    Trouble with install MM
    8 Posts 2 Posters 1.7k Views 2 Watching
    • F Offline
      fischi87
      Hello guys, I try to start a second mirror but I get this error: somebody a solution?
      is a fresh install!
      pi@raspberrypi:~/MagicMirror $ cat /home/pi/.npm/_logs/2022-02-26T20_40_40_863Z-debug.log
      1 verbose cli [ '/usr/bin/node', '/usr/bin/npm', 'run', 'start' ]
      2 info using npm@6.14.12
      3 info using node@v10.24.1
      5 info lifecycle magicmirror@2.18.0~prestart: magicmirror@2.18.0
      6 info lifecycle magicmirror@2.18.0~start: magicmirror@2.18.0
      7 verbose lifecycle magicmirror@2.18.0~start: unsafe-perm in lifecycle true
      8 verbose lifecycle magicmirror@2.18.0~start: PATH: /usr/lib/node_modules/npm/node_modules/npm-lifecycle/node-gyp-bin:/home/pi/MagicMirror/node_modules/.bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/local/games:/usr/games
      9 verbose lifecycle magicmirror@2.18.0~start: CWD: /home/pi/MagicMirror
      10 silly lifecycle magicmirror@2.18.0~start: Args: [ '-c',
      10 silly lifecycle   'DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js' ]
      11 silly lifecycle magicmirror@2.18.0~start: Returned: code: 1  signal: null
      12 info lifecycle magicmirror@2.18.0~start: Failed to exec start script
      13 verbose stack Error: magicmirror@2.18.0 start: `DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js`
      13 verbose stack Exit status 1
      13 verbose stack     at EventEmitter.<anonymous> (/usr/lib/node_modules/npm/node_modules/npm-lifecycle/index.js:332:16)
      13 verbose stack     at EventEmitter.emit (events.js:198:13)
      13 verbose stack     at ChildProcess.<anonymous> (/usr/lib/node_modules/npm/node_modules/npm-lifecycle/lib/spawn.js:55:14)
      13 verbose stack     at ChildProcess.emit (events.js:198:13)
      13 verbose stack     at maybeClose (internal/child_process.js:982:16)
      13 verbose stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:259:5)
      14 verbose pkgid magicmirror@2.18.0
      15 verbose cwd /home/pi/MagicMirror
      16 verbose Linux 5.10.63-v7l+
      17 verbose argv "/usr/bin/node" "/usr/bin/npm" "run" "start"
      18 verbose node v10.24.1
      19 verbose npm  v6.14.12
      20 error code ELIFECYCLE
      21 error errno 1
      22 error magicmirror@2.18.0 start: `DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js`
      22 error Exit status 1
      23 error Failed at the magicmirror@2.18.0 start script.
      23 error This is probably not a problem with npm. There is likely additional logging output above.
      24 verbose exit [ 1, true ]
      • F Offline
        fischi87 @sdetweil
        @sdetweil said in Trouble with install MM:
        @fischi87 are u running system in graphics mode? must have desktop, before starting mm
        yes I do!
        i don’t had the display connected. now it works!
          sdetweil @fischi87
          @fischi87 need node 14 or 16.
          use my install script.
          see
          erase the MagicMirror folder first
          • F Offline
            fischi87 @sdetweil
            tried already but I get this:
            install log being saved to /home/pi/install.log
            system running in command line mode, configured for graphical desktop, please reboot
              sdetweil @fischi87
              @fischi87 yes, needs to be in desktop mode. electron/browser draws graphics
              cannot be lite version
              F 2 Replies Last reply Reply Quote 0
              • F Offline
                fischi87 @sdetweil
                i upgrade and now I get this after npm run start:
                /home/pi/MagicMirror/node_modules/electron/dist/electron exited with signal SIGTRAP
                • F Offline
                  fischi87 @sdetweil
                  what can I do to geht the electron/browser draws graphics?
                    sdetweil @fischi87
                    • F Offline
                      fischi87 @sdetweil
                      yes I do!
