │ name               │ mode     │ ↺    │ status    │ cpu      │ memory   │
                      │ 0  │ MagicMirror        │ fork     │ 0    │ online    │ 0%       │ 2.6mb    │
                        @richard238 no reboot…
                        just pm2 stop 0
                        pm2 flush
                        pm2 start 0
                        then pm2 logs --line=50
                          Richard238 @sdetweil
                          pi@magicmirror:~/MagicMirror $ pm2 stop 0
                          [PM2] Applying action stopProcessId on app [0](ids: [ '0' ])
                          │ 0  │ MagicMirror        │ fork     │ 0    │ stopped   │ 0%       │ 0b       │
                          pi@magicmirror:~/MagicMirror $ pm2 flush
                          [PM2] Flushing /home/pi/.pm2/pm2.log
                          [PM2] Flushing:
                          [PM2] /home/pi/.pm2/logs/MagicMirror-out.log
                          [PM2] /home/pi/.pm2/logs/MagicMirror-error.log
                          [PM2] Logs flushed
                          pi@magicmirror:~/MagicMirror $ pm2 start 0
                          [PM2] Applying action restartProcessId on app [0](ids: [ '0' ])
                          │ 0  │ MagicMirror        │ fork     │ 0    │ online    │ 0%       │ 2.4mb    │
                          pi@magicmirror:~/MagicMirror $ pm2 logs --lines=50
                          [TAILING] Tailing last 50 lines for [all] processes (change the value with --lines option)
                          /home/pi/.pm2/pm2.log last 50 lines:
                          PM2        | 2022-01-06T14:24:56: PM2 log: App [MagicMirror:0] starting in -fork mode-
                          PM2        | 2022-01-06T14:24:56: PM2 log: App [MagicMirror:0] online
                          /home/pi/.pm2/logs/MagicMirror-out.log last 50 lines:
                          0|MagicMir |
                          0|MagicMir | > magicmirror@2.18.0 start
                          0|MagicMir | > DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js
                          0|MagicMir |
                          /home/pi/.pm2/logs/MagicMirror-error.log last 50 lines:
                          0|MagicMir | App threw an error during load
                          0|MagicMir | TypeError: Log.log is not a function
                          0|MagicMir |     at Object.<anonymous> (/home/pi/MagicMirror/js/app.js:20:5)
                          0|MagicMir |     at Module._compile (node:internal/modules/cjs/loader:1116:14)
                          0|MagicMir |     at Object.Module._extensions..js (node:internal/modules/cjs/loader:1169:10)
                          0|MagicMir |     at Module.load (node:internal/modules/cjs/loader:988:32)
                          0|MagicMir |     at Module._load (node:internal/modules/cjs/loader:829:12)
                          0|MagicMir |     at Function.c._load (node:electron/js2c/asar_bundle:5:13331)
                          0|MagicMir |     at Module.require (node:internal/modules/cjs/loader:1012:19)
                          0|MagicMir |     at require (node:internal/modules/cjs/helpers:94:18)
                          0|MagicMir |     at Object.<anonymous> (/home/pi/MagicMirror/js/electron.js:4:14)
                          0|MagicMir | (node:12755) [DEP0025] DeprecationWarning: sys is deprecated. Use util instead.
                          0|MagicMir | (Use `electron --trace-deprecation ...` to show where the warning was created)
                          0|MagicMir | A JavaScript error occurred in the main process
                          0|MagicMir | Uncaught Exception:
                          0|MagicMir | [12789:0106/142502.942799:ERROR:viz_main_impl.cc(161)] Exiting GPU process due to errors during initialization
                          0|MagicMir | [12805:0106/142503.366582:ERROR:sandbox_linux.cc(376)] InitializeSandbox() called with multiple threads in process gpu-process.
                            @richard238 ok, do
                            cd ~/MagicMirror
                            rm -rf node_modules
                            rm package-lock.json
                              pi@magicmirror:~/MagicMirror $ rm -rf node_modules
                              pi@magicmirror:~/MagicMirror $ rm package-lock.json
                              pi@magicmirror:~/MagicMirror $ npm install --only=prod
                              > magicmirror@2.18.0 install
                              > echo "Installing vendor files ...
                              > " && cd vendor && npm install --loglevel=error
                              up to date, audited 10 packages in 4s
                              found 0 vulnerabilities
                              > magicmirror@2.18.0 postinstall
                              > npm run install-fonts && echo "MagicMirror installation finished successfully!
