    Volvo on Call
    34 Posts 4 Posters 13.1k Views 4 Watching
    • MZ-BERM Offline
      MZ-BER
      Hello there - I’m discovering the Volvo on Call API and I noticed that Volvo added a screenshot from a MagicMirror on their website. Does anyone knows to whom that belongs?
      I tried to install the https://github.com/eouia/MMM-VolvoOnCall but I’m stuck. I’m getting an 401 Error with the message I’m unauthorised. :-/
      https://developer.volvocars.com/volvo-api/
      • MZ-BERM Offline
        MZ-BER
        I was able to fix the problem with the authorization issue (just reseted my password). So I’m able to pull the information with the python script from https://github.com/molobrakos/volvooncall.
        Now I’m getting the following error as soon as I start the Mirror:
        [28.02.2022 22:03.38.534] [LOG]   [VOC] ERROR: No vehicle found. Check your account. Module stopped.
        Which is weird because I can pull the data from my car by just typing voc list or voc dashboard
        Any advice would be really appreciated.
        • JerryPJ Offline
          JerryP
          @mz-ber
          What is your config look like?
          MZ-BERM 1 Reply Last reply Reply Quote 0
          • MZ-BERM Offline
            MZ-BER @JerryP
            Hey @jerryp - I’m getting the output as soon as I write voc list. So that seems to work.
            My config:
              module: "MMM-VolvoOnCall",
            	scanInterval: 1000 * 60 * 30,
                    units: "metric",
                    timestampFormat: "MMM D. HH:mm:ss",
            	durationFormat: "HH:mm",
            @JerryP Can you please share your config? I’m not sure what I’m doing wrong.
            JerryPJ 1 Reply Last reply Reply Quote 0
            • JerryPJ Offline
              JerryP @MZ-BER
              @mz-ber
              yes but now you miss the data in the config
              			disabled: false, //false, true
              			position: "bottom_left",
              			units: "metric",
              			mapConfig: {
              				apiKey: "",  // Your Google Map API Key
              			display: { // You can control which section will be displayed or not.
              				info: false,
              				position: false,
              				status: true,
              				notice: true,
              				trip: false,
              • MZ-BERM Offline
                MZ-BER @JerryP
                @jerryp Okay, do I need an api key from google maps?
                • JerryPJ Offline
                  JerryP @MZ-BER
                  @mz-ber
                  yes i’f you use the map function. I have add the api and it’s working fine
                  • MZ-BERM Offline
                    MZ-BER @JerryP
                    @jerryp is it working for you without the map function? I’m actually not interested in it.
                    • JerryPJ Offline
                      JerryP @MZ-BER
                      @mz-ber
                      Yes but i have put the api key in the config. I dont have try it whitout the key
                      • MZ-BERM Offline
                        MZ-BER @JerryP
                        @jerryp Would you do me a favor and test it without the key or a wrong key? Just wondering if that is the issue
                        • JerryPJ Offline
                          JerryP @MZ-BER
                          @mz-ber
                          yes it’s working like above whit out api key
                          • MZ-BERM Offline
                            MZ-BER @JerryP
                            @jerryp Hi Jerry - thank you for checking! I still stuck and I dont know where I’m doing something wrong. I dont want to give up because I know it is still working for you.
                            The weird thing is that the API works perfect. I can pull all informations from my car via voc dashborad.
                            Only the module is telling me: No vehicle found
                            That is my current config:
                            	  disabled: false,
                            	  debug: true,
                            		units: "metric",
                            		display: {
                            					info: true,
                            					position: true,
                            					status: true,
                            					notice: true,
                            					trip: true,
                            It is setup correctly I guess.
                            I’m wondering where in this node_helper.js is the voc pulled from? I’m not good in JavaScript :-(
                            const exec = require('child_process').exec
                            const spawn = require('child_process').spawn
                            const moment = require("moment")
                            var NodeHelper = require("node_helper")
                              start: function() {
                                this.config = null
                                this.carInfo = []
                              socketNotificationReceived: function(noti, payload) {
                                if (noti == "SCAN") {
                                  this.scan()
                                  this.trip()
                                if (noti == "INIT") {
                                  this.config = payload
                                  this.list()
                              list: function() {
                                exec("voc list", (e, sdo, sde)=>{
                                  if (e) {
                                    console.log("[VOC] ERROR(>list):", e.toString())
                                  } else {
                                    this.listResult(sdo)
                              listResult: function(output) {
                                var re = /^([^ ]+)\s\(([^\)]+)\)\s([^ ]+)$/gm
                                var matches = null
                                var result = []
                                while (matches = re.exec(output)) {
                                  this.carInfo.push({
                                    type: matches[2],
                                    vin: matches[3]
                                if (this.carInfo.length > 0) {
                                  this.sendSocketNotification("INITIALIZED", this.carInfo)
                                } else {
                                  console.log("[VOC] ERROR: No vehicle found. Check your account. Module stopped.")
