    Black screen with v2.18.0
    3 Posts 2 Posters 820 Views 2 Watching
      bmue
      Hello,
      Im sorry if Im not posting this in the right place but I was tried to update my MM with “git pull && npm install” but I just get a black screen so I was wondering if someone can point me in the right direction because I’m a complete newbie here.
      I have tried to troubleshoot with some of the previous suggestions in this forum but I’m afraid to break any dependencies or something (If I hadn’t already), and I was already in the finishing process to end my mirror so any help will be so, so much appreciated.
      Thanks in advance
      Im running my MagicMirror through PM2 and here’s the log:
      /home/pi/.pm2/logs/mm-error.log last 15 lines:
      0|mm       | - /home/pi/MagicMirror/js/electron.js
      0|mm       | - /home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js
      0|mm       | -
      0|mm       |     at Module._resolveFilename (node:internal/modules/cjs/loader:940:15)
      0|mm       |     at Function.n._resolveFilename (node:electron/js2c/browser_init:249:1128)
      0|mm       |     at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/module-alias/index.js:49:29)
      0|mm       |     at Module._load (node:internal/modules/cjs/loader:785:27)
      0|mm       |     at Function.c._load (node:electron/js2c/asar_bundle:5:13331)
      0|mm       |     at Module.require (node:internal/modules/cjs/loader:1012:19)
      0|mm       |     at require (node:internal/modules/cjs/helpers:94:18)
      0|mm       |     at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-cryptocurrency/node_helper.js:2:15)
      0|mm       |     at Module._compile (node:internal/modules/cjs/loader:1116:14)
      0|mm       |     at Object.Module._extensions..js (node:internal/modules/cjs/loader:1169:10)
      0|mm       |     at Module.load (node:internal/modules/cjs/loader:988:32)
      0|mm       |     at Module._load (node:internal/modules/cjs/loader:829:12)
      0|mm       |     at loadModule (/home/pi/MagicMirror/js/app.js:127:19)
      0|mm       |     at loadNextModule (/home/pi/MagicMirror/js/app.js:165:5)
      0|mm       |     at /home/pi/MagicMirror/js/app.js:167:6
      0|mm       |     at Class.loaded (/home/pi/MagicMirror/js/node_helper.js:18:3)
      0|mm       |     at loadModule (/home/pi/MagicMirror/js/app.js:144:6)
      0|mm       |     at /home/pi/MagicMirror/js/app.js:167:6 {
      0|mm       |   code: 'MODULE_NOT_FOUND',
      0|mm       |   requireStack: [
      0|mm       |     '/home/pi/MagicMirror/modules/MMM-cryptocurrency/node_helper.js',
      0|mm       |     '/home/pi/MagicMirror/js/app.js',
      0|mm       |     '/home/pi/MagicMirror/js/electron.js',
      0|mm       |     '/home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js',
      0|mm       |     undefined
      0|mm       |   ]
      0|mm       | }
      0|mm       | [10.01.2022 01:31.29.246] [ERROR] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
      0|mm       | [10.01.2022 01:31.29.248] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
      0|mm       | [6258:0110/013130.992573:ERROR:viz_main_impl.cc(161)] Exiting GPU process due to errors during initialization
      0|mm       | [6282:0110/013131.304650:ERROR:sandbox_linux.cc(376)] InitializeSandbox() called with multiple threads in process gpu-process.
      0|mm       | [10.01.2022 01:35.26.563] [ERROR] Whoops! There was an uncaught exception...
      0|mm       | [10.01.2022 01:35.26.567] [ERROR] TypeError: Cannot read properties of undefined (reading 'close')
      0|mm       |     at App.stop (/home/pi/MagicMirror/js/app.js:257:14)
      0|mm       |     at App.<anonymous> (/home/pi/MagicMirror/js/electron.js:139:7)
      0|mm       |     at App.emit (node:events:394:28)
      0|mm       |     at appMethod (node:electron/js2c/browser_init:69:1830)
      0|mm       |     at Object.execute (node:electron/js2c/browser_init:69:5623)
      0|mm       |     at MenuItem.click (node:electron/js2c/browser_init:73:1862)
      0|mm       |     at Object.a._executeCommand (node:electron/js2c/browser_init:81:2453)
      0|mm       | [10.01.2022 01:35.26.570] [ERROR] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
      0|mm       | [10.01.2022 01:35.26.573] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
      0|mm       | /home/pi/MagicMirror/node_modules/electron/dist/electron exited with signal SIGINT
        bmue @sdetweil
        @sdetweil said in Black screen with v2.18.0:
        @bmue see
        need a few more lines of output
        @sdetweil Thanks for replying so fast.
        I just noticed it was a specific module causing those errors. I removed it and I install it again and it’s working.
        Thanks again
          sdetweil @bmue
          @bmue see
            bmue @sdetweil
            @bmue see
            Thanks again
