    Volvo on Call
    34 Posts 4 Posters 11.3k Views 4 Watching
    • MZ-BERM Offline
      MZ-BER @sdetweil
      @sdetweil Yes, I also checked that with regex101. Can I just parse in the details I have?
      listResult: function(output) {
          var re = B-PY 186 (V90) XVASS123345
        sdetweil @MZ-BER
        @mz-ber the regex returns an array of matched things
          sdetweil @MZ-BER
          @mz-ber i think the regex is not expecting the 186
          try ths one
          /^([^ ]+)\s.*\(([^\/]+)\/([^\)]+)\)$/gm
          start of string ^
          capture up to the 1st space ([^ ]+)
          skip everything to (and including) the open paren \s.*(
          get the two things in the parens, separated by /, not including the parens
          capture up to the slash ([^/]+)
          skip the slash /
          capture up to the close pareen ([^)]+)
          skip the close paren )
          end of string $
          MZ-BERM 1 Reply Last reply Reply Quote 0
          • MZ-BERM Offline
            MZ-BER @sdetweil
            @sdetweil Your one is not working. Here are the details I try to get:
            B-PY 186 (V90/2019) YV1PWAKUDK1XXXXXX
            I also played a bit with the expression and removed the white space:
            before:
                var re = /^([^ ]+)\s\(([^\)]+)\)\s([^ ]+)$/gm
            after:
                var re = /^([^]+)\s\(([^\)]+)\)\s([^]+)$/gm
            That is working based on regex101 and I dont get the error anymore. But nothing is loaded into the MM
              sdetweil @MZ-BER
              @mz-ber the regex has to return 3 items
              • MZ-BERM Offline
                MZ-BER @sdetweil
                @sdetweil Right! And I guess it is doing so? Or am I wrong? b5cae454-af0f-4887-abbb-bd6117d3fe82-image.png
                  sdetweil @MZ-BER
                  @mz-ber i do not know what the module is expecting or its process
                  it also does a voc dashboard…
                  and parses that…
                  • MZ-BERM Offline
                    MZ-BER @sdetweil
                    @sdetweil Yes, I guess voc list should work. But really quick to voc dashboard
                    That is the list I’m getting
                    B-PY 186 Position             : (52.55352783203125, 13.4XXXXXXXXXX6, '2022-03-06 20:20:32+01:00', None, None)
                    B-PY 186 Door lock            : Locked
                    B-PY 186 Heater               : Off
                    B-PY 186 Odometer             : 34484 km
                    B-PY 186 Trip meter 1         : 131 km
                    B-PY 186 Trip meter 2         : 1 km
                    B-PY 186 Fuel amount          : 40 L
                    B-PY 186 Fuel level           : 72 %
                    B-PY 186 Fuel consumption     : 9.9 L/100 km
                    B-PY 186 Range                : 440 km
                    B-PY 186 Average speed        : 31 km/h
                    B-PY 186 Last trip            : 2022-03-06 20:20:32+01:00
                    B-PY 186 Engine               : On
                    B-PY 186 Door lock            : On
                    B-PY 186 Hood                 : Closed
                    B-PY 186 Tailgate             : Closed
                    B-PY 186 Front left door      : Closed
                    B-PY 186 Front right door     : Closed
                    B-PY 186 Rear left door       : Closed
                    B-PY 186 Rear right door      : Closed
                    B-PY 186 Front left window    : Closed
                    B-PY 186 Front right window   : Closed
                    B-PY 186 Rear left window     : Closed
                    B-PY 186 Rear right window    : Closed
                    B-PY 186 Front right tyre     : OK
                    B-PY 186 Front left tyre      : OK
                    B-PY 186 Rear right tyre      : OK
                    B-PY 186 Rear left tyre       : OK
                    B-PY 186 Washer fluid         : OK
                    B-PY 186 Brake Fluid          : OK
                    B-PY 186 Service              : OK
                    B-PY 186 Bulbs                : OK
                    B-PY 186 Doors                : Closed
                    B-PY 186 Windows              : Closed
                    With the regular expression /^([^\s]+)\s([\w\s]+)\:\s(.+)$/gm it is not perfectly matching the groups:
                    B-PY 186 should be always in group 1. Do you have an idea to adjust the expression?
                    • MZ-BERM Offline
                      MZ-BER @MZ-BER
                      I got it to work! Finally.
                      The whole problem was my licence plate. The regular expression wasn’t able to grab the right groups. Thank you @sdetweil for helping me to investigate.
                        sdetweil @MZ-BER
                        @mz-ber how did u fix the regex?
                        i would change the 1st capture to
                        in the list
                        ^([^\(]+)\s  =capture up to but not including (
                        in the scan = capture 1st 8 chars
                        how long is a license number? always 8?
                        ^(.{8})\s
                        • 3 / 4