                              > magicmirror@2.18.0 install-fonts
                              > echo "Installing fonts ...
                              > " && cd fonts && npm install --loglevel=error
                              up to date, audited 2 packages in 13s
                              > magicmirror@2.18.0 prepare
                              > [ -f node_modules/.bin/husky ] && husky install || echo no husky installed.
                              no husky installed.
                              added 267 packages, and audited 268 packages in 6m
                              19 packages are looking for funding
                                @richard238 and try to run mm again
                                  Online, but no MM showing.
                                  │ 0  │ MagicMirror        │ fork     │ 0    │ online    │ 0%       │ 2.5mb    │
                                    @richard238 and show log output again?
                                    and output of
                                    node -v
                                    npm -v
                                      PM2        | 2022-01-06T14:50:49: PM2 log: Stopping app:MagicMirror id:0
                                      PM2        | 2022-01-06T14:50:49: PM2 log: App [MagicMirror:0] exited with code [0] via signal [SIGINT]
                                      PM2        | 2022-01-06T14:50:49: PM2 log: pid=12707 msg=process killed
                                      PM2        | 2022-01-06T14:50:59: PM2 log: App [MagicMirror:0] starting in -fork mode-
                                      PM2        | 2022-01-06T14:50:59: PM2 log: App [MagicMirror:0] online
                                      0|MagicMir |
                                      0|MagicMir |
                                      0|MagicMir |
                                      0|MagicMir |
                                      0|MagicMir | /home/pi/MagicMirror/node_modules/electron/dist/electron exited with signal SIGINT
                                      0|MagicMir | (node:18699) [DEP0025] DeprecationWarning: sys is deprecated. Use util instead.
                                      0|MagicMir | [18754:0106/145107.193182:ERROR:viz_main_impl.cc(161)] Exiting GPU process due to errors during initialization
                                      0|MagicMir | [18773:0106/145107.559447:ERROR:sandbox_linux.cc(376)] InitializeSandbox() called with multiple threads in process gpu-process.
                                      pi@magicmirror:~/MagicMirror $ node -v
                                      v17.3.0
                                      pi@magicmirror:~/MagicMirror $ npm -v
                                      8.3.0
                                        @richard238 can u show the ~/MagicMirror/config/config.js
                                          config.js, minus private data.
                                          /* Magic Mirror Config Sample
                                           * MIT Licensed.
                                          var config = {
                                          	port: 8080,
                                          	address:"0.0.0.0",
                                          	ipWhitelist: [],
                                          	//ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1", "::ffff:192.168.1.1/120",],
                                          	language: 'en',
                                          	timeFormat: 24,
                                          	units: 'metric',
                                          			module: 'alert',
                                          			module: "updatenotification",
                                          			position: "top_bar"
                                          			module: 'clock',
                                          			position: 'top_left'
                                          			module: 'calendar',
                                          			header: 'Calendar',
                                          			position: 'top_left',
                                                              maximumEntries: 6, // Total Maximum Entries
                                                              maximumNumberOfDays: 365,
                                                              displaySymbol: true,
                                                              defaultSymbol: "calendar", // Fontawesome Symbol see http://fontawesome.io/cheatsheet/
                                                              displayRepeatingCountTitle: false,
                                                              defaultRepeatingCountTitle: "",
                                                              maxTitleLength: 30,
                                                              fetchInterval: 5 * 60 * 1000, // Update every 5 minutes.
                                                              animationSpeed: 2000,
                                                              fade: true,
                                                              showEnd: false,
                                                              urgency: 0,
                                                              timeFormat: "absolute",
                                                              dateFormat: "ddd Do MMMM",
                                                              getRelative: 0,
                                                              fadePoint: 0.50, // Start on 1/4th of the list.
                                                              hidePrivate: false,
                                          						symbol: 'calendar-check-o ',
                                          						url: 'https:/nnnnnnnnnnnnnnnnnnnnn/basic.ics'
                                          			module: 'calendar',
                                          			header: 'Binday',
                                          			position: 'bottom_left',
                                                              maximumEntries: 4, // Total Maximum Entries
                                                              maxTitleLength: 30,
                                                              fade: true,
                                                              showEnd: false,
                                                              urgency: 0,
                                                              getRelative: 0,
                                                              hidePrivate: false,
                                          						symbol: 'trash-o ',
                                          						url: 'https:/nnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnn/basic.ics'
                                                          titleReplace: {
                                                          //	"'s birthday": "",
                                                          //	"Recycling": "Bins",
                                                              "Red Bin": "Red & Black Bins",
                                                              "Green Bin": "Green & Black Bins"
                                                          // Override start method.
