    MMM-PersonalConfig: Persist personal config to GitHub
    4 Posts 2 Posters 1.1k Views 2 Watching
    • C Offline
      CFenner
      Description:
      This module is meant to host your personal mirror configuration and persist it to GitHub to easily restore your config if it’s lost and to have a change history (config-as-code).
      The linked repository is a template repository that you can use to create your own copy. Clone your personal copy to your mirror.
      The module as of now just provides the ability to link your config files (config.js, custom.css) to the right locations. Thanks to updateNotification module, changes to the config repository are highlighted on the mirror.
      Future features:
      • update config via telegram command (chat-ops)
      • auto update config & restart on changes (git-ops)
      Screenshots:
      This module provides no visualization.
      Configuration:
        module: "MMM-PersonalConfig",
      Download:
      [card:https://github.com/CFenner/MMM-PersonalConfig-Template]
        sdetweil
        could you change your module name?
        my MMM-Config has been out for a while and provides a form based admin for MM
        https://github.com/sdetweil/MMM-Config
        • C Offline
          CFenner @sdetweil
          @sdetweil thanks, didn’t check that! Will do so.
          Could you add your module to the modules list: https://github.com/MichMich/MagicMirror/wiki/3rd-Party-Modules
            sdetweil @CFenner
            @cfenner no, not at this time
