    font size
    4 Posts 5 Posters 2.7k Views 5 Watching
    • P Offline
      pat59
      hello how to change the font size of degrees on the currentweather module
      thank you
        sdetweil @pat59
        @pat59 u will have to use CSS to change the size. I do not know the classes to modify, but you can find them
        see this
        https://forum.magicmirror.builders/topic/14862/help-with-a-couple-css-issues?_=1642973279503
        more importantly
        currentweather and weatherforecast are discontinued ( deprecated) and will be removed
        use the weather module with the type of current or forecast
        • P Offline
          pat59
          Hello thank you for your return, I just found while browsing the site.
          thanks again for everything
          • P Offline
            paunboli2 @sdetweil
            @sdetweil thanks for sharing this link , this helps me a lot
