    Pm2 not starting MM
    5 Posts 3 Posters 1.2k Views 3 Watching
    • K Offline
      kikosilva17
      I’m having a bit of an issue with my pm2, because when I do “pm2 start MagicMirror”, it appears that is started, however nothing shows up on the screen… When I do “cd MagicMirror” and then “npm start” it works… Sorry if this is some noob problem but I’m struggling here 😔.
      • K Offline
        kikosilva17
        @kikosilva17 Forgot to mention that in using MX Linux and an old PC due to the fact that raspberry’s are all sold out in my country…
        BKeyportB S 2 Replies Last reply Reply Quote 0
        • BKeyportB Offline
          BKeyport Module Developer @kikosilva17
          @kikosilva17 Sounds like you have the wrong command saved to it, or the script used isn’t accurate.
          You can delete the command and roll your own. Try something like this:
          pm2 delete MagicMirror
          cd MagicMirror
          pm2 start npm start --name MagicMirror
            sdetweil @kikosilva17
            @kikosilva17 run
            pm2 logs --lines=50
            may have to clear them and redo
            pm2 stop all
            pm2 flush
            wait 10 seconds
            pm2 logs
              sdetweil @BKeyport
              @bkeyport installers/mm.sh is there for this purpose