                                                          start: function () {
                                                              Log.log("Starting module: " + this.name);
                                                              /* This code changed times to 24hr clock until April 17 system update.
                                                              ** Set locale.
                                                              **  if (config.language === 'en' && config.timeFormat == 24) {
                                                              **  config.language = 'en-gb';
                                                              ** moment.locale(config.language);
                                                              for (var c in this.config.calendars) {
        var calendar = this.config.calendars[c];
        calendar.url = calendar.url.replace("webcal://", "http://");
        this.addCalendar(calendar.url, calendar.user, calendar.pass);
                                                              this.calendarData = {};
                                                              this.loaded = false;
                                          			module: 'compliments',
                                          			position: 'lower_third',
                                          			anytime: [
                                          				"A1",
                                                          "A2",
                                                          "A3"
                                          			morning: [
                                          				"M1",
                                          				"M2",
                                          				"M3"
                                          			afternoon: [
                                          				"N1",
                                          				"N2",
                                          				"N3"
                                          			evening: [
                                          				"E1",
                                          				"E2",
                                          				"E3"
                                          		updateInterval: 30000,
                                          		remoteFile: null,
                                          		fadeSpeed: 4000
                                          			/*config: {
                                          				remoteFile: 'compliments.json'
                                                      module: 'MMM-doomsDay',
                                                      position: 'top_center', // This can be any of the regions, best results in center regions
                                                      doomsDay: "2022-01-06 24:00:00", // YYYY-MM-DD HH:MM:SS, Do not alter the time, just the date
                                                      /*            doomsDay: "2020-12-21 24:00:00", // YYYY-MM-DD HH:MM:SS, Do not alter the time, just the date   */
                                                      toWhat: "today",
                                          			module: 'currentweather',
                                          			header: 'Current weather for: ',
                                          			position: 'top_right',
                                          				locationID: 'nnnn',  //ID from http://www.openweathermap.org
                                          				appid: 'nnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnn'
                                          			module: 'weatherforecast',
                                          			header: 'Weather Forecast',
                                          				locationID: 'nnnnnnn',  //ID from http://www.openweathermap.org
                                          				appid: 'aaannnnnnnnnn'
                                                      module: 'MMM-MysqlQuery',
                                                      position: 'bottom_right',
                                          			header: 'Greenhouse Status',
                                                          connection: {
                                                              host: "192.168.1.23",
                                                              port: 3306,
                                                              user: "nnnnnnnnnnnnnnnn",
                                                              password: "nnnnnnnnnnnnnnnn",
                                                              database: "garage"
                                          /*              query: `select Temp-2
        from readings
        order by ID desc
        limit 1`,
                                          			query: "select Added, \
                                          			Temp, \
                                          						Pressure, \
                                          						Humidity \
                                          						from gh_readings \
                                          						order by ID \
                                          						desc limit 3",
                                              			intervalSeconds: 1 * 60,
                                                          emptyMessage: "No data!",
                                                          columns: [
                                                              { name: "Added",     title: "At", cssClass: "left", dateFormat: "time", dateLocale: "en-GB" },
                                                              { name: "Temp",     title: "Temp", cssClass: "left", suffix: "°C", nullValue: "???" },
                                                              { name: "Pressure",     title: "Pressure", cssClass: "left", suffix: " hPa", nullValue: "???" },
                                                              { name: "Humidity",     title: "Humidity", cssClass: "left", suffix: " %" },
                                          			module: 'newsfeed',
                                          			position: 'bottom_bar',
                                          				feeds: [
        title: "BBC World",
        url: "http://feeds.bbci.co.uk/news/world/rss.xml"
        title: "Al Jazeera",
        url: "https://www.aljazeera.com/xml/rss/all.xml"
        title: "Sky news",
        url: "http://feeds.skynews.com/feeds/rss/world.xml"
                                          				showSourceTitle: true,
                                          				showPublishDate: true,
                                                          reloadInterval:  2 * 60 * 1000, // every 5 minutes
                                                          updateInterval: 2 * 5000
                                            @richard238 said in v2.18.0 update gave black screen, then nothing.:
                                            >                     ** Set locale.
                                            what is that? I’m not aware of any code in config for calendar
                                            for grins, can you add // in front of the Log.log statement
                                            • 2 / 4