                              scan: function() {
                                exec("voc dashboard", (e, sdo, sde)=> {
                                  if (e) {
                                    console.log("[VOC] ERROR:", e.toString())
                                  } else {
                                    this.scanResult(sdo)
                                    //this.sendSocketNotification("RESULT", sdo)
                              scanResult: function(output) {
                                var carIndex = this.carInfo.map((value, index, array)=>{
                                  return value.id
                                var result = []
                                var re = /^([^\s]+)\s([\w\s]+)\:\s(.+)$/gm
                                var matches = null
                                  var idx = carIndex.indexOf(matches[1])
                                  var key = matches[2].trim()
                                  var value = this.reformValue(key, matches[3].trim())
                                  if (typeof result[idx] == 'undefined') {
                                    result[idx] = []
                                  result[idx].push({
                                    key: key,
                                    value: value
                                if (Object.keys(result).length == 0) {
                                  console.log("[VOC] ERROR: No information could be retrieved.")
                                  console.log(output)
                                } else {
                                  this.sendSocketNotification("SCAN_RESULT", result)
                              reformValue: function(key, value) {
                                if (key == "Position") {
                                  var re = /([0-9\.\-]+)\,\s([0-9\.\-]+),\s\'([^\']+)\'/
                                  var matches = re.exec(value)
                                  if (matches) {
                                    return {
                                      lat: matches[1],
                                      long: matches[2],
                                      time: moment(matches[3]).format("X")
                                  } else {
                                    return null
                                if (key == "Fuel level") {
                                  return value.replace(/\s/, "")
                                if (key == "Fuel amount" || key == "Range" || key == "Odometer" || key == "Average speed") {
                                  return value.replace(/[^0-9\.]+/g, '')
                                if (key == "Fuel consumption") {
                                  var re = /^([0-9\.]+)/g
                                  if (matches) {
                                    return matches[1]
                                return value
                              trip: function() {
                                for(var i = 0; i < this.carInfo.length; i++) {
                                  try {
                                    carId = this.carInfo[i].id
                                    var sdo = ""
                                    var result = spawn('voc', [
                                      '-i', carId,
                                      '--json', 'trips'
                                    result.stdout.on('data', (data)=>{
                                      sdo += data
                                    result.on('close', (killcode)=>{
                                      this.tripResult(carId, JSON.parse(sdo))
                                  } catch (e) {
                              tripResult: function(carId, obj) {
                                if (Array.isArray(obj) && obj.length > 0) {
                                  var trip = obj[0]
                                  var detail = trip.tripDetails[0]
                                  var ret = {
                                    title: trip.name,
                                    category: trip.category,
                                    note: trip.userNotes,
                                    fuelConsumption : detail.fuelConsumption,
                                    electricalConsumption : detail.electricalConsumption,
                                    electricalRegeneration: detail.electricalRegeneration,
                                    distance: detail.distance,
                                    startTime: moment(detail.startTime).format("X"),
                                    startPosition: detail.startPosition,
                                    endTime: moment(detail.endTime).format("X"),
                                    endPosition: detail.endPosition,
                                  this.sendSocketNotification("TRIP_RESULT", {id:carId, data:ret})
                                } else {
                                  return
                              sdetweil @MZ-BER
                              @mz-ber
                              list: function() {
                                    if (e) {
                                    } else {
                              then the good results are parsed in listResult()
                              • MZ-BERM Offline
                                MZ-BER @sdetweil
                                @sdetweil Thank you Sam! Can you please tell me what the letters in the bracket mean? (e, sdo, sde)
                                • MZ-BERM Offline
                                  MZ-BER @MZ-BER
                                  @mz-ber Oh I guess I understand. If the function is not getting the right details than -> e if everything is okay than -> sdo
                                    sdetweil @MZ-BER
                                    @mz-ber exec(“voc list”, (e, sdo, sde)=
                                    execs the command “voc list”
                                    and the exec function returns
                                    error (e)
                                    stdout (sdo)
                                    and stderr(sde)
                                    so if no error (e is null)
                                    it sends the command output to the listResults function
                                    • MZ-BERM Offline
                                      MZ-BER @sdetweil
                                      @sdetweil Thank you for the explanation. Is the function executing voc list in the terminal? If I’m doing manually voc list I’m getting a result.
                                      Is there a way to see what the script is getting back in detail?
                                      Again, thank you very much!
                                        sdetweil @MZ-BER
                                        @mz-ber yes executing just like on console
                                        nothing built in to show results.
                                        but you could add a
                                        console.log(sdo)
                                        before the call to listResults()
                                        and see it where u start mm
                                        npm start
                                        it should be the same outout
                                        • MZ-BERM Offline
                                          MZ-BER @sdetweil
                                          @sdetweil Alright, I added the console.log before the call listResult() and it is getting the details from my car. I feel sooo close to get this running but I dont know where it is stuck. :anguished_face:
                                          Is maybe the regex search not getting the details viewed?
                                            sdetweil @MZ-BER
                                            @mz-ber so the regular expression isn’t finding your text
                                            I use this for building and testing rejects
                                            https://regex101.com/
